Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 03-19-2014, 04:32 PM #46
HokieRunner's Avatar
HokieRunner HokieRunner is offline
Real Name: Matt
HokieRunner will become famous soon enough
Real Name: Matt
Originally Posted by gaterose View Post
That's a sweet box! I've been tossing around the idea of a new cargo box (especially after seeing Jeff's latest rendition) for mine so I thought I'd throw some of my ideas your way.
Didn't see any mention (may have glossed over it) of the carpet. It might not be a bad idea to remove the carpet if you want to gain all possible space and keep it as low as possible. There is 3/4-1" of padding/carpet under there. Since you're already soundproofed, the box should absorb most of the other road noise the carpet and padding are stopping.
Also possibly use a thinner or almost baseless (just strips where the floor is lower and where it bolts down) base board. The base doesn't really support a lot weight since it's just sandwiched between the box frame and the cargo floor, and mostly acts to keep the vertical boards parallel.
You may not like those ideas, but they are things I've had in my mind based on my needs and previous experience with 2 other boxes I built before going to my current minimalist setup. SO I thought I'd mention em.
The main reason I couldn't make a box work was that it was the height. Dogs hated it; their heads were almost touching the roof, this hatred was multiplied on uneven terrain like trails or dirt roads. The raised floor also makes the "wall" separating the cargo box from the rear seat lower which seemed to make them uneasy. Especially since they couldn't 'hang on' to the stiff wood top as well as padded carpet.
Also, I used 5/8" BC sanded Pine for my entire box and was happy with it but planned replace several pieces with 1/2" and possibly some 1/4" in spots. Mostly the bottom and drawers, I'd rather keep 5/8" for the uprights and the top so that I don't have to worry about their strength under heavy-ish loads.
Thanks Matt - funny enough was just looking at your cargo build earlier. Definitely got some good ideas off it as well. Good call on the carpeting removal. I couldn't remember exactly what was under there but I had planned on pulling most of it. As for the baseboard, initial plans were to use a thinner baseboard and do cutouts under a portion of the drawer area for weight savings. My only concern was how to adequately address any lateral forces on the uprights so I hadn't figured out how much to cut out. This was another idea I 'borrowed' from Dusty's build.
Good point on the dogs. I had my dog in the back the other day while I was taking measurements to see how tall I could make the box without cramping his headroom. My neighbors probably already think I'm crazy so I'm sure they thought nothing of me tape measuring the height of the dog in the truck haha. That's kind of the tipping point on removing the wheel wells. I think just an inch or two height difference will make or break it for the dogs and still afford me the required storage space AND a totally flat cargo deck. But we'll see. As most projects go - the best laid plans can get turned to garbage in an instant.
I just sourced 1/2" baltic birch locally for a decent price in 5'X5' sheets so I need to see if they'll fit my design templates for all the cuts I need. The local vendor knew his stuff regarding it's strength and feels it would be more than adequate for a box fitting my design.
Loving all these great suggestions - thanks guys!
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
HokieRunner is offline   Reply With QuoteReply With Quote
Old 03-19-2014, 05:40 PM #47
Dusty Driftwood's Avatar
Dusty Driftwood Dusty Driftwood is offline
Real Name: Jeff
Dusty Driftwood will become famous soon enough
Real Name: Jeff
Originally Posted by HokieRunner View Post
Where did you use the 1/2" versus the 3/4"? !
Similar to gaterose, think thinner material for horizontal parts and thicker material for vertical parts. This helped cut down on height, or increase storage:height ratio for the same size exterior shell.
I used 3/4" vertical pieces so I had some good meat to anchor the thinner horizontal pieces to. I hadn't considered removing the carpet, but you already know my thoughts on keeping the interior in tact. With the right design, I'm sure you could solve all problems you're facing with this build. It just take a little time and a lot of graph paper...
2013 Knight's Armor Pearl GX460 Premium "Grace"
2007 Nautical Blue Metalic SR5 4X4 V6 "Carl"
SOLD: 2008 Driftwood Pearl SR5 4X4 V6 "Dusty"
Dusty's Cargo Drawers
Dusty Driftwood is offline   Reply With QuoteReply With Quote
Old 04-07-2014, 08:47 AM #48
Real Name: Matt
Real Name: Matt
Light Racing UCA out - Desert Racing Uniballs IN.
Finally had a chance to swap in the new UCAs. The passenger side Light Racing balljoint was shot after 12k and 10mos. Driver side was in ok shape. Both light racing boots appeared to be well sealed and were undamaged so unless you tested the ball joint or pulled the boot, there'd be no way to tell from the exterior. I have no idea how or when the PS boot was contaminated but the ball joint had excessive play and a ton of corrosion. Both ball joints were brand new when I installed them last spring.
I highly recommend that anyone with Light Racing UCAs frequently check and re-grease the ball joints and boots. Needless to say, I'm done with SPC and Light Racing after having to swap out the sleeves for the bushing configuration re-design and now this. All in less than 1 year and 12k miles. I know plenty of people run them and are happy but my experience has been a headache. Those 12k miles were mostly on road with several hundred miles off road.
Enter the new Desert Racing uniball UCA's from Down South Motorsports. Thanks to @ebg18t for the details on the Desert Racing arms.
Install was straight-forward and they come with 1" stainless steel uniballs and 3 degrees built in caster. The front end is nice and tight again and no squeaks or loud noise issues that some folks have with uniballs. Use a quality grease when installing the bushings and you shouldn't have an issue. I only use the Energy Suspension white grease. It sticks to everything but won't wash out or break down for a long time.
Also swapped out the rear pads and rotors with NAPA ultra premium rotors and AdaptiveOne pads. Been running these on the front for 45k miles and they've performed well.
DIY writeup for the rear rotors and pads
Made a shift knob out of one of my broken hockey sticks the other day.
Saved this small snapper out of the road too...was really tempted to make some turtle soup but my girlfriend wouldn't let me keep him hahaha
Last but not least...got my hobart handler 140! Lots of projects coming up with this now on hand. Thanks to Josh @Whitson_Metalworks for all the help on picking a welder and getting set up. Should definitely keep me busy!
Old 04-07-2014, 06:25 PM #49
ebg18t ebg18t is offline
ebg18t is on a distinguished road
I think you will really like the DSM/Desert Products UCA. They are beefy and well made. Glad you are using a safer product now.
I bought the Redline synthetic grease from Amazon for my grease gun. Works excellent on these poly bushings.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 04-12-2014, 10:31 PM #50
Stuck CAPS's Avatar
Stuck CAPS Stuck CAPS is offline
Real Name: Alex
Stuck CAPS is on a distinguished road
Stuck CAPS's Avatar
Real Name: Alex
I really like your cargo drawer design. IF you have some extra space on that passenger side, go get a cheap geiger counter, pull it apart and fit that in there! That'd be cool ;D
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
-Helpful DIY Videos
Stuck CAPS is offline   Reply With QuoteReply With Quote
Old 04-16-2014, 12:53 PM #51
Ryanmb21 Ryanmb21 is offline
Ryanmb21 is an unknown quantity at this point
Really great build and fantastic writeups. I want to follow your lead on the bussman wiring setup. Thanks!
Ryanmb21 is offline   Reply With QuoteReply With Quote
Old 04-18-2014, 11:12 AM #52
Real Name: Matt
Real Name: Matt
I'm loving them so far! Easy to keep clean and a noticeable improvement from the old UCAs. Super quiet too. Redline CV-2 looks like good stuff - wonder if it's compatible with other moly greases? Currently running the Energy suspension grease on all the poly bushings and mobil1 synthetic for the driveline. I'll have to try it when I run out of the current stuff if it's compatible.
Thanks! I've tried to incorporate everything I'll be using on a frequent basis. The geiger counter would be neat but in keeping with my build philosophy of using everything I add...well, I feel like I'd be inviting disaster by adding one!
Appreciate it! Hope to make a bit more progress soon but I've been slowed down lately with back to back hockey injuries (concussion then a separated shoulder). Then just this week the cam seals on the 4Runner decided to take a dump. So it's been at the shop getting new seals and an alignment. Needless to say, hopefully all my 2014 bad luck is out of the way!
Fun fact on the 2005+ VVTi V8 motors...to replace the cam seals, the cams have to be R&R'd. Not the quickest repair job!
Old 04-18-2014, 02:12 PM #53
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
Let's ship over to Chernobyl and do some wheelin'!
-Helpful DIY Videos
Old 05-25-2014, 01:46 PM #54
bugeye1257 bugeye1257 is offline
bugeye1257 is on a distinguished road
Great looking 4runner!
How did you convert the 05 headlights to the 06+ projector ones?
I am looking to do this swap.
bugeye1257 is offline   Reply With QuoteReply With Quote
Old 05-27-2014, 06:09 PM #55
Real Name: Matt
Real Name: Matt
Thanks! To swap the 06 headlights in you just need the 06 housings, different trim (little pieces under the headlights) and you can either splice the light wires or get the 06+ harnesses. The 06 headlights bolt right in.
Old 06-16-2014, 12:43 AM #56
Jonota Jonota is offline
Jonota is on a distinguished road
Where's the secondary air block off plates?
Jonota is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 09:40 AM #57
navin navin is offline
navin is an unknown quantity at this point
btw: I finally got around to doing my HID retrofit on the 06+ housings. If you are ever in the Fairfax area and want to check them out shoot me a PM.
ps. If you ever sell the wheels, let me get first dibs :P
navin is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 09:53 AM #58
Real Name: Matt
Real Name: Matt
The secondary plates are just below the exhaust manifolds on either side of the engine. You can actually make your own with some sheet metal or buy them online. I tried to find some pictures showing the location (somone on t4r posted up some nice shots of them) but no such luck. If you crawl under the truck or look behind the rear-most, removable fender liner in the front wheels you'll be able to see the junction.
Sounds good man! I'm actually waiting on some new black series lenses from TRS so I can mod up the new housings I got and sell the current 06+ blacked out housings. And I'll definitely put you down as first in line for the wheels...but I won't be looking to sell them anytime soon.
Old 06-16-2014, 10:07 AM #59
So you just put a block off plate IN the flow path to the manifolds, and the manifolds still have the air injection tubes?
Old 06-16-2014, 10:41 AM #60
Real Name: Matt
Real Name: Matt
That's correct. you're basically just isolating the secondary air system so that no air goes in or out and the valves cannot get stuck open or closed.
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
Guyduebro's Surf build..De-build Guydudebro 3rd gen T4Rs 3 03-17-2013 08:27 PM
The question: to build or not to build... zoski 3rd gen T4Rs 23 07-24-2012 12:50 AM
