Originally Posted by BlackWorksInc
Basically one of the Coil on Plug units is bad, I would assume "E" means cylinder 5, so if want you can swap that coil with another one, reset the DTCs and see if the code changes to the corresponding cylinder, thus proving it is indeed the coil pack.
Thanks. I just checked, the connector of ignition coil caused the problem.
