01-23-2017, 02:16 PM
#241
4runner
any other maintance I should be doing on the 4wheel drive system? any fluids that should be changed?
02-17-2017, 07:16 PM
#242
Belated (mid)February reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
02-17-2017, 08:59 PM
#243
*Gear oil for front diff, transfer case, rear diff
*Lube zerk fittings of drive shaft
07 T4R Sport Edition V6 4x4
02-21-2017, 01:51 PM
#244
thnx, done, thinking about doing what I saw on youtube, guy took needle air injector hooked it to grease gun to lube sealed ball joints....
03-07-2017, 12:16 PM
#245
Belated March reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
04-01-2017, 10:18 AM
#246
New month. New reminder.
04-01-2017, 03:29 PM
#247
I have had mine for 5 months, but have not put it in 4 lo. Definitely goes into 4hi every couple of weeks however. Is that bad?
04-01-2017, 06:28 PM
#248
Not bad. When I got mine (used), they never cycled through. So my t4r didn't go into 4hi on the fly. Had to keep cycling and now it does. For 4low, I just stay on my street. But it in 4low. Roll straight 10 feet and then stop. That's all I do.
04-01-2017, 07:05 PM
#249
Bought mine used in January. Don't know if 4LO was ever used. Tried it last month just for kicks. Had a hard time getting 4LO to engage. There was a lot of beeping and a little grinding. After about 7 tries, it engaged. I now engage it once a week. No issues at all now.
2008 SR5 4WD, Window Tint, LED Interior Lights, TRD Pro Rims, Falken Wildpeak AT3 265-70-17, Cornfed 1.5/1 Spacers, New rear OEM springs, Rear Bilstein 4600
04-01-2017, 07:41 PM
#250
Mine didn't make all the noise but took awhile and several tries. You should be good with once a month now.
04-02-2017, 12:51 AM
#251
Real Name: Matt
Real Name: Matt
Dumb question....
Is it just engaging 4hi that's enough? Or will I need to engage both 4hi and 4lo? Also is it beneficial to stay in 4hi for awhile then go back to 2wd?
Thanks!
04-02-2017, 01:02 AM
#252
Real Name: Ed
Real Name: Ed
Originally Posted by theoutbackdream
Dumb question....
Thanks!
Or course it would be best if you "exercised" 4Hi and 4Lo (exercise as in drive for a while in all modes). Just engaging to 4Hi/4Lo/2wd is fine b/c the point of this, IS to make the actuator work. I switch between 2wd/4Hi and back again over a span of a few miles. I admit I should engage 4Lo more often, but getting to a dirt parking lot isn't always easy and timely. Anyway, since I've been doing this, my transfer case appears to work a lot better than before.
Hope this answers your question.
04-02-2017, 02:06 AM
#253
Real Name: Matt
Real Name: Matt
Thanks for that information. When you say that we should engage 4Lo in a dirt parking lot... Why can't we engage it on the street, and drive it under 25mph(I think thats the max? I was under the assumption 4Lo just changes the gear ratio. Not differentials... So I was thinking of engaging it in the back of my schools parking lot, and just do a few circles.
04-02-2017, 02:14 AM
#254
You don't need to do circles. I usually go straight 10-20 feet. Stop. Then lock my differentials. Go straight another 10-20 feet and then turn it all off and back to 2wd
04-02-2017, 09:49 AM
#255
Building off this. Like Madeinhb said, you don't need to go in circles. You're switching into 4hi and 4lo to get the actuator mechanism to engage. Same thing for locking the center diff.
If you do this on the street, you can go in circles as long as your center diff is unlocked. BUT, you'll need to stay in a straight line if you lock center differential. You'll cause your drivetrain to windup if you go in circles. (I found this article helpful: Click).
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
