10-03-2013, 01:56 AM
How to: A/C in console
so a few months ago i got the idea i wanted a way to keep drinks cold when going on trips. so i got to thinking of ways i could buy or make something that was cheap but worked and this is what i came up with.
closed
open
back side
things you need a PVC bushing, a drain plug, and a whole saw
Step one: remove console from truck
Step two: disassemble console so you have just the main compartment tub and A/C vent
Step three: separate tub and A/C duct
Step four: locate the location your going to drill the whole in the console tun
Step five: cut hole in console with whole saw
Step six: remove whole saw from main drill bit
Step seven: reassemble console tub to A/C duct
Step eight: take whole saw without main drill bit and insert into the hole and cut into A/C duct by hand
Step nine: clean up holes drilled and insert pvc bushing
Step ten: cut pvc bushing to desired length( i took the drain plug and inserted it into the bushing and put it all in a drill press and cut with metal lathe tool to make chamfer
Step eleven: put everything back together
Step twelve: if you want you can insulate the console or add Styrofoam divider to console
when all done you can close all A/C vents and open the one in the console and keep your drinks cold
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
10-04-2013, 09:32 AM
.................nice mod
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
Reason: seen what i was looking 4
10-04-2013, 06:19 PM
Originally Posted by earthrealm
more pics please.................nice mod
what would you like pictures of?
nice thing about this mod is drinks stay in low 30's and i think if you insulate you might get stuff to freeze. cheaper then arb fridge
10-06-2013, 08:28 PM
Real Name: Brad
Real Name: Brad
Interesting mod. However only problem with it is You need to keep the A/C going to keep the compartment cold.
You can actually make your center console a cooler by installing thermo-electric devices, which are fairly cheap, and easier to control.
Peltier Thermo-Electric Cooling Module 6 Amp 320-253
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
10-06-2013, 08:36 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
Can you elaborate? this would be sweet in the bottom of a cup holder.
edit, looks like it needs a heat sink which would be a PITA under the cup holder, too much cutting
10-06-2013, 10:08 PM
yes i could do this but my mod was less then half that cost so thats what i did
10-06-2013, 10:25 PM
Wholly crap, that's brilliant!
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
10-06-2013, 10:27 PM
so what would you do about the heat from one of these? you could not have both in the console
10-06-2013, 11:45 PM
Real Name: Sam
Real Name: Sam
GET OUT OF MY HEAD. I've been thinking about doing this and routing to the cup holders. Nice mod.
10-07-2013, 12:04 AM
its an easy cheap mod and could be done with the cup holders. fir that i would use tubes to each side of the cup holders
i also get a lot of questions about it when i have people in my truck. fun to tell people that not only do you have heated seats but you can cool drinks
10-07-2013, 12:05 AM
Real Name: Sam
Real Name: Sam
thats what i was thinking, should be easy because the vent tubing is right there. could easily make it slide into that tubing.
10-07-2013, 12:54 AM
do it
10-22-2013, 02:25 AM
I'm really confused on this. Is there a pic from further back? Can't tell where this is.
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
11-19-2013, 10:52 PM
its the back wall of the center console
11-20-2013, 12:06 AM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
Instead of removing the whole console couldnt you just pop the back off and access the AC duct from there and drill into the back?
