Old 12-20-2013, 10:19 AM #16
scottblink23's Avatar
scottblink23 scottblink23 is offline
Real Name: Scott
scottblink23 is on a distinguished road
Real Name: Scott
After
After
My slow build thread-photo-1-jpg  My slow build thread-photo-2-jpg  My slow build thread-photo-3-jpg  My slow build thread-photo-4-jpg
2006 SR5 4WD | OME Lift (885 + top spacer) w/Superflex Rear Coils | ICON Uniball UCAs | CBI Full Front Bumper | Warn Winch | PIAA 510s | Cooper AT3XLT 295 75 16 | Level 8 Trackers | GOBI Stealth Rack | MJT Satoshi Grille - http://www.toyota-4runner.org/4th-ge...ld-thread.html
scottblink23 is offline   Reply With QuoteReply With Quote
Old 06-08-2014, 03:24 PM #17
Real Name: Scott
Real Name: Scott
Tube Steps
Installed Sport Edition tube steps courtesy of @xpeppyx
My slow build thread-image-jpeg
Old 11-29-2014, 11:59 AM #18
Real Name: Scott
Real Name: Scott
OME Lift Ordered
I finally ordered the OME lift I've been putting off for a long time to replace my Day Star 2.5 1.5.
Hope to install it before Christmas. Toytec includes a trim packer to adjust for any lean but I'm still debating whether I should keep my rear driver's side day star spacer. Any advice? Thanks!
My slow build thread-capture-png
Old 11-29-2014, 01:05 PM #19
Dylan's Avatar
Dylan Dylan is offline
Dylan is on a distinguished road
Dylan's Avatar
Did you go with the AB or C load Destinations? I've had mine about a month now...second set, but first on this runner, and I'm loving them.
2004 SR5 V8 4WD White - Full LED Swap - Pioneer BT Stereo - Lite Racing UCAs - Toytec Bilstein 5100 Front 3"
Superflex Rear 2"- Spidertrax 1.5" - 255/75r17 Destination AT - SS Brake Lines - Prothane Bushings - SE Brake Upgrade - Full Synthetic
1994 SR5 V6 4WD Black - Bilstein HDs - OME 900 - 31" Destination AT
Dylan is offline   Reply With QuoteReply With Quote
Old 11-30-2014, 01:12 AM #20
Real Name: Scott
Real Name: Scott
I have the LT version so they are load C. Great tires.. Quiet, lightweight and the skinnys are fine if you can push them out with spidertrax.
Old 11-30-2014, 12:44 PM #21
Dylan's Avatar
Dylan's Avatar
Nice...that's what I went with. An additional 5lbs per tire hasn't really affected much in the way of MPGs thankfully. Did you have any issues with bearings or CVs with the additionaly weight/circumference?
Old 12-07-2014, 04:32 PM #22
Real Name: Scott
Real Name: Scott
OME Lift Installed
Installed an OME lift yesterday, with help from my brother-in-law. After 6 hours, it was a success! I did break a @&$% ABS sensor line so I'll have to figure out how to get that fixed..
Anyways, the details:
Replaced my Daystar 2.5 / 1.5 with an OME lift:
Up front:
885 Coils
OME Nitro Shocks
.5 Top Spacer
Toytec Diff Drop
In the back:
Toytec Superflex Coils
OME Nitro Shocks
I took before & after measurements from the center cap to fender. Please note, these aren't stock measurements, but measurements going from a Daystar to an OME lift. I was hoping to get an additional 1.5 inches and even when the lift settles, I'm confident I'll be there.
Before w/Daystar 2.5 - Front:
Driver - 21.25
Passenger - 21
Before w/DayStar 1.5 - Rear:
Driver - 22.75
Passenger - 22.75
After w/OME - Front:
Driver - 23.5
Passenger - 23.75
After w/OME - Rear:
Driver - 24
Passenger - 24
So, before things settle, I gained +2.5 inches in the front and 1.25 inches in the rear. Onto the pictures! Oh, I never took pictures when I added the brush guard and Hella lights.
My slow build thread-photo-2-jpg  My slow build thread-photo-5-jpg
Old 12-07-2014, 04:37 PM #23
Real Name: Scott
Real Name: Scott
More Pics - OME
After pics
My slow build thread-img_5144-jpg  My slow build thread-img_5146-jpg  My slow build thread-img_5147-jpg
Old 12-07-2014, 04:39 PM #24
Real Name: Scott
Real Name: Scott
After Pics
More After Pics
My slow build thread-img_5148-jpg  My slow build thread-img_5149-jpg  My slow build thread-img_5145-jpg
Old 12-08-2014, 05:15 PM #25
Real Name: Scott
Real Name: Scott
Alignment
Got an alignment today and the difference is night and day. My 4R is still stiffer with the OME suspension, but it drives so much smoother after an alignment.
I plan on tackling the ABS sensor lines this weekend.
Old 12-08-2014, 05:24 PM #26
NuclearN8's Avatar
NuclearN8 NuclearN8 is offline
NuclearN8 is on a distinguished road
NuclearN8's Avatar
these may help... Broken ABS Speed Sensor Harness Fix
Help!! VSC Trac, VSC Off, & ABS Lights On
Current: 17' GX460 Luxury with DSP, Nightfall Mica / Black
Sold: 05' 4R Sport v6, 07 4R Limited v6
NuclearN8 is offline   Reply With QuoteReply With Quote
Old 12-08-2014, 05:27 PM #27
Real Name: Scott
Real Name: Scott
Originally Posted by NuclearN8 View Post
Thanks a lot man! My plan is to follow the first link's advice and find the break(s), solder the ends and re-wrap in a plastic/rubber tube.
Old 12-08-2014, 06:08 PM #28
jsmith21's Avatar
jsmith21 jsmith21 is offline
Real Name: Jonathan
jsmith21 is on a distinguished road
jsmith21's Avatar
Real Name: Jonathan
How's the ride with 885's? I'm thinking of upgrading to 885's, 886's, or 887's. 886's would probably be too harsh with no bumper yet though.
08 V6 SR5 4WD Nautical Blue Metallic
My Build- http://www.toyota-4runner.org/4th-ge...ld-thread.html
jsmith21 is offline   Reply With QuoteReply With Quote
Old 12-09-2014, 12:00 AM #29
Real Name: Scott
Real Name: Scott
The ride is stiffer but I got the 885s mainly bc I wanted the mad amount of lift plus I'm going to get a Demello bumper sometime in the future. With a v6 I wouldn't go higher than the 885
Old 12-09-2014, 06:34 PM #30
hearno's Avatar
hearno hearno is offline
hearno is on a distinguished road
hearno's Avatar
Looks great with the lift. You gotta knock out the BHLM so they match the rest of the truck.
2014 Trail
A mild build She gone... sad face.
2001 Limited 4x4
hearno is offline   Reply With QuoteReply With Quote
2006 , build , led , slow , thread
Ronin's Slow Build Thread........ Ronin1082 3rd gen T4Rs 7 12-13-2014 09:59 AM
Nate's Slow Build/Mod Thread 02_SE_Runner 3rd gen T4Rs 46 10-12-2014 04:42 PM
SixShooter slow Build thread TheSixShooter 3rd gen T4Rs 6 04-11-2013 04:19 PM
TXTRDTEEJ's Slow Build Thread TexasTRDTeej 3rd gen T4Rs 1 01-20-2013 07:53 PM
Loaf7's Slow Build Thread Loaf7 3rd gen T4Rs 0 11-05-2012 09:29 PM
