02-28-2014, 03:55 PM
FJ Coil Alternatives
I am getting ready to put new Bilstein shocks/struts on my 08. Looking on the forum, I am now sold on putting FJ coils on as well. However, I am having a problem locating a used front and rear set. Are there any other decent options other than OEM FJ coils that would be worth exploring?
I wouldn't mind a little lift, but it certainly isn't a priority. The truck only goes off-road a few times a year. I mostly want an overall better ride for daily driving.
The truck has 82k on it and I have a mechanic friend who is only going to be available for a couple more months, so I want to get a lot of stuff done while I can. I will probably do new brakes and rotors, sway bar bushings and links, and maybe a coolant flush. Then next winter I will do new tires. So since there is other stuff that needs to be done, I don't want to spend my whole budget on the suspension...
Thanks
02-28-2014, 04:42 PM
The moog springs for the fj on rock auto are a good choice and inexpensive. Also the front springs from an 05 and up tacoma. They will give more lift than the fj's to.
'03 with '12 TRD Taco swap with 1/2" Toytec front/1.5" DaystarRear, 265/70/17 Cooper Discoverer ATP's on Sequoia Split Spokes
Scarcely for a righteous man will one die; yet perhaps for a good man some would even dare to die.
Romans 5:7
02-28-2014, 05:13 PM
Take a look at this thread...
FJ vs. Tacoma springs?
Basically looks like the Tacoma TRD front springs and shocks are actually a better way to go than the FJs. And far more common to get used...
2007 Limited 4x4 V6
Front: Taco TRD struts + 1" spacer - Rear: 2" Superflex w/ driver 1.5" spacer TRD shocks - eBay UCAs - Lots of lights Past: 1996 FJZ80 LX450 Locked OME
1999 UZJ100 Locked
2006 Tacoma Prerunner SR5 5100s TRD rear leaf
02-28-2014, 06:47 PM
You should also check this thread out.
I just received my 5100s and Moog 81088 springs for the front to replace X-REAS. No coil change for the rear, just going to 5100 rear shocks.
I expect about 3/4" of lift in the front, but we'll see on Tuesday when they go on.
2008 Sport / V8 / Bright Silver FN FX Pro / 255/75 Duractracs / Fox 2.5" Factory Front Coilovers / JBA / Superpro / Fox 2.0" Rear / Wheeler's T12 / Limited Grill / Rigid Duallys / Flowmaster 70 Series / ScanGaugeII on Blendmount / 5k LEDs / Homelink Upgrade
03-01-2014, 12:22 AM
Really interested to see how this turns out. I've been thinking of doing similar to my wife's 2006. It's got nearly 140k with original suspension still
2006 Sport 4x4 V8 - OME Nitrocharger 2885/2895 - Icon Rebound 17x8 - Nitto Ridge Grappler 285/70/17 - RCI Engine Skid
03-01-2014, 12:33 AM
also want to know how this install goes tuesday! please update as soon as completed!
Current - 2016 Mag Gray SR5, 3rows - diode dynamics fogs, tint, FalkenAT3W, blacked out badges, more to come
Old - 2008 Black sr5 v6 - Bilstein 5100s, FJ rears, black counter steers, xenon depot h11 hid kit, Scion Radio upgrade (touchscreen), BHLM, tint, Cooper AT3s.
03-01-2014, 12:55 AM
Real Name: Rob B.
Real Name: Rob B.
I just did 5100s and new moog fj Springs all around. The ride is great. Not harsh in the least bit. Smooth over small bumps and firm in corners with significantly less body roll and nose dive than stock. Front struts set at. 85". Level stance with about a 1-1.5" lift.
2009 GX470 Sport Edition w/ KDSS
03-02-2014, 10:56 PM
I think this is what I am leaning towards. Did you have to buy any other components other then the 5100s and springs? I hear people talk about spacers on one of the sides, rubber covers, and strut mounts. I don't much about suspensions, so I want to make sure I get all the right parts for my mechanic to do the job. Also, do I tell him to just set the fronts at .85" or does he need to know anything else?
There is still a chance I may just put the 5100s on and leave the oem springs. I just really want improved ride and not so worried about the lift.....
03-02-2014, 11:04 PM
You will need springs for improved ride quality. The stock springs are very wimpy, especially when you see it in comparison to FJ or equivalent. The spring and bilstein firm up the steering nicely, that alone is worth the money.
GONE - 08 T4R - 4" Lift with OME 885/895 & Bilstein 5100s, Toytec top-out spacer, Daystar 2" spacer, 1.5" Body Lift, 275x65x20 Duratracs (34.1"), Light Racing UCAs, Spidertrax, Toytec Diff Drop, 5th gen brake upgrade, SS brake lines, Budbuilt 5 piece skid kit, CBI sliders, Avid light bar, Hella 500ff with HID conversion, Curt front hitch receiver, ARB Awning, Uniden/Comet CB, Rostra seat heaters, Dynamatted interior
Corvette C7 Z51 | Ford Raptor | Aprilia RS250 | Aprilia RSV4 | Ducati 848 Corse
03-03-2014, 12:14 AM
I've got 5100s and moogs coming in the mail
2007 Driftwood Pearl SR5 V6 4x4 /MB Wheels TKO 17x8.5 -6mm/ Hankook dynapro mt2 285/70/17 / bilstein 5100s -1.5 daystar rear spacer lift on moog fj coils / 1" Toytec body lift / ddm hids / interior leds / reverse light led / vsc - atrac disable mod / limo-30% tint/ rear diff breather mod / rola vortex roof rack / hanma 30" LED lightbar / kenwood ddx373bt w backup camera / ppi p900.4 / sundown sax1200d sa8d4v1.5 / diamond audio d6 comps / SPPC black halos
03-03-2014, 12:31 AM
Real Name: Rob B.
Real Name: Rob B.
I bought new top plates from Oreilly's. I couldn't remove the top nuts on my stock struts due to age/rust so I took them out as a unit. The new top plates were pretty cheap so I just swapped them out. No other spacers or trim packs were used.
03-03-2014, 03:16 PM
Did you get the 81108 for the rear also or a different number?
03-03-2014, 06:29 PM
81081 is the part number for the rear.
2006 SR5
2007 Porsche Cayman
03-03-2014, 09:22 PM
One last thing. Will the truck need an alignment after the new suspension is put on?
03-03-2014, 09:28 PM
Yep.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
