10-06-2013, 03:07 PM
Real Name: Marcin
Real Name: Marcin
Battery/Alternator issues
So I accidentaly left my lights on last night and the auto shut off feature didn't work for some reason.
I drove to a restaurant with some friends (4 miles). On the way back my battery indicator started going off and a couple minutes later all the warning lights started going nuts, the headlights dimmed and radio turned off, then the RPMs started dropping so I pulled over and the 4runner died. I started it a couple of minutes later and drove a mile home, then it died in front of my house.
Could this be a case of a bad alternator or a bad battery, or something else?
Thanks for your help ahead of time.
2004 SR5
Front 2.5" HD OME springs and FJ shocks, rear 3"
Nitto Terra Graplers 265 70 17
NWTI Steel plate bumper with ENGO winch
Stock Rims powder coated matte black
10-06-2013, 03:13 PM
Real Name: Marcin
Real Name: Marcin
to add:
i have a subwoofer system with a capacitor, it shows a full 12v.
2004 SR5
10-06-2013, 03:17 PM
Do you have a battery charger? Also try another spare battery?
My Divemoblie 4runner
2005 Toyota 4runner V6 SR5
10-06-2013, 03:19 PM
Real Name: Marcin
Real Name: Marcin
i'm about to go get one.
should i just take the battery and have it tested?
also, how do you check the alternator?
2004 SR5
10-06-2013, 03:21 PM
It doesn't seem like the alternator is blown since all you did was forgot to turn off the headlights. If you were running the car, and you pulled one of the battery connector, then the alternator would be fried. I suggest taking the old battery and see if its good, get a new one and connect it in to see if it runs. Narrow down the checklist.
10-06-2013, 03:32 PM
Real Name: Marcin
Real Name: Marcin
will do.
i'm just confused by two things.
why would the battery not charge while driving, and why would the engine die when there's no power, shouldn't it just run off the alternator if the battery is bad?
2004 SR5
10-06-2013, 07:49 PM
Real Name: Marcin
Real Name: Marcin
so i charged the battery and it's fine.
but when i start the 4runner the battery light shows up.
looks like a bad alternator at this point.
what do u guys think?
2004 SR5
10-06-2013, 07:58 PM
before you start replacing anything get it tested. Most the chain part stores will test the alternator/battery for free. This will give us more info to work with. I also wonder if any of your battery -> alternator wires are disconnected/corroded/falling apart.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
10-06-2013, 08:00 PM
also is that the original Panasonic battery?
10-06-2013, 09:32 PM
Real Name: Marcin
Real Name: Marcin
got the battery tested, it's fine.
i'm taking it to s shop tomorrow to do the lift anyway (too many seized bolts to do it without shop tools).
i'll let you guys know what the issue was.
2004 SR5
10-06-2013, 10:36 PM
have you check the alt-s fuse ? its in the engine compartment. check some fuses first.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
10-11-2013, 02:15 AM
Real Name: Marcin
Real Name: Marcin
it was the alternator, should've known.
you should always check all the connections before replacing the alternator though. i'm glad i got a good mechanic.
i gave her a front lift too.
2004 SR5
10-11-2013, 05:15 PM
so is it the big fuse or the little fuse?
10-13-2013, 01:48 PM
Real Name: Marcin
Real Name: Marcin
the fuses were fine. just the alternator decided to quit.
2004 SR5
10-14-2013, 12:00 PM
I was gonna say the alternator is bad. I had the same thing happened to me and it was the alternator that was bad.
