06-24-2019, 04:56 PM
#16
Originally Posted by Toyrundrive
I'm no expert but that looks like bearing grease. Good luck! I'll be waiting for the results. I have new front hubs, just need to source some bearings and get it done. If this fixes your problem I guess I'll do my front hubs.
ran into a hitch, seems i over torqued the sensor bolt, and broke it while attempting to reinstall the sensor, so gotta drill out the broken bolt, during the wheel bearing ops, i cleaned and reinstalled the sensor, but error still remained, will wait till i install new bearings before i conclude. truck drives ok, except for a slight drone, i though a failed bearing on both rears would make a helluva sound
btw, i can see the front wheel sensor is a hex/allen key?, what size is it?. all my allen keys didnt fit. attched is a readout fron my obd bluetooth app
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
06-24-2019, 08:18 PM
#17
I honestly don't remember. Maybe 5mm definitely metric. My tools are buried right now but I'll be rebooting my CV axles in a parking lot tomorrow so I can check then.
The open electrical circuit you are reading, if the sensors are ok as you say they are, means the harness circuit is broken. Can you push the wire back into the connector? 1/2" is enough to break the circuit. When my Speedo stops working I get out and push the wire back in and it works again. Be careful though: you no longer have abs until the computer reads a proper circuit for long enough. Can't remember if disconnecting the battery resets that and brings it back once you push the wire back in. Not having abs when you're used to it is a recipe for disaster. It takes a lot to get my blood pumping, getting sideways on a busy interstate will get it done.
Be careful with that bolt. I've drilled plenty of bolts out from shearing the head off. For this you better use a bolt extractor. Or carefully weld something to it and twist it out
06-28-2019, 07:01 AM
#18
welded a short 14mm bolt on the broken bolt stub, and used a spanner to back it off, took several attemps as it was parting at the welds. yes i have some play in the carness, i pushed it in by 1\2inch or so on the LHS sensor, and no dice. may have to buy a new sensor and take it from there
sensors read ok 0.34ohm when tested alone, harness reads ok, when disconnected from sensor, however no continuity when sensor is plugged into harness, and read from the combined harness connector, above the axle
i am looking at 3 options now,
1. Buy a new harness
2. Trace from the harness connector above axle to the abs ecu/vss (you have any idea where this is?)
3. double my continuity reading again
07-01-2019, 05:30 AM
#19
Pretty sure it's part of the master cylinder.
Are both sensors connected when you're checking continuity?
07-01-2019, 05:28 PM
#20
no nd yes, did the test in stages.
been pretty busy, left the car, will do further trouble shooting over the weekend.
@ bolded, you mean the harness for the rear wheel speed sensor??. toyodiy has a schematic showing they terminate somewhere near the center storage area, a lil puzzling, cos there is no ecu there to my knowledge
07-03-2019, 12:43 PM
#21
The two wires come together and plug into a harness in the location you describe, yes. But then that harness surely plugs into the skid control ECU.
If you have the harness out to test it, doesn't that mean you know where that link terminates?
07-03-2019, 08:15 PM
#22
So the part circled in yellow clips into another connector hidden ontop of the frame.so that connector, am assuming leads to the vsc ecu?..
Its that pathway i wish to test for continuity if possible...hence my question.
07-05-2019, 10:05 PM
#23
That's what I thought you meant, check one of the online parts diagrams. I usually get on Toyota of Dallas parts to use their diagrams, but there are so many scam websites that are close to their address...
I'm pretty sure it plugs into the brake master cylinder assembly
07-06-2019, 02:54 PM
#24
So, some good news. Got back from a 5 day trip and drove the runner for about 1mile, and the brake sign went off, and my odometer started working, scanned the car, and all wheel sensors are working ok.
Note i had previously driven the truck about 5miles after the last repair/cleaning attempt on the wheel sensor.
So maybe the cleaning did the trick and the truck requires upto 6miles to reset the wheel sensors.
Only puzzle is that, i thought my san tool would have been able to communicate with the sensor, after my last attempt to clean them
now time to face the stubborn p0174.........arrrrggghhhhhhhh
10-25-2020, 09:58 PM
#25
Has anyone figured a definitive solution?
I’ve recently experienced this problem after a wheeling trip. My VSC trac, VSC off, ABS, and Brake light are lit up. Driving in the snow with no VSC or abs has been terrifying.
On my OBD reader it gives me a problem with the Left rear wheel sensor. I figured no problem I’ll just replace it so I did when I serviced my rear brakes (it also had grease on the sensor). To my surprise, after start up the problem continued (even after 100+ miles of driving). Tomorrow I am checking the continuity of the harnesses and will report back. Otherwise if anyone has any suggestions or tips, much appreciated!
03-02-2021, 10:22 PM
#26
what were the readings from your harness? sorry 2 year old bump thread. but this happened to me too. but can't find anywhere about number of resistance for the harness. my rear passenger sensor was just as dirty. i want to spray the hub with wd40 to clean it because its muddy but don't know how that will affect
12-05-2023, 10:12 AM
#27
so 2years after the lights are back again..the 2 rear wheel speed sensors are faulty from the codes i pulled with the obd tool. confused on what next to do now
