Originally Posted by pag04
The blower motor on my '04 is making a loud rumbling type noise. Sounds like the bearings are gone. I've been looking at threads to figure out how how big a job it is to replace this and it seems like it is a real PITA. It seems with earlier models it was just a matter of removing the glovebox. On the '04 it looks like part of the center console has to be removed and some other trim and the glovebox to get the motor out.
Is that right? Has anyone replaced the blower on an '04? How big a job is it?
Thanks.
My was doing the same thing. It is really easy to get out. I found the attached TSB and used it as a guide and while I followed it, I remember I didn't have to take off half of what it said to access the blower motor screws. Stick your head under there, it may be that you don't have to remove anything.
I also didn't follow the instructions for disconnecting the negative battery terminal. Over in that area is the ECU for the transfer case and I guess they are worried that if you damage the ECU or disconnect it while it has power you might fry something else.
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods:
Spoiler,
HIR bulbs,
Kenwood DNX6960 Nav,
Back Window Up with Remote Mod, Rear Camera, LED Tails,
Key Reminder Disable, OEM Automatic Headlights,
Rear USB Ports,
Seat Heaters,
Aftermarket Third Row,
Heated Side View Mirror
Locations: VA
