Old 01-24-2018, 12:26 PM #406
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
JBL owners,did the install, went fairly smooth but I’m experiencing the volume fluctuation issues. I’m using the metra TYTO. Did anybody use an LOC, or is there a requirement to turn the volume up on the old system before installation of the new HU? My understanding is that was an issue on The PAC but not Metra.
Also, I have the new scion HU, and I also have a NAV module. I had the exact same setup on a non-JBL non-nav 4Runner and had zero issues with the nav, but on my non-nav JBL 4runner the nav just seems confused. The nav follows in general areas but is never pointing the right direction or on the actual road I’m on. It just lags into the general area.
Any ideas?
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 12:59 PM #407
SoSoRunner's Avatar
SoSoRunner SoSoRunner is offline
Real Name: SoSo
SoSoRunner is on a distinguished road
SoSoRunner's Avatar
Real Name: SoSo
Just picked up a PT546-00140 for pretty cheap and I'm gathering up the harnesses to hook it up. Does anyone know if this is the Y adapter for the duel antenna (HD radio)?
UPDATEThis is the Y adapter and you also need a end conversion link below also.
https://www.amazon.com/Metra-40-UV43...Y33Q49MDAHN3TF
https://www.amazon.com/gp/product/B0...b63ca550fcc234
2006 Salsa Red V6 Sport 4WD:
Outgear Solutions full length roof rack | Pelfreybilt front bumper | Smittybilt X20 wireless winch | Factor 55 Prolink | Demello sliders | FN Wheels 5 Star 17x8.5 -6 offset | Cooper STT Pro 285/70/17 | Energy Suspension LCA bushings | JBA UCA | Icon 2.5 RR front coilover (extended travel) | MetalTech 4x4 Long Travel medium rear springs| MetalTech Long Travel Icon 2.5 RR cdcv rear shocks | Resz Fab rear links & lateral rod | Icon rear lower shin guards
SoSoRunner is offline   Reply With QuoteReply With Quote
Old 11-03-2018, 02:36 PM #408
KoNEJO KoNEJO is offline
KoNEJO is on a distinguished road
Originally Posted by simple View Post
Well, I knew my radio was some sort of corolla radio, but the fact that you called out pt296-00170 as a corolla nav module is embarrassing for some reason, haha.
I can tell you that newer Nav modules don't work with the older pt546-00160/t10015 radio. The harness is incompatible with the newer radios. You can see here,
Additionally, the GPS connector is different. On the 6.1 radios, the GPS connector is square.
From what I can tell, my nav module (pt296-00170) only gives me nav. The only app I see is gracenote, but in the nav there's a pandora icon, but I haven't really played around with it. I was also under the impression that 'bespoke' is Scions 'entune'.
This tread still alive? What wire harness do i need to use this radio on my 07 tr4 ? I just found a PT546-00170 it looks like i will need also the 296-00179 for nav! Thanks
KoNEJO is offline   Reply With QuoteReply With Quote
Old 11-07-2018, 05:59 PM #409
Jerry42 Jerry42 is offline
Jerry42 is on a distinguished road
Scion pt546-00140 into JBL 03 limited
BUMP:::
OK so I've read about 400 posts in this and other threads here and there seems to be conflicting info on putting this Scion radio into a stock JBL 10 speaker system and having it work..So I ask...
Could anyone please put up a list of the harnesses I will need and maybe some pics of the back of the 00140 plugged into this years 4Runner Harneses, ready to work as expected?? Looking forward to all the new stuff this HU offers, especially the rear camera install.
Thanks in advance for any help you can give.
Jerr42 LOOKING FOR LITTLE HELP, PLEASE
"The secret of life is honesty and fair dealing. If you can fake that, you've got it made." - Groucho Marx
Jerry42 is offline   Reply With QuoteReply With Quote
Old 11-07-2018, 06:59 PM #410
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Jerr42
Another side question is what trim surrounds are folks using for the JBL equipped vehicle? I mean, you can skip on the surround but the gap is rather prominent!
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 02:41 PM #411
LA4RUNNERGUY LA4RUNNERGUY is offline
Real Name: Marciano
LA4RUNNERGUY is on a distinguished road
Real Name: Marciano
T10015 Install
I know this thread is a few years old but If by chance a member who installed this unit is able to respond, I would appreciate this. I am preparing to install a T10015 in a non-jbl Sr5.
In regards to the Metra connectors, are these needed for a non-jbl or just a JBL system? If they are needed for a non-jbl, what is the order of the connection to the harness?
I've seen the screen shots of the back of the stereo with labeling, but I have not found where the bluetooth adapter connects too?
thanks.
2009 Lexus Rx350
2022 4Runner Limited
LA4RUNNERGUY is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 03:50 PM #412
Real Name: Marciano
Real Name: Marciano
Ok, I think i figured this out. The 40-GM10 converts the smaller stock attenna plug to a regular size plug. I am wondering if using the Scosche Mda-B would provide the same result. Oh well, i guess I will figure it out.
2009 Lexus Rx350
Old 09-30-2020, 04:07 PM #413
montijo505's Avatar
montijo505's Avatar
The Ultimate Scion Head Unit: 2003 Toyota 4Runner - The Track Ahead
Sent from my SM-G986U using Tapatalk
Old 12-20-2020, 09:36 PM #414
lj4r lj4r is offline
lj4r is on a distinguished road
I picked up a 2007 FJ Cruiser. It is the base model with a very basic radio. While looking through some boxes in the garage I found two scion headunits. they look the same, but have different model numbers. One is a T1819 and the other is T10004. The T1819 shows a Feb. 2012 manufacture date and the T10004 shows a September 2012 manufacture date.
We used a T1819 in one of our 2003 4Runners. It worked great, for what it was.
Does anyone know if these will work in the FJ Cruiser? If so, what is needed. As I recall, the swap required a few new harnesses for the antenna and a mic for the phone function.
Thanks
One Dark Blue 2003 4Runner, one Silver 2003 4Runner and one Grey 2004 4Runner, new to the fleet, 2007 FJ Cruiser, Base Model
lj4r is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 10:45 AM #415
If anyone needs a Scion radio with a setup kit for a JBL system, I'm selling mine
Scion radio PT546-00120 with everything req'd for JBL Synthesis install
Old 01-22-2021, 09:34 PM #416
I did the swap with a 2016 Toyota version of the Scion touchscreen. I love the new headunit. I am having a glitch with the Aux in. When using it, the sound is very distant and garbled. Any ideas. thanks Phil
Old 03-03-2021, 10:40 PM #417
KeepingMy_ShirtOn KeepingMy_ShirtOn is offline
KeepingMy_ShirtOn is on a distinguished road
Does the PT546-00140 have amber knob lights that match?
KeepingMy_ShirtOn is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 10:33 AM #418
cnmurray14's Avatar
cnmurray14 cnmurray14 is offline
cnmurray14 is on a distinguished road
cnmurray14's Avatar
Yes
Sent from my SM-N981U using Tapatalk
cnmurray14 is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 07:12 PM #419
NCHornet NCHornet is offline
Real Name: Kevin
NCHornet is on a distinguished road
Real Name: Kevin
I just bought a super clean 2007 Limited with the JBL system. Sound quality is ok for me but the lack of Nav and Backup camera are a huge bummer. It seems the choices of head units that will work with the JBL is very limited. Has anyone found a Scion radio that will work with the 07 JBL system? I have also considered getting a mirror with dash cam and backup cam and using my phone for Nav but in 2021 there must be other choices to get what I would like? Thanks
NCH
2007 Limited 4wd 140k
NCHornet is offline   Reply With QuoteReply With Quote
Old 02-20-2022, 05:06 PM #420
Gomesito Gomesito is offline
Gomesito is on a distinguished road
Does anyone know if there is an amp plug and play t-harness for the T10015 stereo? I did the stereo conversion but now want to add a 5 channel amp and sub with minimal splicing and rigging.
Gomesito is offline   Reply With QuoteReply With Quote
3rd Gen Radio Bezel - Modified to fit Scion Radio - $65 Vancouver, WA Motohead For Sale: T4R Items 4 09-17-2013 04:54 AM
Scion radio kimboy Classifieds - buy & sell (no commercial ads please) 9 06-05-2008 07:17 PM
XM Radio on Scion HU? PolkManiac Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-29-2008 02:23 PM
MUTE function on Moto IHF-850/1000 with scion radio or Fujitsu radio. ginkang Engines / Suspension / Wheels / Tires / Audio / Accessories 0 06-28-2007 12:20 PM
New '06 Scion Radio cknsls@adelphia Engines / Suspension / Wheels / Tires / Audio / Accessories 30 10-22-2005 08:38 PM
