Originally Posted by Nervo19
Are you looking at Destination AT's? I don't own a vehicle with 17" wheels but the '89 4runner below has 31x10.5 x15 AT's on it. The tread is more aggressive than the LT's shown above. My set was cheaper than the Walmart Authority tires I was considering. I was surprised because I got them from an indy dealer who sourced them from NAPA. I don't know that they are the "best" but they are a good value and I have no complaints. They are not noisy which would drive me nuts. For my DD I'm probably going to get Coopers. If not I'll be getting these in a 16" size.
Just to clarify--the tires shown in the picture above are the Destination AT's, but are an LT-rated tire (as opposed to a P-rated tire). If you are getting Destination AT's they will look the same as what's in the picture.
Originally Posted by scottblink23
Thanks a lot! The look of your 4runner is what I'm looking to accomplish with mine. What lift/setup do you have?
I'm running OME 885 springs up front, Toytec Superflex springs in the rear, and Bilstein 5100's all around. The front shocks are set at the stock height, all lift is provided by the springs.
I also have LR upper control arms and some one-off extended sway bar end links in the rear.
