Old 11-02-2019, 11:51 AM #16
Benny123's Avatar
Benny123 Benny123 is offline
Benny123 is on a distinguished road
Benny123's Avatar
Yeah I probably could have disconnected the drive shaft, but I just didn't feel it was necessary. Plus you open up a whole new can of worms if one of those bolts is rusted or breaks off as well. In the end it's the principle, I already took off the skid plate and the gas tank straps. I shouldn't have to take off the drive shaft to access a single bolt.
Benny123 is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 11:02 PM #17
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
That’s a really good point. Literally EVERYTHING I’ve tried to take apart on this truck has been seized, or just plain sheared off when applying enough torque to get it loose. It’s very frustrating. When I did my calipers after one seized, I couldn’t even change the rubber lines because they were frozen to the hardline fittings. So now I have a brand new set of stainless lines I can’t use. I couldn’t get ANY of them loose, front, or rear without either rounding the fittings, or twisting the hard lines and breaking them. Didn’t want to open that can o’ worms either! I’m going to look at doing what you did next time I’m under there, because I’d rather not have to drop the driveshaft, even though, it shouldn’t be a big deal. From my experience EVERYTHING underneath this truck is a big deal because of rust. It’s really too bad because the rest of the truck is flawless inside and out, but the frame will be the death of it.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 11:15 AM #18
CapitalCityRunner CapitalCityRunner is offline
CapitalCityRunner is on a distinguished road
Originally Posted by Terminator03 View Post
I actually snapped the head off that bolt a couple of weeks back when I had to replace a broken fuel tank strap. I actually broke another on the frame side as well. I had the skid sandblasted and powder coated, so it’s all ready to go back on, but now I need to remove the driveshaft to be able to drill that bolt out and retap the hole. What a crappy design! EVERY bolt was completely rusted into the frame, so I guess I’m lucky only 2 broke. I chased all the holes with a tap, and used new bolts, with anti-seize this time, so hopefully if it ever needs to come down again, it will be easier next time!
Has anyone had trouble after you get the bolt removed? It’s like my skid plate and that bracket are married together, I got the bolt out and I’ve tried prying it apart with a screwdriver but it’s not budging
CapitalCityRunner is offline   Reply With QuoteReply With Quote
Old 05-14-2021, 10:26 AM #19
bigwave bigwave is offline
bigwave is on a distinguished road
How long to remove skid plate
The skid plate in now way holds the gas tank, correct? You can run a 2005 4runner with the skid plate removed, is that correct?
bigwave is offline   Reply With QuoteReply With Quote
Old 05-14-2021, 11:22 AM #20
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Under ordinary conditions, no need for the skid to support. The tank straps hold the tank up.
If your straps are broken/rusted through, the tank will then be supported by the skid.
I've got a write-up on replacing the tank straps with a lot of pictures, that can give you some good part familiarization for the tank, straps, skid, and attachment: Fuel Tank Strap Replacement Tutorial (60+ Pictures)
y=mx+b is offline   Reply With QuoteReply With Quote
Help cut my gas tank skid! 04desertrunner So Cal 7 01-03-2014 02:43 AM
Carnage: Gas tank skid AZTOY Off-Roading 11 07-14-2012 05:36 PM
TE Fuel Tank Skid FlyNavy 5th gen T4Rs 4 05-16-2010 07:45 AM
gas tank skid plate 4th gen 747ifly Classifieds - buy & sell (no commercial ads please) 9 11-28-2009 07:54 PM
F/S 1st Gen Fuel Tank Skid seanlandess Classifieds - buy & sell (no commercial ads please) 0 11-28-2009 04:36 PM
