Old 01-07-2014, 11:32 PM #1
Jeremy03Sport Jeremy03Sport is offline
Jeremy03Sport is on a distinguished road
Serpentine Belt Tensioner Replacement w/Photos
I have a 2003 Sport, AWD, V8. Tensioner pulley bearings failed. It was bad long enough that I was unable to just replace the pulley. The shaft on the tensioner was worn. FYI, the pulley is only $20 from auto parts store. To remove, bolt is reverse thread - righty, loosey.
I purchased an aftermarket tensioner from autoparts store for about $55.
To replace:
1. Disconnect ground from battery - 10mm socket
2. Pull front skid plate - 4 bolts, 12mm socket
3. remove plastic engine cover plate - 2 nuts, 10mm socket
4. remove air intake from airbox to engine - loosen 2 clamps on either end with 10mm socket. remove vacuum hoses and set aside
5. remove serpentine belt, if not removed already. use 14mm socket on pulley and pull to left (ccw) to remove tension
6. Next remove the timing belt cover, there are two pieces. The left side has 3 bolts and 1 nut, 10mm (pictured). The right side has 2 bolts, 12mm (not pictured, but just to the right of the tensioner).
Serpentine Belt Tensioner Replacement w/Photos-20140107_195031-jpg
7. Remove tensioner fasteners - 1 bolt and 3 nuts, all 12mm. One nut shares a stud with alternator. (I put arrow by wrong nut, arrow on lowest left nut, should actually point to one just above and to left). The one I'm pointing to is strictly a alternator fastener.
Serpentine Belt Tensioner Replacement w/Photos-20140107_194456-jpg
8. Remove alternator fasteners - 1 bolt (accessed from below), and 1 nut from top side of alternator, both 14mm. The third nut (12mm) is shared with the tensioner and was removed in step 7.
Serpentine Belt Tensioner Replacement w/Photos-20140107_192513-jpg
9. Remove power steering pump fasteners - 2 bolts and 1 nut, all 14mm. Access through the hole in the power steering pulley.
Serpentine Belt Tensioner Replacement w/Photos-20140107_192045-jpg
10. slide power steering pump toward front of vehicle. Slide alternator off stud shared with tensioner. Pull out tensioner.
11. Assemble in reverse.
I have more photos available if more detail is needed.
Jeremy03Sport is offline   Reply With QuoteReply With Quote
Old 09-28-2018, 01:19 PM #2
captaininsano captaininsano is offline
Real Name: Stew Pedazzle
captaininsano is on a distinguished road
This post as well as this recent video post on youtube helped with the install of the new assembly.
https://www.youtube.com/watch?v=jCbXOUcRBLs
https://www.youtube.com/watch?v=hkiSgype2Qk
Took me about 6 hours as the stud that holds the plastic cover on the timing belt threaded off instead of the tophat nut.
I also was able to do the entire replacement without removing the radiator hose and having to mess with the re-fill of the fluid. I will say it would have definitely made things easier.
07 SE, OME BP 51, 275-70/17 BFG KO2s, TRD Pro Wheels.
captaininsano is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 12:24 AM #3
JoeToyota's Avatar
JoeToyota JoeToyota is offline
JoeToyota is on a distinguished road
JoeToyota's Avatar
I also just used this post as reference. Was a lot of help. Solid pictures.
Chirping at idle was my issue. Previous owner had replaced serpentine belt about 7k miles ago for the same reason. Turns out the tensioner was the original issue.
I was able to do %99 of the work from the top. I only was below the car to remove the shield and remove the bottom alternator bolt, then to tighten that lower bolt upon reinstalling and replacing the shield. I did not open the cooling system. I've got long arms though.
The friggen top-hat nut gave me a bit of grief. I just left it stuck and continued turning until the stud came out of the block. From there I was able to work around the timing belt cover by just shifting it. Without that top-hat nut getting stuck I could have gotten close to 2 hours work time..
Took me 2 hours 40 mins in my garage which is about 0F right now and no power tools. Seemed like a terrible job upon researching. If you can work in tight spaces with your hands, then with this write-up you will get it done in no time.
2006 4Runner Sport V8
JoeToyota is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 09:08 PM #4
Swimupstream Swimupstream is offline
Swimupstream is on a distinguished road
Thanks for all this gang. Anybody know of any of the same for a 4th gen V6? Can't find a stinking thing. Hope I'm just looking past it.
Got no problem giving it a shot, but I know, like you said, might save me a couple struggle points by reading ahead and getting to my cocktail early enough!
2005 4R SR5, 4WD V6
Clearly I'm not a motorhead, like spending as little as possible, but don't mind working and trying new things.
Swimupstream is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 05:03 PM #5
grocery_getter grocery_getter is offline
grocery_getter is on a distinguished road
I've removed the bolts to the p.s. pump and can't get the dam thing to budge. I was tempted to bang it woth a 4lb hammer bit dont want to damage the pulley. Any suggestions?
I know this thread is dead but I figured it give it a shot.
grocery_getter is offline   Reply With QuoteReply With Quote
Idler Pulley and Belt Tensioner Replacement Bearing Sizes tjhaf2007 4th Gen T4Rs 29 12-16-2018 04:59 PM
Serpentine Belt Replacement 04 V-6 Boaz Maintenance/Detailing 55 04-22-2012 01:49 PM
Need help with 3.0 Timing Belt replacement (photos) AKcharger Maintenance/Detailing 0 05-15-2011 06:04 AM
4.0 V6 - serpentine belt tensioner? bxc13 Problems & Warranty Issues 2 09-13-2008 11:46 AM
03 V6 replacement serpentine belt part number RkyMtHgh Maintenance/Detailing 3 03-02-2007 08:33 AM
