Old 01-22-2014, 11:15 PM #1
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Exclamation ? " Rumble Strip Tranny"
Went back to look this up about tranny noises & found @Ducman 's posts about this ^ , been having this same noise for about 4wks & thought it was a loose skid plate apparently NOT ! SOmehave said torque converter , while I read that its the WS fluid is to thin & used the older fluid & that fixed it anyway has it ever been determined what is the problem ?
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 01-22-2014, 11:22 PM #2
Stuck CAPS's Avatar
Stuck CAPS Stuck CAPS is offline
Real Name: Alex
Stuck CAPS is on a distinguished road
Stuck CAPS's Avatar
Real Name: Alex
Have you tried flushing it and running a magnet through/over the old crap?
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
-Helpful DIY Videos
Stuck CAPS is offline   Reply With QuoteReply With Quote
Old 01-22-2014, 11:27 PM #3
Yes had it done at dealership !
Old 01-22-2014, 11:31 PM #4
Scott@Hightech Scott@Hightech is offline
Scott@Hightech is on a distinguished road
Most likely you will have to replace the converter. However you can try adding some Lucas additive. I think its called shudder fix or trans medic or something similar.
If you have access to a scan tool, monitor the TCC pid and see if it locks up at the same time as the vibration
I no longer work for hightech. PM me if interested in my new shops information. i have all the same capabilities I had at Hightech.
Scott@Hightech is offline   Reply With QuoteReply With Quote
Old 01-22-2014, 11:52 PM #5
Will do thanks Scott
Old 01-24-2014, 02:44 PM #6
bagginz's Avatar
bagginz bagginz is offline
Real Name: Tom
bagginz is on a distinguished road
bagginz's Avatar
Real Name: Tom
Sounds like a TQ issue. I would make sure the fluids clean. Its difficult to "flush" these transmissions as you can only get about 3 quarts out at a time. With that being said, some of the dealers aren't really even doing fluid changes on these yet so some may not have a good since of how to really change the fluid on these. Let us know if you use the additive. Very interested to hear how that works
FJ TT Springs, Bilstein 5100s, front set at 1.75, 1' rear cornfed spacer, AllPro wheel spacers F1.25 R1.5, 55w hid 5000k HID lows and fogs, High beam mod, Fog light mod, OEM 265/65/17
bagginz is offline   Reply With QuoteReply With Quote
Old 01-26-2014, 09:18 PM #7
Question
Well really starting to think this a torque converter issue ! Been reading all the old posts & it sure feels and sounds , feels like it . If any of the old guys still have there 4runners and replaced their TC please holler back if things have held up on this !! It's doing it now in 4th gear so that's why I'm growing a little concerned .
"Rumble Strip" Transmission issue Ducman 4th Gen T4Rs 363 01-10-2023 07:56 PM
"Rumble Strip" Transmission issue moved from 4th gen ningduo 5th gen T4Rs 0 10-26-2010 04:13 PM
'88 4Runner-Tranny Fluid "burping" out of shift lever hole akalaka Classic T4Rs 2 10-11-2010 11:26 PM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
20"+ rims at the strip don't mix RonMAIDEN Off Topic 4 04-03-2007 12:46 AM
