Old 12-29-2013, 07:04 PM #1
JeffMerr's Avatar
JeffMerr JeffMerr is offline
JeffMerr is on a distinguished road
JeffMerr's Avatar
Oil recommendation?
I recently purchased an 06 2WD 4runner with 84k. I searched through the oil threads and determined it was best to run 5w-30 full synthetic. When i went to walmart yesterday I didn't realize there were so many different types of Mobile 1 5w-30. There was regular full synthetic, high mileage full synthetic, European full synthetic, and some other green bottled one. Should I go with the high mileage synthetic or just stick with the regular synthetic? What would be the difference? Thanks
JeffMerr is offline   Reply With QuoteReply With Quote
Old 12-29-2013, 07:28 PM #2
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
Id wait until over 100k to switch to high mileage. I have no idea if there really is a difference but i use it and im just barely over 100k.
LTDSC is offline   Reply With QuoteReply With Quote
Old 12-30-2013, 12:38 PM #3
MikeInNH MikeInNH is offline
MikeInNH is on a distinguished road
I've always thought the high-mileage oil is gimmick. I've never used it. Even on vehicles with well over 300k and even 400k miles.
Stick with ANY oil that meets Toyota's oil specs. Which is pretty much every single oil on the market (synthetic and non-synthetic).
Brand name doesn't mean that much. Just make sure you change the oil according to spec and use the recommended viscosity (5w-30 is what's recommended) - and you'll be fine.
MikeInNH is offline   Reply With QuoteReply With Quote
Old 12-30-2013, 08:52 PM #4
flyneco22 flyneco22 is offline
flyneco22 is on a distinguished road
true story IMHO....I've been on the AMSOIL kick since i switched from MOBIL1. Little pricey (9$+ a quart) and sometimes difficult to find but it's done its job for 5k mile intervals on a turbo SRT4 with 2x stock hp.
flyneco22 is offline   Reply With QuoteReply With Quote
Old 12-30-2013, 09:27 PM #5
chitown40's Avatar
chitown40 chitown40 is offline
Real Name: Rob B.
chitown40 is on a distinguished road
chitown40's Avatar
Real Name: Rob B.
You can either take the advice above including using what is spec'd in the owner's manual,
OR
You can go here and over-analyze and micro-scrutinize oil all the way down to the molecular level.
Ok, seriously, the above site has some great info, but just put in good quality 5W-30 oil meeting factory specs. Sale prices should have more affect on your choice than brand name. Oil is already over-priced for what it is and how long it lasts.
2009 GX470 Sport Edition w/ KDSS
chitown40 is offline   Reply With QuoteReply With Quote
Old 12-30-2013, 09:35 PM #6
Tooltime19 Tooltime19 is offline
Tooltime19 is on a distinguished road
I have always used Mobile1 in all my vehicles. Motor Oil, Diff fluid, wheel bearing grease ect. As noted above, with today's technology, It would be hard to find a bad full synthetic. I would stick with a known brand. You can always find "better" high end synthetics if you have the need.
I do use the High Mileage Mobile-1 in all my rigs, and have been for a long time. If you look at the specs and compare to the other series of Mobile-1 on back of the bottle, it states the High Mileage works better in high heat conditions. For me here in the hot dusty dry Southwest, the High Heat protection is something I need. Marketing or not, I use that blend. The price is the same.
I have noticed a slight drop in oil temp on my SRT8 Charger.
I also use this in my T4 & my 02 Sport Trac prerunner.
just my .02 Good Luck
Bilstein 5100's on all four, Eibach/Toytec front coils, OME rear coils, RCI skid plates, 1.25/1.5 wheel spacers front/rear 275/70/17 BFG A/T KO2's, drop in K&N, Cobra CB, Powerslot Slotted Rotors, Hawk HPS pads and Mobile-1 Lubricants throughout.
Tooltime19 is offline   Reply With QuoteReply With Quote
Old 12-30-2013, 09:42 PM #7
lehiguy's Avatar
lehiguy lehiguy is offline
Real Name: Mike Davies
lehiguy is on a distinguished road
lehiguy's Avatar
OR
This is true. How the engine's lubrication system is engineered has far more to do with longevity than the oil. If you were to push 700HP then oil might become more critical. Synthetic is probably overkill, although that's what I use. Gear boxes are a good place to save some fuel by using synthetic to reduce drag. It is far less viscous in the cold than standard gear lube.
If ignorance is bliss, why aren't more people happy?
lehiguy is offline   Reply With QuoteReply With Quote
Old 12-30-2013, 09:51 PM #8
ebg18t ebg18t is offline
ebg18t is on a distinguished road
Yep. There are a ton of good synthetic oils. I have been using the Penzoil platinum or ultra (which ever is on sale) from WalMart with OEM filters. I have sent a few samples into Blackstone for testing and always received good numbers from this oil on this truck. I should go with a longer oil change interval like Blackstone suggested, but I still replace between 5-6k miles.
I stopped using Mobil 1 when they changed the formula some years back. It is still excellent oil, but didn't like how they changed the formula (cheaper formula) and kept the price the same or increased it in some markets. Just didn't sit well with me.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 12-30-2013, 09:56 PM #9
M16A4 M16A4 is offline
M16A4 is on a distinguished road
High mileage isn't needed, I bought my 4runner with 124k and switched it to synthetic (Pennzoil Ultra). Can't go wrong with any oil these days as long you keep it changed.
M16A4 is offline   Reply With QuoteReply With Quote
Old 12-31-2013, 12:58 AM #10
Gecko123 Gecko123 is offline
Gecko123 is on a distinguished road
I agree. Even if it is not a gimmick, how does one define what is high mileage. Even if you can define high mileage, mileage is not the only indication of the engine's condition. You can have a 150K mile engine in better shape than a 100K mile engine.
Key is changing the oil REGULARLY!!! I tend to stick with the old standard which is changing the oil every 5000 KM (3000 miles). I know newer cars you can go longer but I am just use to this old standard. I use regular dino oil, good enough for me.
Gecko123 is offline   Reply With QuoteReply With Quote
Old 12-31-2013, 10:28 AM #11
I agree 100% with that. I do use synthetic. Mainly because I do a lot of towing in the summer (pulling our pop-up). And the cold winters - especially when we go to the white mountains for skiing. I've woke up to many mornings to -20. Synthetic oil is much better for extreme cold weather.
Old 12-31-2013, 10:46 AM #12
I always tell my customers to keep with the factory suggestions regarding the oil weight and viscosity. None of my rigs are over 80k. Yet again, due to the added high heat protection, I use the high mileage product. Im not loyal to any single brand really. It just so happens that I fell into Mobile-1 one day and have been there for a while. Before that, I was using Valvoline.
I too change my oils at 5k no matter what. Just one of those ocd things. Plus, it gets all kinds of hot around vegas in the summer times.
Old 12-31-2013, 12:56 PM #13
SierraDan SierraDan is offline
SierraDan is on a distinguished road
As far as engine oil I like to use the European spec synthetic, i've read American oil isn't what Europeans consider synthetic. A true synthetic is made from Group 1V (or higher) base stocks and quite often are referred to as European formulations. i.e Castrol 0W-30, made in Germany, and available at your local Walmart. Other examples of true synthetics are Amsoil Signature Series and Mobil 1 Extended Performance oil. Any Group 1V or higher is good to use.
As for transmissions and gears, I like Royal Purple, which gives it less rolling resistance and less wear.
Mine: 06 SR5 4x4 V8
Wife: 02 Town & Country 3.8 V6
Also: 99 Suburban K1500, 95 Sierra C1500 305/5spd, 88 Town Car
SierraDan is offline   Reply With QuoteReply With Quote
Old 12-31-2013, 01:43 PM #14
JBecker's Avatar
JBecker JBecker is offline
Real Name: Josh
JBecker is on a distinguished road
JBecker's Avatar
Real Name: Josh
Ah oil threads, what could go wrong? lol
Call me cheap, but I use a Purolator filter and Supertech (Walmart house brand) 5W-30 conventional oil. I change it every 3,000 miles which translates to about every 5-6 months for me, I don't drive much anymore.
My last oil change cost me just under $20.
JBecker is offline   Reply With QuoteReply With Quote
Old 12-31-2013, 02:42 PM #15
Dylan's Avatar
Dylan Dylan is offline
Dylan is on a distinguished road
Dylan's Avatar
I just bought my '04 V8 and did the first oil change since I've had it at about 142K miles. I went with about 6 quarts of Mobil 1 5w-30, full synthetic high mileage.
2004 SR5 V8 4WD White - Full LED Swap - Pioneer BT Stereo - Lite Racing UCAs - Toytec Bilstein 5100 Front 3"
Superflex Rear 2"- Spidertrax 1.5" - 255/75r17 Destination AT - SS Brake Lines - Prothane Bushings - SE Brake Upgrade - Full Synthetic
1994 SR5 V6 4WD Black - Bilstein HDs - OME 900 - 31" Destination AT
Dylan is offline   Reply With QuoteReply With Quote
Tire recommendation wingshootin 5th gen T4Rs 4 06-30-2012 03:28 PM
New spring recommendation? JohnnyReb Classic T4Rs 6 05-06-2012 09:15 PM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
Should I take the dealers recommendation? runnerbuzz 4th Gen T4Rs 5 09-04-2010 09:07 AM
