11-17-2013, 07:19 PM
Real Name: Maharshee Patel
Hydro-locked help
So I drove through a 6-8inch puddle like I normally would and you guys can probably assume the rest. So now im looking at used engines and i was wondering to those of you if any that have gotten engines put in how mush should I expect to be paying?
2014 4runner Limited Attitude Black Metallic 55W 5000K TheRetrofitSource Morimoto HID
2006 Subraru WRX Limited STI swapped and fully built
2007 4runner SR5 4WD V6 55w 4300K Morimoto Xenons, Morimoto 90mm Halo's, Blacked out trim, Plasti Dipped Wheels, Nitto Terra Grapplers 265/70/17(R.I.P)
2008 Nissan Sentra SER Spec-V (Sold)
11-17-2013, 07:30 PM
I am confused how you hydro locked on a 6-8" puddle?
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
11-17-2013, 07:35 PM
Real Name: Chris
Real Name: Chris
Me too, I've run plenty in lots of water and never had any issues.
Chris - '07 SR5
‘05 Limited - sold
11-17-2013, 07:36 PM
I probably went to fast and it might have been deeper
11-17-2013, 07:38 PM
You 100% it hydro locked and some shop isn't trying to take you for a ride?
Figure $4-6k for used block installed.
11-17-2013, 07:39 PM
Real Name: Jake
Real Name: Jake
I did the exact same thing. Normal puddle on the side of the road, drove through it and water sprayed up into my intake. Got about a gallon straight into the intake and shot a rod out the side of the block.
As for repairs, mine was covered under comprehensive insurance, but I believe the bill for a used motor with 45,000 miles installed with all new components (water pump, spark plugs etc) was $4500 from a local shop. If you do the work yourself, expect to pay around $2000 for a good engine and then add a few hundred for new parts. Another tip is to be very careful when buying an engine, as there are a few different 1GR'S that are very similar. I got the wrong engine three times and it took the Toyota dealer over a month to figure that out.
Good luck, I know how much this sucks, such a harmless puddle that can do so much damage
11-17-2013, 09:57 PM
Thanks im having it towed tomorrow so we shall find out what happens soon
11-17-2013, 10:42 PM
sorry to hear that man. I did something similar about a month ago...went through a puddle at WOT and sucked up a good amount of water. Hope all goes will getting it sorted out.
2003 SR5 4WD: V8 TRD Supercharged, TRD Headers, ARB Bull Bar, CBI Rear, OME 886 coils w/ 1/4'' Spacer, AllPro 3.5's w/1.5 DS, 5100's, 285 Cooper STT, Slee SS Brake Lines, Custom Sway Bar Links, 4xInnovations Sliders, AllPro Lower Links, DDM HID's, 30" Light Bar/Duallys, Safari Snorkel, Custom Y-Pipe, Magnaflow, BudBuilt, KurtFab Diff-Brace, Wet Okole's, JL Sub/Amp, KCCO
sorry to hear that man. I did something similar about a month ago...went through a puddle at WOT and sucked up a good amount of water. Hope all goes well getting it sorted out.
11-17-2013, 10:46 PM
Can someone explain how a "puddle" on the side of the road is taking out one of the most capable off road vehicles left and right....? I call shenanigans on something - either the size of said "puddles", or them hydrolocking the engines or something... Don't our intakes have a bypass valve of some sort at least too?
Think of all the off road videos and clips of dudes going through much more then "puddles":
Point being - don't make me scared to drive my Runner like it was meant to be driven - with ease none the less.
(At least I don't want this to be true!)
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
11-17-2013, 11:23 PM
The intake is right above the passenger wheel well so if the splash is too large in the water goes
11-17-2013, 11:30 PM
Real Name: Chris
Real Name: Chris
Yeah, I've been through plenty of deep water but these posts make me wonder too.m
Could the WOT be the determining factor?
Chris - '07 SR5
‘05 Limited - sold
11-17-2013, 11:50 PM
Real Name: Jake
Real Name: Jake
Im wondering the same thing. Mine was WOT or at least close. I also have my trimmed fender liners to blame Im sure.
11-17-2013, 11:52 PM
Sorry, what's WOT?
EDIT: wide open throttle?
11-18-2013, 12:59 AM
The issue isn't the trucks. Toyota did a greatjob of installing intake that makes it very hard for this to happen.
First day I was 16, Dad took me to DMV. It was storming...had to drive through a large puddle.
Wanna know what my genius father said? Go slow. Driving fast will create a high pressure wave that can force itself into the engine.
Seems like some folks missed this one. Offroad doesn't mean its a submarine.
