Old 03-18-2016, 11:46 AM #76
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
I think the faint brief whooshing sound is normal at cold start. Mine does it, and as you've correctly surmised, that's related to the air pump forcing air through the cat. There's no need to resort to subterfuge to mask that sound when you sell it.
The EPA has rules that the mfgs have to meet, in order to get their emissions type certificate, concerning how quickly the engine meets emission standards immediately after startup. The air pump is part of the mechanism that enables them to meet that standard.
However, it's impractical for the state emissions testing stations to require that you bring your car in with a cold engine for the test (you'd have to trailer it to the station), so they have no way of testing that part of the system, which is why the bypass works. Look for OBDIII diagnostics sometime in the future which will monitor the start-up stuff and throw a code if it is not working. Not there yet, however.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 01-26-2018, 11:02 AM #77
ndjose ndjose is offline
ndjose is on a distinguished road
Sorry to revive just an old thread, but do the non VVTI engines also have this problem? I have an 03 V8, wondering if I should be proactive on this.
Thanks
Jose
ndjose is offline   Reply With QuoteReply With Quote
Old 01-26-2018, 01:26 PM #78
slyfox75 slyfox75 is offline
slyfox75 will become famous soon enough
No, 2005+ only.
slyfox75 is offline   Reply With QuoteReply With Quote
Old 01-26-2018, 02:48 PM #79
Originally Posted by slyfox75 View Post
No, 2005+ only.
Thanks
Old 05-05-2021, 01:41 PM #80
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Has anyone with a 2008 or 2009 had this issue?
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 05-06-2021, 01:18 PM #81
Yes on the 2008-2009 AIP SAIS pump issues. This problem affected all 4.7s from 2005-2009 on the 4Runners.
2005 SR5 V8 4x4. Shrockworks Sliders, 4th gen Limited Wheels, Falken Wildpeak ATW3, Slyfox75 Bypass of course, Bilstein 5100s w Dobinson's Coils(314 & 505)
Slyfox75 AIP/SAIS bypass kit. Bypass = $49 Stainless Blockoff Plates $28(pair) email to jeffcolemaps at gmail for more info or questions. -jeff
Old 10-22-2022, 12:45 PM #82
4Player 4Player is offline
4Player is on a distinguished road
When resetting P2440
I pull my ground cable off battery to reset and get out of limp mode. I can drive quite a while before it happens again. Does this mean the valves are closed during this time?
I would like to install the Slyfox Bypass which I THINK can only be done with valves closed.
4Player is offline   Reply With QuoteReply With Quote
Old 10-23-2022, 02:36 PM #83
Best to email me your codes…..but in general….if you have limp you will need blockoff plates.(and bypass)
Old 10-26-2022, 01:39 PM #84
mavrick1903's Avatar
mavrick1903 mavrick1903 is offline
mavrick1903 is on a distinguished road
This is why it's a great idea to do the AIP bypass proactivly. I installed it from @slyfox75 shortly after I got the truck (2007 v8 bought used in 2014)
mavrick1903 is offline   Reply With QuoteReply With Quote
ABS Pump? why do you gotta' pump every 5 seconds? infamousRNR 3rd gen T4Rs 5 01-17-2014 10:32 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Codes P2440, 1441, 1444, C1201, dashboard X-mas tree :( MRT555 Problems & Warranty Issues 2 09-20-2011 03:30 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
12v Air pump Falls Engines / Suspension / Wheels / Tires / Audio / Accessories 7 06-23-2006 04:20 PM
