Old 02-05-2014, 03:08 PM #1
Jer5091 Jer5091 is offline
Jer5091 is on a distinguished road
Need a new cat converter....
Need a new catalytic converter. I know they're expensive, but will install myself. Any OEM or aftermarket suppliers to save me some coin on this? I would rather not spend 600 on an OEM.
Thanks!
BTW - i've got an 03 SR5 v6 automatic.
I don't care what your wife says, we're going fishing...
Jer5091 is offline   Reply With QuoteReply With Quote
Old 02-05-2014, 04:15 PM #2
MikeInNH MikeInNH is offline
MikeInNH is on a distinguished road
Why do you think you need a new catalytic converter?
The reason I'm asking is because there have been MANY MANY catalytic converters replaced when the real problem was just an O2 sensor. If you have a bad cat...then there's a code that's thrown to the ECU. If you have a bad O2 sensor (usually down stream O2 sensor)...it can throw the same code as a bad cat.
Further tests need to be done to determine if it's a bad O2 sensor or in fact a bad cat.
MikeInNH is offline   Reply With QuoteReply With Quote
Old 02-05-2014, 04:33 PM #3
Jeff T's Avatar
Jeff T Jeff T is offline
Jeff T is on a distinguished road
Jeff T's Avatar
I'm in the same spot as the OP. With 248k on the odometer the dealer scanned it and it was the converter Bank 2 and they gave me the part #. Now, I read BlackWorks sticky about drilling a hole to check and wonder if ANYONE ever had that done at a dealer?
OP - Check RockAuto.
2004 4Runner Sport Edition 4x4, V6
Stratosphere Mica
284k
Jeff T is offline   Reply With QuoteReply With Quote
Old 02-05-2014, 11:31 PM #4
Sorry, should have mentioned in my first post, my brother used to be a car tech at a dealership, he scanned it and it threw the cat code for the right cat, not the O2 sensor. I'd be much much happier if it were for the sensor since they're cheap.
From what i've been quoted from the local Austin dealership, they say approximately 2k-2100 for parts and labor, but we've got all the tools. 134k on the truck now and needs tires soon...would rather toss money into mods (you know how it is)
Old 02-06-2014, 01:27 AM #5
Thanks for the Rock Auto suggestion. Checked and they have a good selection, and they're cheap. My only worry would be getting something that would last 1 emission cycle because it doesn't have enough platinum, palladium, and rhodium.
Old 02-06-2014, 02:36 AM #6
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Pacesetter or magnaflow are only after market I was aware of ? Still cheaper than oem !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 02-06-2014, 02:59 AM #7
TFJ-4runner's Avatar
TFJ-4runner TFJ-4runner is offline
TFJ-4runner is on a distinguished road
URD O2 Fooler will save you hundreds if not thousands
Project LEXUS GX470 Build 6
/Radflo 2.5 Full Suspension Extended Travel ~ All Pro 3.5" Springs ~ SPC UCA ~ SCS SR8 Wheels ~ Metal Tech Rear Spring Isolators\
Daily Driver/Weekend Warrior
TFJ-4runner is offline   Reply With QuoteReply With Quote
Old 02-06-2014, 10:10 AM #8
You can NOT determine if it's a bad cat from just scanning it. A bad O2 sensor can give a false reading making the ECU think it's a bad cat. Further testing needs to be done. Not sure of the procedure for the 4runner...but my Pathfinder you had to ground unplug the O2 sensor and then jumper a couple wires....etc...
Scanning just tells you that the O2 sensor is sending a reading to the ECU of the air-flow ratio. That ratio is either a true reading...or a false reading because the O2 sensor is bad.
Update - How to test an O2 sensor....Here's a test for the Honda... I'll bet the Toyota O2 check is similar.
http://www.wikihow.com/Check-Honda-Oxygen-Sensors
Old 02-06-2014, 11:01 AM #9
Thought about doing this, but probably won't pass emissions tests this coming year.
Cat Converter - 96 TXLUGNUT Want to Buy/Trade 0 04-12-2013 03:15 PM
Cat Converter Help nilblake 3rd gen T4Rs 0 04-17-2011 01:03 PM
Bad Converter? edy0way Classic T4Rs 2 08-30-2010 11:43 PM
TSB for converter speed junkie 4th Gen T4Rs 20 08-24-2008 12:13 PM
cat. converter??? silver cobra 4th Gen T4Rs 7 09-15-2005 10:12 PM
