Old 11-10-2016, 09:21 PM #211
Ruthven13 Ruthven13 is offline
Ruthven13 is on a distinguished road
Last time I was actuating both the CDL and Lo on my '03 V8 I had to shut the truck off and start it again for the shift to complete. Otherwise it would just beep and not shift back to the previous mode. Everything works, just not really how it is supposed to. I would think it would take less than 200' or so of straight line driving for it to switch back over. That's all the room I have to work with on my street and wanted to be close to home if something happened since that was right after I bought it 10 mos ago. Ever since just left in in 4Hi...
2003 galactic grey mica Limited 4x4 V8 X-REAS and rear factory air suspension.
Ruthven13 is offline   Reply With QuoteReply With Quote
Old 11-11-2016, 11:22 AM #212
metramm metramm is offline
metramm will become famous soon enough
sprocketus,
If you haven't changed out your diff fluid (front, rear and center) I would do that.
When I did mine, it came out black as tar. I don't think it was ever changed in its life.
Very simple to do and there is a forum link with detailed pictures to guide you through the change. I used it to guide me and it worked like a charm.
I exercised mine yesterday and 4HI engaged in I'd guess 6 seconds, and 4LOW in 1 second. It is nearly instant now.
It used to take upwards of a minute to engage the 4HI before the fluid change.
The fluid is about 12 bucks a quart. Mobil1 75w 90. Plus you need the plug gaskets from the dealer but they are only a few dollars each.
Good luck!
metramm
metramm is offline   Reply With QuoteReply With Quote
Old 11-15-2016, 01:12 PM #213
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
Is is normal to have some noise going from 4HI to 4LOW or back to 4HI? It's hard to describe, not exactly a grinding noise. It just lasts a short time, then there is a bit of a clunk after the noise which is fine.
So does it do that for everyone? I tried it twice this morning, once before it was warmed up (1000 rpm idle), and once after it just barely warmed up (~500 RPM idle). I didn't notice much difference in noise, but there was maybe a bit less when it was warmer. I try to turn the knob quickly after I shift it into neutral.
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 11-15-2016, 01:24 PM #214
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
Originally Posted by metramm View Post
sprocketus,
Good luck!
metramm
I guess this will be my next step. I have tried getting into 4Lo many times with no success. Other than waiting for Summer and hot weather, not sure what else is to be done.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 11-15-2016, 01:51 PM #215
sport2004,
Yep I would do the diff fluid change for sure. Only takes like an hour for all three.
Get yourself a fluid transfer pump like this one off amazon:
https://www.amazon.com/Plews-55001-L...479232263&sr=1
worked a treat for me. Just had to pump it like a zillion times lol.
Let us know if this improves your switches after the fluid is changed.
metramm
Old 11-15-2016, 01:57 PM #216
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
sport2004,
metramm
Thanks. I will def post here whatever the result, keeping my fingers crossed it will be good news. Now, I have to call my brother to see if he will help with this...LOL
Regards, sport2004
Old 12-06-2016, 09:02 PM #217
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
(Late for) December reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 12-06-2016, 10:49 PM #218
northstarmaine07 northstarmaine07 is offline
northstarmaine07 is on a distinguished road
Toyota junk/4runner junk !!!!!!!!!!!!
I test drove five used 4runners and they all had 4wd/actuator motor issues (I needed a new vehicle). I finally found a 2007 with 57k on it in beautiful shape. I took it for a test-drive to a gravel parking-lot and it went into 4wd low as it should have. I thought I had found a good one, so I bought if for $15k in Sept 2016. I took it home and took it to a dirt road near my house and again, put it into 4wd low and exercised the TC and...it worked. Fast-forward a couple of months to our first snow-storm and I went hunting out in the country. Twenty attempts to engage 4wd low and it did all of the things all the other ones I test-drove did -blinking lights, beeping, grinding noises coming from the TC - no combination of putting my middle finger from my left hand up my ass and holding my breath -- in and out of 4wd, back and then forward, 2wd high, 4wd high - - - - nothing. I was deep in the woods and all I had was 4wd high. I was so f'ing pissed; I kept trying and it finally locked into low, with lights still flashing and the beeping, but you could tell it was in low. Well...guess what ??? It then wouldn't come out of low. I had a two hour interstate drive to get back to my house and the switch was in 2wd high...with the lights still blinking and the beeping and I couldn't do anything to get it out of 4wd low. I did every f'ing thing you can do to try and get it out. The truck doesn't even have 60k on it. UNBELIEVABLE !!!! HOW CAN TOYOTA GET AWAY WITH THIS KNOWN DEFECT ???!? DO NOT EVER BUY A USED TOYOTA 4RUNNER, 2005- 2009 !! DO NOT BUY THIS VEHICLE IF YOU PLAN TO USE THE 4WD SYSTEM. HAS ANYBODY HAD ANY LUCK WITH OUT OF WARRANTY, WARRANTY REPAIRS ? TOYOTA JUNK. 4RUNNER JUNK. KNOWN DEFECT. NEVER BUY ANOTHER TOYOTA AGAIN. TOYOTA JUNK.
northstarmaine07 is offline   Reply With QuoteReply With Quote
Old 12-07-2016, 12:44 AM #219
TrueBlue's Avatar
TrueBlue TrueBlue is offline
TrueBlue is on a distinguished road
TrueBlue's Avatar
I think you need to step back and take a breather buddy. Coming on here trying to preach to a bunch of DIY 4x4 Enthusiasts about how junk the vehicle we know and love is, it's not gonna get you anywhere.
TrueBlue is offline   Reply With QuoteReply With Quote
Old 12-07-2016, 01:30 AM #220
4Reak Show's Avatar
4Reak Show's Avatar
Had a buddy with a 4th gen 4.0 V6 and his 4WD did the same thing. Did research and to pull the shifting motor requires TC disassembly according to what I read in FSM.
I was able to remove TC fill plug and sprayed some penetrating lube all around inside. Not a WHOLE whole bunch, but aiming for the shift forks. 30 minutes later it shifted in 4WD and has worked ever since. Lucky? Or stupid? Fine line I suppose.
Old 12-07-2016, 11:27 AM #221
sprocketus sprocketus is offline
Real Name: Tom G
sprocketus is on a distinguished road
Real Name: Tom G
sprocketus,
Good luck!
metramm
Thanks for the tips, and sorry I missed your post for awhile. Mine is working ok now, and changing the fluids is definitely on my to-do list when this Illinois weather changes to spring. There are only 51k miles on this one, but I still want to change it out as soon as I can. Thanks.
sprocketus is offline   Reply With QuoteReply With Quote
Old 12-07-2016, 03:51 PM #222
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
1) 4Runner Junk? All reliability stats you can find online or otherwise will tell you otherwise, but nice try.
2) Appears as though the last owner didn't use the actuator often. These rigs "like it" when they are used with frequency (they won't bind up and not work). Mine used to take its sweet time engaging, but it does so quickly now. If you would've read this and other thread like this, you would've known.
CookieRoe is offline   Reply With QuoteReply With Quote
Old 12-07-2016, 06:36 PM #223
Kmvreter's Avatar
Kmvreter's Avatar
I test drove ...
You had your chance.
Nice first post... just sayin'
Welcome to the forum and chill.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 12-08-2016, 11:54 PM #224
Timberland's Avatar
Timberland Timberland is offline
Timberland is on a distinguished road
Timberland's Avatar
I've added an extra step to my use it or lose it regimen - the parking brake. I don't use it under normal operation unless I'm parking on a hill or parking with a heavy trailer so I figured it's good to keep it moving freely just like the 4x4 system.
So the first of every month, I cycle the CDL, 4LO, and parking brake.
2007 4runner Limited V8 (Fox 2.0 / OME 895 / MetalTech RAS delete, 285/70/17 Duratracs / Method Standards / Doug Thorley headers / Gibson Exhaust)
1991 Toyota MR2 | 2002 Harley Night Train
Canadiangearhead.com | Youtube | Instagram
Timberland is offline   Reply With QuoteReply With Quote
Old 12-09-2016, 12:47 AM #225
ColoRig's Avatar
ColoRig ColoRig is offline
ColoRig is on a distinguished road
ColoRig's Avatar
Not sayin you didn't already try this, but, did you refer to the manual? I've had mechanics tell me my 4wd is bad just because they don't understand how to engage or disengage. The beeping does sound like a plane going down and it can rattle ones nerves.
Good luck!
2003 SR5, Stratosphere Mica, Bilstein 5100's, Gunmetal Level 8 mk6 17" wheels, Duratrac 265's, Rola rack
ColoRig is offline   Reply With QuoteReply With Quote
no monthly GPS vehicle tracker pacho General Discussions 24 09-17-2023 03:07 AM
Entune Monthly Charges DannyLlama 5th gen T4Rs 40 09-13-2013 07:32 PM
Monthly Meets in Central AR ARK_SWAMP_RIDER Ozarks 57 07-10-2013 09:49 AM
Monthly payments Sprocket 5th gen T4Rs 12 12-13-2010 04:35 AM
Comcast To Restrict Monthly Broadband Use icantsee Off Topic 4 09-05-2008 01:13 PM
