02-04-2014, 10:14 PM
Finally did it! Upgraded to 5th gen 20" limited wheels!
I've been wanting the rims since they first came out in 2010... and finally had a good reason to buy. Needed new tires and found a great deal on all 5 wheels with tires with around 1k miles on them! Really like the ride and looks.
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
02-05-2014, 04:33 AM
grats
I hate my 5th gen worst purchase I have made
02-05-2014, 08:38 AM
I have a set of low mile tires just for this reason. Just waiting
02-05-2014, 09:27 AM
Originally Posted by Code2
grats
How come?
2006 4Runner SR5 4WD V6 Nautical Blue
02-05-2014, 09:36 AM
grats
I take it you had a 4th gen and "upgraded" to a 5th gen?
2004 V8 LIMITED 4WD
02-05-2014, 09:41 AM
Thought my 18" Limited wheels looked nice.......
Those 20"s look awesome !!
02-05-2014, 10:28 AM
Real Name: Chris
Real Name: Chris
Wow, those look so great!
02-05-2014, 10:41 AM
looks so good!
i tired to find a similar deal when I needed new tires a few months ago.. never could make it work. people wanted too much for their 'throw-away' wheels...
do notice it riding slower? happen to weigh the difference?
02-05-2014, 11:13 AM
I assume these are not a direct bolt on? what is needed to make these work? looks great BTW
02-05-2014, 11:23 AM
Originally Posted by drapaki
looks so good!
I can feel the weight difference when driving, but not by much. Something you really can't avoid when you're adding 3" larger wheels. The smoother ride and looks are definitely worth the sacrifice.
2004 V8 LIMITED 4WD
02-05-2014, 11:25 AM
Of course these are a direct bolt on 6 lug / 6 lug.
The 5th gen offset is +12 / 4th gen is +30.
02-05-2014, 11:27 AM
Thanks!
Direct bolt on, no modifications necessary. Only issues are either swapping the TPMS or turning off the sensor dash light, and also remembering that the larger tire size will add ~3% to your MPH. My plan is to swap in the TPMS once I need new tires and do the TPMS sensor mod to turn off the annoying blinking light on my dash.
2004 V8 LIMITED 4WD
02-05-2014, 11:42 AM
Real Name: Chris
Real Name: Chris
Are you lifted or stock height?
02-05-2014, 11:58 AM
stock height. The larger sidewalls on the tires did add some extra clearance. When I get new tires I'll most likely stick to the stock diameter which is 255/50 R20.
2004 V8 LIMITED 4WD
02-05-2014, 02:16 PM
larger sidewalls? Are your new tires bigger than 255/50 20s? Your stock tires should have had a larger side wall. 255/50 20 is the same height as your older 265/65 17s, but you have thinner side walls on the 20s because the wheel is larger.
As for weight, I doubt you would notice any difference. The wheels would weigh maybe 5 lbs pounds more, but your tires will weigh less. It is almost a wash. With a 3 inch wheel increase, you should notice a big handling difference. It should feel much stiffer. Maybe that is what you are feeling.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
