02-22-2014, 10:25 PM
Bad wheel bearing
Hi all,
I have a 2005 4runner 4wd SR5.
After doing research I found that one of my front wheel bearings is bad. My symptoms are there is a loud noise and a vibration coming through the steering wheel. When i'm driving straight or turn left the noise is evident. When I turn right, the noise disappears. I know noise travels but it does sound like its coming from the drivers front side.
I did find a good youtube video on how to replace it but my dilemma is which side is has the bad bearing. I don't think that the driver and passenger side bearings are interchangeable, so I just need to get the right one.
Bluepitbearings.com front wheel bearing hub assembly on a 2003-2012 Toyota 4Runner - YouTube
With these symptoms, could it be the driver side? Or the passenger side?
Thanks in advance,
mlc2000
02-22-2014, 11:08 PM
Real Name: 03 v8 Limited
Originally Posted by mlc2000
Hi all,
Thanks in advance,
mlc2000
Jack up truck grab tire at 12 and 6 and which ever one has play is the bad side
That being said might just want to change both sides
And yes the wheel bearings are interchangeable aide to side
02-22-2014, 11:09 PM
Also make sure you change the dust seals on spindle when your doing them
Otherwise you will be doing them again sooner then you may expected
As well as a new o ring
02-23-2014, 12:39 AM
Real Name: Tony
Real Name: Tony
Hi all,
Thanks in advance,
mlc2000
Don't make the mistake of ordering the different parts and thinking you will get it cheaper than what this guy is selling the whole complete unit for. LOWEST PRICE complete front wheel bearing assemblies ANYWHERE!!! I made that mistake, had to send the crap I got back and order from these guys. They are awesome! and by far the cheapest you will find.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
02-23-2014, 01:07 AM
On my 4runner, when I turned right the sound would go away. This lead me the believe the right side was bad because it got quite when unloaded. Turned out the left side was bad. Something with our suspension geometry actually made the bearing quiet when loaded, turning right.
02-23-2014, 11:13 AM
Thanks for posting this link! I need to do my bearings this spring as my seals are both shot. The only places online I find with complete bearings are $$$
04 Limited 4WD V8 Silver All Stock
93 RX7 Twin Turbo Non-Sequential
02-23-2014, 11:55 AM
Banned
Banned
Hi all,
Thanks in advance,
mlc2000
I'll just put this here
http://www.toyota-4runner.org/sale-t...st-custom.html
02-23-2014, 12:06 PM
Try the wheel rocking method? That's how I knew for sure which was bad.
-Pete
07 Shadow Mica V6 Sport
Audio: Eclipse AVN 6620| Alpine PDX 4.150 & 1.600 | CDT HD62 x2 & Fiberglassed 12'' & Lots of Soundproofing
Lighting: 4300K HID, 3000k HID Fogs, LED Interior, Krager HID Driving Lights
Outside: Daystar 2.5/1.5, 285/60R18 Toyo OC AT | T&H High Bull Bar
02-23-2014, 12:21 PM
Banned
Banned
you can also spin the wheel and listen for grinding
02-23-2014, 06:34 PM
this is the wheel bearing master right here ^^^^^^
03-02-2014, 06:16 PM
Banned
Banned
I have been called Hub Master General by other members
03-10-2014, 09:24 PM
Send a PM to
@ nj636
and he should help you out. As listed above, he sells them.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
03-10-2014, 09:38 PM
Originally Posted by NJshadow93
Send a PM to
@ nj636
This ^^^^
03-10-2014, 09:53 PM
Banned
Banned
Send a PM to
@ nj636
This ^^^^
thanks guys I sent him a PM
Toyota prices don't include a bottle of lube
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
