10-08-2013, 01:03 PM
30-40 and 65-75mph cyclical moan
so i have this cyclical moan, i can feel and slightly hear it between 30-40 mph and between 65-75 mph seems worst around 67mph
it tends to be a moan and slight gas peddle vibration, no steering wheel shake at all, almost like a harmonic moan at 1 sec. intervals
driving me crazy, cause it's steady as a rock at 50 mph, below 30 mph and above 72mph
I do need and stab bar end link which I am replacing, i'm gonna try rotating the tires (prob to no avail)
any ideas? I had new tires put on but i have no steering wheel shake, could it be balancing?
10-08-2013, 02:12 PM
Harmonic vibration of the drivetrain, probably the front diff:
Driveline Drone on the Freeway - Toyota 120 Platforms Forum
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
10-08-2013, 02:57 PM
what i don't get is this just started at 155,00 Miles
10-08-2013, 03:12 PM
You're lucky. Mine started within 20k.
10-08-2013, 03:27 PM
so i sort of have the same problem but no shaking and it starts at 1mph lol...hopefully its some kind of bearing in the driveline...ive been looking to grease everything up but my drivelines are all sealed up i guess.
can anyone tell me if there have been problems with input and output shaft bearing problems from the diff or transmission?
10-08-2013, 03:34 PM
Wheel bearing gone bad?
10-08-2013, 03:49 PM
i changed out the front bearings and still sounds the same...could be rear i suppose but when it was on the lift i put it in drive and listened and it was coming from the driveline but the sound could be from anywhere and just traveling up the shaft.
10-08-2013, 05:44 PM
SureShot, I'm going with wheel bearings. Have they been replaced?
Mine produced similar symptoms, and the fronts made noise in the lower range And the rear was higher speed. Speed ranges were similar for mine.
Can you get the sound to change by swaying the truck left and right a bit while driving? This may help isolate the noise to a side. It
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
10-08-2013, 08:29 PM
no the sound does not change when i sway from side to side and the steering wheel does not shake at all...however the sound gets louder as there is throttle but when i let off of the gas the sound dies down which is why i think its the drive shaft bearings.
10-09-2013, 08:25 AM
The sound that I have is only evident under constant throttle, like with the cruise control engaged on a flat stretch of highway. As soon as I step on the gas or let off the gas, it goes away.
10-09-2013, 09:43 AM
Mine starts at exactly 63mph and stops around 71mph it happens in cruise control, foot on gas without cruise, and when you let off the gas as it passes that speed range
if i put it in 4th gear it will start once it hits the same 63mph even though RPM's are now higher, you can feel it ever so slightly in the gas peddle and it's a very tight/close feeling vibration/pulse and with the windows up and radio off sounds like a subtle "womp.... womp.....womp.....womp"
10-09-2013, 11:11 AM
Another vote for wheel bearings.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
10-09-2013, 12:50 PM
correction i'm at 115,00 not 150K
Wheel bearings expensive?? i have full time 4WD
10-09-2013, 01:04 PM
Wouldn't a bearing be a constant at other speeds not just at 65-70 mph?
10-09-2013, 11:31 PM
Real Name: Kris
Real Name: Kris
Just had my driver side bearing replaced at 48k. Had the same noise going 45-55 mph and then again at 65+. It was covered by the certified warranty so I paid nothing. Noise Went away after it was replaced. There is a vendor here that sells bearings or you can try bluepitbearings.com
Good luck.
2016 Trail Edition Premium
KF5UXO
