Originally Posted by Bigt5646
Anyone have any advice for what to check next if you still have a popping sound after removing the front sway bar. I removed it and it got rid of the scratching sound of the sway bar rubbing on the coil perch but I still have the pop when turning at low speeds or going over bumps. It’s intermittent.
Could tie rod ends be the culprit?
They could be, I would expect to see unusual tire wear though if this has been going on for some time. Jack the front up and and put some muscle on it or pry on it intelligently to check for slop. That noise turning at low speeds is a known symptom of outer cv axle failure. You can check them for excessive lateral play the same way. Sh1t like this is how you get to know your girl intimately. 🙏
