11-18-2013, 10:16 AM
A/C kicking off?? Knob light flashing??
I have a 03 V8. A few times this year the ac has stopped blowing cold and the light on the knob flashes. Still blows but not cold. Turn it off and back on and it works. Any one else had this problem???
2003 4Runner SR5 V8 AWD + Daystar 2.5/1.5 + FJ Swap + Definity Dakota 285/75r16 MT's
2014 Taco 6spd TRD OR billies/dakar HD pack/33's
11-18-2013, 10:38 AM
Real Name: John
Real Name: John
I did as well, do a search and you will find the problem will most likely be the relay located in the engine compartment fuse box. To test it you can try swapping if with the fog relay and see if that fixes your problem. From some mods I did I had a couple of relays laying around so I swapped mine with one of those and haven't had a problem since. I plan on eventually buying a couple of spares from here. Good luck.
Amazon.com: Four Seasons 35874 Standard Relay: Automotive
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
11-18-2013, 11:13 AM
thx brother.....
a few bucks cheaper shipped (to my zip anyways) on RA
http://www.rockauto.com/catalog/cata...+AIRTEX+1R1696
11-18-2013, 11:31 AM
Real Name: John
Real Name: John
Thank you, I am bookmarking that link!
