07-02-2017, 11:32 AM
#106
Originally Posted by jfry008
I just checked and it said they were sold out but thanks anyway!!
2016 4runner SR5 Premium
2007 4runner Limited
1998 Camry (almost 300,000 miles)
10-18-2017, 02:08 PM
#107
Real Name: Sunny
Real Name: Sunny
Question
Are you guys re-torquing at 50,100 or 500 miles? I'm leaning towards 50 then double checking at 500
2017 White TRD Off Road Prem w/ KDSS: TRD Wheels + Grill/Garnish . 6112/5100 2.5/1.5 Lift, TRD CAI, TRD Skid Plate, 285/70/17 Nitto Terra Grapplers My Build
02-20-2020, 07:56 PM
#108
I just got a set of Spidertrax 1.25” spacers... I have the torque wrench, I have the red loctite, just want to make sure I’m doing it right.
The nuts that come on the spacer, with the angled/conical side facing inward, would go on first to hold the spacer on... snug to 90 (per spidertrax instructions)... Then the wheel... then the factory lug nuts.
Check spacer nuts after 50 miles by torquing them at 80 ft lb, if there’s ANY movement, start over
I feel confident but all these horror stories scare me.
02-20-2020, 08:03 PM
#109
Real Name: Todd
Real Name: Todd
That's correct. The only horror stories are from people either using the non-hubcentric spacers or not setting/checking the torque correctly. I've had Spidertrax spacers on my Tacoma for a while with zero issues. Follow the instructions and you'll be fine.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
02-22-2020, 08:59 PM
#110
3 years with ebay hubcentric spacers that cost me 50 bucks for all 4. No problems.
Sent from my Redmi 4 using Tapatalk
02-22-2020, 09:09 PM
#111
Ive also been running wheel spacers for about 20 years now and ZERO issues. Ive only ran Spidertrax spacers and have always torqed to specs and rechecked. I cant remember hearing anything like this happening due to the spacers, always have been something else.
Bottom line is, you're ok, the 4runner can be replaced, you cant.
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
06-19-2020, 02:56 AM
#112
Real Name: Blair
Real Name: Blair
Installing a Spidertrax 1.25" set tomorrow. I'm going to torque to 90 ft lbs and draw a line with a paint pen across the spacer's lug and spacer body. I'll do a visual after 50-100 miles for any creep and again when I rotate the new tires I'm getting next week. I have complete faith in these things because I will do a very careful job. Which brings me to my questions:
I am probably going to use Discount (AKA America's) Tire in San Mateo County, CA - Does anyone know if that company is anti-spacer and how do I ensure that the tire tech doesn't over-torque and weaken the spacer's studs without being a helicopter customer? Also, do I even mention that I have spacers during the sale, and instead try to talk to the tech before the wheels go back on after balancing?
I'm sure it will be fine, but I'm busy over-thinking it..........
06-19-2020, 08:42 AM
#113
Helicopter customer?
2006 Sport Edition XSP V-8 4x4
285/70-17 BFG TA KO2, Fox 2" coil overs, SPC UCAs, TRD Style 17x8 Wheels, Cobra handheld, Pioneer headunit (Navi, DVD), Alpine amp, JL Audio Sub and upgraded speakers, HIDs (head & fog lights), LEDs all above inside lights
06-19-2020, 09:48 AM
#114
Hovering over them while doing there work.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
06-19-2020, 10:19 AM
#115
Thats cool. I always try to do the same :-)
06-19-2020, 06:30 PM
#116
Real Name: Carlos V.
If I cannot do at least some light "hovering", I go to another place.
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
06-19-2020, 07:13 PM
#117
I just took the spacers off my wheels in the back to grease the contact points on the shoes. I torqued the spacers down to 80 ft lbs, but didn't put loctite on them. Should I retorque them with loctite to 125 ft lbs?
06-19-2020, 10:14 PM
#118
Real Name: Russell (OB #9908)
You should apply red Loctite then torque them to the spacer manufacturer’s specs.
06-21-2020, 06:37 PM
#119
Scary stuff, I followed everything to a T as well. Correct torque specs, cleaned all contact points prior to installation. Had them on for 2 or 3 years and 20k miles. No issues at all. Occasional retorqueing but nothing has come loose
Sent from my ONEPLUS A6003 using Tapatalk
03-15-2021, 04:36 AM
#120
It problt wasn’t even your studs it’s could’ve been because you bought that specific branded spacers. When it comes to your life money don’t matter
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
