Old 01-23-2014, 01:24 AM #1
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
Melted OEM AUX switch wires
I installed a LED bar around Christmas time, its been on and working great for some time. Today i smelled some weird electrical smell while driving and figured that couldnt be good. I did some investigating in my console and found this tonight.
This is the wire that melted the loom in the pic above. Looks like maybe a diode or whatever got too hot or shorted out.
Now, i know first thing everyone will think is how did you wire your light. I used the drawings i found below;
and this one
What exactly would have caused this? Could the diode just go out on me? The switch wont work obviously so im hoping i didnt blow the OEM AUX switch. I know the OEM wiring in the harness is very very tiny, could it just have maxed out the little wiring?
Can i just rewire it with bigger wiring without a diode or whatever is in that wire which melted?
Anyone have any idea?
LTDSC is offline   Reply With QuoteReply With Quote
Old 01-23-2014, 10:52 AM #2
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
Which wire was it that melted? I don't see any diodes in that diagram?
zopperman is offline   Reply With QuoteReply With Quote
Old 01-23-2014, 11:24 AM #3
HokieRunner's Avatar
HokieRunner HokieRunner is offline
Real Name: Matt
HokieRunner will become famous soon enough
Real Name: Matt
and this one
First off - glad you caught it and it wasn't any worse.
Did you follow the wiring diagrams to the letter? Just wondering what the purpose of the diode is and if that's the part that burned. Which actual wire melted? Was it the signal wire?
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
HokieRunner is offline   Reply With QuoteReply With Quote
Old 01-23-2014, 11:28 AM #4
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
The diode is in the oem wiring. I did a ton of googling last night and its apparently there for oem wiring. As if I was plugging in to factory system. It's so the computer won't overload the switch. But a lot of people instruct to remove the wire with the little diode in it and wire a normal wire and have no issues. Its been hooked up for a month no issue then I was driving with it off and smelled plastic.
Its the red/green wire so its the wire in which leads to the relay.
Old 01-23-2014, 11:33 AM #5
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
Do you know what load the diode was rated to handle?
Old 01-23-2014, 11:46 AM #6
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
Couldn't find that info. I have a 5amp fuse from the relay to the switch and its not blown.
Old 01-23-2014, 12:00 PM #7
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
I would imagine the diode is between 1-3.5A and it is certainly possible that it melted because the draw was too much.
How long was the bar running before the melting occurred?
the bar draws 180w/12v = 15amps through a relay. The relay coil typically pulls <1 amp.
Old 01-23-2014, 12:05 PM #8
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
bar wasnt on. Thats why im confused. I've left it on for an hour with me watching everything previously and nothing.
Old 01-23-2014, 12:11 PM #9
Stuck CAPS's Avatar
Stuck CAPS Stuck CAPS is offline
Real Name: Alex
Stuck CAPS is on a distinguished road
Stuck CAPS's Avatar
Real Name: Alex
I've noticed that sometimes the plastic cover over the shifter gets pretty hot sometimes, are you sure that it wasn't touching anything that got really hot?
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
-Helpful DIY Videos
Stuck CAPS is offline   Reply With QuoteReply With Quote
Old 01-23-2014, 12:11 PM #10
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
You have the relay between the switch and relay or between the power and the switch? There should be one between the switch and wherever its power is from.
All the FJ switches I've installed I've cut the harness past that diode (didn't actually know it was a diode) before installing. Not sure if that's right or wrong but they've worked fine for 4 years.
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 01-23-2014, 12:11 PM #11
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
Didn't you previously cross the wires or something? COuld it have been from that?
Old 01-23-2014, 12:12 PM #12
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
could very well have touched it. I havent fully opened up the wiring as it was dark. Planned to do it here soon, but the switch is inoperable now.
Old 01-23-2014, 12:14 PM #13
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
theres a relay which is fused from battery to relay and fused after the relay to the switch. Also fused from green trigger wire to power.
Old 01-23-2014, 12:32 PM #14
Real Name: Matt
Real Name: Matt
I'm still trying to understand what part of the harness wiring has a diode in it? Is it to do with the OEM fog light switch (did it come with it's own harness?)
ie. of the diagrams you posted - which wire melted?
Old 01-23-2014, 01:07 PM #15
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
It's in the switch's harness, and I think the green wire.
-Helpful DIY Videos
Help: Hatch Handle Melted Grape Ape 5th gen T4Rs 40 07-17-2020 02:13 PM
Blue NGK Plug wires switch help? Runner4liife 3rd gen T4Rs 22 05-16-2014 08:51 PM
Amp switch wires smoking kokbagg Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-10-2013 10:32 PM
Melted Rear ABS/Speed sensor wires! What gauge? DiskDoctr Problems & Warranty Issues 4 09-09-2012 01:14 PM
