I'm attempting to install a Daystar lift. After reading tons of install posts, it sounds like the best method is where you lower the LCA.
Questions- How hard (if even possible) is it to lower the LCA without lossening the lca to body bolts? Are there some type of springs or washers within the lca to body bolts that would cause tension? I saw some references to using a bottle jack to lower...where would that be wedged?
I'm asking because rust is an issue on my 04 NY T4R & those lca bolts look to be a pia.
Here is the method I'm trying to follow posted by "Galactic 04"...there is a great diagram picture showing the steps. For me, steps 1-3 already loosened, hoping to replace step 4 with jacking or prying of some sort.
Leveled her this weekend
