10-07-2013, 02:29 PM
Xreas and warranty timing out
I have about 10K left on my 100k warranty.
Can Toyota service to inspect for issues (early leaks wear) or are issues either there or not with this suspension?
2007' V6 SE 4WD PIAA 520's.
Yakima Load Warrior
Michelin LTX M/S 265 65 17
Westin Bull Bar Weathertech Mats
Bilsteins 5100's
10-07-2013, 03:29 PM
Either the struts are leaking or they aren't.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
10-07-2013, 04:00 PM
Exactly. Once they start leaking it is an expensive repair if you stay with xreas. Or you just yank the system and install a traditional shock system.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
10-08-2013, 12:14 AM
Real Name: Ed
Real Name: Ed
Call in for an appointment and say your truck is riding weird. Obviously they will look at the shocks and see the leak (IF they are leaking). Since its under warranty, it should be replaced free of charge! If all is fine, cool, BUT expect them to fail. They eventually do. Although I've seen some with their 4R go until 150,000 without any problems. I replaced my XREAS a few months back (all 4 shocks) and it was expensive. $1100 IIRC. My warranty had run out several months BEFORE the leak was discovered at Toyota.
Good luck
10-08-2013, 12:22 AM
Most warranty companies consider shocks/struts to be a wear item like brake pads and therefore aren't covered. Call and find out first to see if they're even covered by your company.
10-08-2013, 12:34 AM
Real Name: Ed
Real Name: Ed
I'm assuming he has some Toyota Platinum warranty. If he doesn't, then most likely no. Pretty sure the XREAS shocks are covered (by the extended warranty Toyota offers).
Some threads for reference:
http://www.toyota-4runner.org/proble...tml#post334657
http://www.toyota-4runner.org/proble...tml#post245598
10-08-2013, 12:49 AM
That's really surprising. Good for Toyota, in that case anyways. Most aftermarket ones will not tho.
10-08-2013, 08:49 AM
Thanks for the information. I have the platinum warranty from Toyota. We had a group buy here some years ago. Will check with the dealer to ensure coverage and take your suggestions.
Thanks again!
Yakima Load Warrior
Bilsteins 5100's
10-21-2013, 02:53 PM
So at oil change the tech noticed the left front strut is leaking. from all I have read it's covered under the platinum warranty. Called them back and waiting for the information from this dealer. May have dodged a bullet.
Yakima Load Warrior
Bilsteins 5100's
10-21-2013, 03:31 PM
Dealer says Left strut gets replaced and if others appear to be failing they will replace those as well under the warranty. He said it's rare that the whole system fails usually one front and one rear.
Yakima Load Warrior
Bilsteins 5100's
10-21-2013, 05:02 PM
Real Name: Armando
Real Name: Armando
Someone correct me if I'm wrong...but I think Toyota recommends replacing XREAS in pairs?
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
10-21-2013, 07:06 PM
I asked the service guy this question. He explained that the bottom of the XREAS system is intact however the top of the shock is leaking so and accordingly only the shock that has the leak needs to be replaced and since it is not leaking from the XREAS component chamber the system is ok.
Thoughts?
Yakima Load Warrior
Bilsteins 5100's
10-21-2013, 08:11 PM
Thoughts?
Seems like the older shock could be soft and the new one firmer, which could lead to a non-ideal ride experience, but I don't really know.
2008 SE V6 4x4, Bilstein 5100's (1.75 in front), FJ springs, Cornfed 1" rear spacer, SCS Stealth 6, Toyo OC AT2 265/70/17, HID 4300k, Plasti-Dip front grill, Flowmaster 50 SUV
10-21-2013, 08:12 PM
I had not noticed that to any degree as yet. Thanks.
Yakima Load Warrior
Bilsteins 5100's
10-21-2013, 08:13 PM
Agreed. I also thought that the XREAS system was a sealed system and that you can't replace just one shock.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
