12-10-2013, 06:47 PM
Alternator or battery?
Hey T4R,
I decided to check my battery voltage this morning and got some....interesting results.
With engine off after a drive voltage is 6.81volts
With engine on voltage is only 7.21 volts.
the odd thing is that my car works perfectly fine. It cranks fine, everything inside works well.
I'm at a loss as to why.
The battery is original, the 4runner is a 2007 with 115k miles on it.
Cheers!
Ryan
12-10-2013, 06:57 PM
I am gonna say either your multimeter is bad or your technique is.
Your car can't start with 7 volts, that is barely half the necessary voltage to make it happen.
So.... if 7 volts isn't enough to start... but the car starts.... what do you think is going on?
12-10-2013, 07:02 PM
this.
you must have been reading the wrong scale or something.
7v wont do it.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
12-10-2013, 07:04 PM
your meter is bad. or how you measuring is wrong. I would like to know how you are doing it. It sounds pretty cool.
12-10-2013, 07:06 PM
I just used the multimeter on my dirtbike and it worked fine (4h ago), the terminals and connectors are clean enough for a good reading. So yeah...... Super confused.
Just decided to recheck the multimeter on my bike's battery...... It's fried
Guess that's what I get for not buying a Fluke
12-10-2013, 07:12 PM
One end on the air intake, the other end in the tailpipe /sarcasm
Battery terminals like normal
The Multi is fried
12-10-2013, 08:41 PM
check the 7.5 amp alt-s fuse in the engine compartment.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
12-10-2013, 09:23 PM
The Multi is fried
actually, meter might have blown a fuse
12-10-2013, 11:47 PM
I think you had the meter leads in the wrong place in the meter and you were set to read amps. Some meter have three places for the leads. You got it crossed and could have taken out the meter or direct shorted the cycle battery if you had in the amp mode.
12-11-2013, 01:07 AM
Nope, didn't happen. It was on DC voltage, 20 volts with the leads in the right space
12-11-2013, 09:59 AM
Registered User
Registered User
On some of the cheaper meters (not saying your is)...if its own battery gets low, it will read incorrectly. (Flukes tell you if the battery is low.)
For example, those meters you can get free (or nearly free) at Harbor Freight with coupon...if the battery inside the meter gets low, it will read incorrectly. Some meters use the internal battery as a reference voltage source, so if it is 'wrong', it will 'read' wrong.
Try replacing the battery inside the meter first before trashing it...
(to be honest...the picture of your meter looks exactly like those given out by Harbor Freight...except the color of the housing and 'manufacturer' label...)
12-11-2013, 04:38 PM
I think there is a +/- 5 VDC give or take on those
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
12-11-2013, 05:00 PM
50LE Multimeter: KELVIN.com
as low as $2.75 if i buy 10 or more, batteries for my fluke 187 costs more than that
12-11-2013, 05:13 PM
Registered User
Registered User
Here's the Harbor Freight special...
7 Function Multimeter
12-11-2013, 05:26 PM
The harbor freight is just as bad, in fact, they probably come from the same crappy chinese factory and are just re-badged.
I had a harbor.. it refused to work right and I ended up buying an actual one from Sears. A real one is 20 bucks and will come from the Chinese factory on the other side of town from a company large enough to ensure quality control.
