01-27-2006, 10:22 AM
2006 Seat Heater
Does anyone know if the 2006 seat heaters, heat both the bottom and lower back?? Or just the bottom
Thanks
01-27-2006, 11:55 AM
Most seat warmers provide heat in both areas. My BMW heats my lower back as well and they are typically smaller seats. I can't imagine that the 4Runner wouldn't do the same. I mean, what's the point? Don't you agree?
2006 TiAg 4Runner Sport 4WD V6
2004 Silver Grey BMW ///M3 6MT
01-27-2006, 11:58 AM
I do agree, but the MDX and my old Volvo only did the bottom.
01-27-2006, 02:29 PM
My 05 Limited only does the bottom, at least that's all you can feel.
Scott
01-27-2006, 08:25 PM
Scott
Mine too, I wish it did the back too. Wish it got a little warmer too.
Check out my 2004 4Runner Audio upgrade.
01-28-2006, 01:23 AM
Super Moderator
Super Moderator
I think mine does both the bottom and lower back. I could swear I felt a little heat in the lower back portion unless I am imagining things! Overall, I don't think any Toyota/Lexus seat gets hot enough. The BMW seats can really burn you if left on high.
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
01-29-2006, 06:24 PM
I like the way BMW seats warm up so hot. They actually penetrate through several layers of clothes that you would wear in the winter anyway. There's no going back after I have them now. Only the 4Runner we ordered didn't list it as an option.
01-29-2006, 10:21 PM
heating the bum
watch out *guys*, you do know excessive heat isnt good for that part of men, right?
01-30-2006, 08:49 AM
Mine seems to heat both, but the seat gets hotter.
Koz
01-30-2006, 10:08 AM
My Acura did bottom and back for the driver, just botttom on the passenger.
I miss the heated seats. I used them all year.
A friend's ES 330 has ventilated seats, wierd feeling.
01-30-2006, 01:47 PM
I would have never ordered heated seats but came with the Limited package. I could never see the cost/purpose. After a couple winters, they are GREAT! The heat takes a mile or two to START getting warmed. The seats take a couple blocks. It's funny how you get to love things just by accident!
Koz
01-30-2006, 01:56 PM
Koz
That's the one thing I miss from my '99 Blazer. Missing the power/memory seats aren't so bad, but I do miss my heat seaters. Its amazing how much faster you warm up in cold weather when the seats get warm too. Sometimes I never even used the vent heat on chilly days.
They will come with CST leather sometime in the future, just get me through this winter!!
01-30-2006, 01:58 PM
It sounds like people are having different experiences with the heated seat zones. I would think it has more to do with whether or not the heated seats (and more likely, the leather seats) were a factory installed or port installed option. My past experience has showed that port options usually cut some corners that you would have gotten if the options had been OEM at the factory.
GEAUX TIGERS!!
[SIZE=1]2006 Toyota 4Runner Limited V8 4WD
Exterior
01-30-2006, 08:23 PM
I have the OEM Leather on mine, and mine don't feel like the heat the back at all. Maybe it depends on the year too? mine is an 04
02-03-2006, 03:18 PM
I have an 06 SR5 with port installed leather. My seat heaters have a 3-position toggle switch for each of the front seats. The middle position is "off", the forward position (designated with 2 horizontal lines) heats both the lower back and seat bottom, the back position (designated with 1 horizontal line) heats just the lower back. There was a card in my glove box that described the operation of the seat heater. It states that you can cut a wire loop under the seat to make the switches control the temperature instead of which parts of the seat receive the heat. If you cut the wire loop, then both parts of the seat are heated and the switch just gives you 2 different temperatures.
On my 05 (which was replaced with the 06 through the lemon law) the seats didn't get as hot as the 06 nor did it heat up as fast as my 06. It seems that it was improved. I think the Limited has a wheel type control for the heater, but I might be mistaken.
If you guys don't have this card, I can type the info in a post.
Doug
2006 4 Runner SR5 4X2, Nautical Blue Metalic, Dark Gray/Stone Leather, Heated Seats, V6, 17" Alloy Wheels, Double Decker Cargo, Moonroof, Rear Spoiler, DRL, NAV w/XM - 11/30/05
