10-28-2013, 04:49 AM
4th gen dash removal and AC repair
Sorry for not using the search function, I am on deployment and anyone in the Navy that has been out to sea trying to use the ships internet can tell you its like back in the dial up days with AOL.
Is there a how to for dash removal? if so can someone point me in the right direction? My wife emailed me and said the AC went out in the 4runner. She had it looked at and the tech said that is leaking from whatever is under the dash. She can drive our other car until I get back in December. I want to replace all the parts my self then have it filled so I don't have to fork over 800 dollars.
Thanks for any input on this subject!
2005 Toyota 4Runner, Sport Edition, 4x4, 4.7 V8...the wifey's ride.
After my upcoming 10 month deployment...Race Red SVT Raptor Supercrew with all the goodies!
10-28-2013, 08:19 AM
Real Name: Matt
Real Name: Matt
I don't know of any 'how-to's' for the dash removal here's the running thread on cracked dash issues and a member posted up pictures of the disassembly process starting at post #150 on page 10.
Dash removal
It's not a difficult process but it's time consuming and will require removing the entire front interior. Here's a pic of the removed dash that will be a good reference for attachment points:
And last but not least - Thank you for your service!
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
10-28-2013, 09:58 AM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
10-28-2013, 12:08 PM
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
10-29-2013, 02:07 AM
Thank you everyone and thanks for the instructions!
11-01-2013, 02:05 AM
When I do the repairs, I will try and take pics and write up a how to. Do I need to remove the steering wheel?
11-01-2013, 07:38 AM
Yes I know the steering wheel had to come off and I think we had to drop the column to get the dash / dash support out. If you have the factory shop manual they actually have excellent directions, if not PM me your email address.
11-01-2013, 08:21 AM
Thanks for all the help!
04-20-2015, 08:51 AM
WAITING FOR THE write up and links you promised am in the same boat now.....searched youtube no hits
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
07-02-2015, 04:54 PM
anyone ever find a guide?
02-24-2016, 01:32 PM
Thanks!
Thanks for your time guys, this made my day!!
Peace
02-24-2016, 01:39 PM
I tried to get the blower assembly out by just removing the glove box and the right side "things blocking my view", but no luck. That top bolt in the blower box assembly can't be reached without the dash out.
I'm attempting to replace my blend door actuator. Get an annoying grind/clicking sound (the famous one) at random times. Vent controls don't move the air to the defrost or floor with any force, so most of the air stays via the vents. I was able to verify that it's the blend door motor when I pulled things apart the other day.
Whew,,,, looks like a fun job... not sure when I'll tackle it, but when I do, I plan to video it for Youtube.
06-01-2020, 07:13 PM
I just removed my dash to replace the evaporator core. Let me tell you this job was no joke. Taking apart wasn't to bad but I didn't do a good job of pictures/videos to help me out. I had the dash on twice now and just took it off again to help connect some harnesses that I miss. I'm kind of at at loss now. I was hoping someone might be able to help me with two harnesses that I can seem to figure out where they go too or any at all. The harnesses are right next to the ECU module. A white connector that I am feeling pretty confident that is not being used based on the way it's taped and I actually found two more connectors that wasn't used. The other black connecter I'm not to sure of since it's pretty loose but cannot for the life of me find where it goes. I'm guessing that wasn't an uncommon thing like I thought it was. Below are pictures of the harnesses. I plan on creating a more lengthy post later of the dash removal as for I have not found much information on it. The only issue I had once i got it back together was the airbag light on the driver side came on and the auto window down for the driver's side wouldn't work. But from what I read those may need to be reset?
06-01-2020, 08:37 PM
Real Name: Skip
Real Name: Skip
No photos are showing up for me.
2004 Limited V8
