Toyota 4Runner Forum - Largest 4Runner Forum
Toyota 4Runner Forum - Largest 4Runner Forum (https://www.toyota-4runner.org/)
-   4th Gen T4Rs (https://www.toyota-4runner.org/4th-gen-t4rs/)
-   -   4x4 PSA: Use it or lose it monthly reminder (https://www.toyota-4runner.org/4th-gen-t4rs/163282-4x4-psa-use-lose-monthly-reminder.html)
Greydog 04-02-2014 09:02 AM
Done, good thing too, first time 4 Lo beeped at me...
earthrealm 04-02-2014 12:50 PM
yeah 10miles is tough for me..as the only unpaved patch near me is about 1/4 mile!!!.....what i do is engage it daily for about a week...i know its really not enough but what can i do...had the truck for 1.6yrs now...it shifts easily
coconutpete 04-02-2014 12:57 PM
Thanks for the reminder. My actuator is less than a year old and It has been a few months since I've "exercised" it.
nevada 04-02-2014 01:01 PM
Originally Posted by BlackWorksInc (Post 1635504)
*snip
* Thus no matter what you do, you still need to foot the bill to have the transfercase removed, torn-down, and then rebuilt (in the case of adding this manual linkage system, you'll need to find a shop that is willing to do the work; some may not due to liability reasons) so you're looking at an expensive modification/repair either way. You might just be better off getting an aftermarket transfercase or even trying to adapt an FJ cruiser manual transfercase (which may be easier to be honest.)
I would have to have a tcase in front of me, but just off the pics ive seen, I think an external shift linkage could be setup using the existing shift rails.
altho, a set of dedicated rails would likely work better.
luckily, my actuator was replaced when I bought it. I think it if ever fails, i'll attempt to fabricate some sort of mechanical linkage system.
Originally Posted by BlackWorksInc (Post 1635590)
I would still exercise it in both 4Lo and CDL ON once a month, the idea is to get the actuator to move so it doesn't seize up which is what typically happens.
im pretty that before me, mine had never been shifted into low range. due to this, it was stuck. I wasn't surprised really. im just glad that because of this site I knew to check it on the test drive.
JB. 04-02-2014 01:43 PM
No significant driving in low range is necessary or advised by the owners manual.
The 10 miles per month advised in the manual is for lubricating the front drive components. It only applies to the V6 multi-mode.
This thread is about the transfer case low range and diff lock actuators which the owners manual doesn't address, but history has shown to be important.
For V6 4wd owners, the act of going into and out of 4wd, all by itself, exercises the diff lock actuator (it finishes unlocked). All that is needed is to stop at some point and put the truck into low range.
Whether there is any possible benefit to doing a little driving while in low range or also engaging the V6 diff lock via button (instead of just using 4wd), I can't say, other than the fact that more is better (with quickly diminishing returns). Perhaps @BlackWorksInc has some input on that.
BlackWorksInc 04-02-2014 08:08 PM
Honestly I just drive my V8 4WD a hundred to a few hundred feet or so in a straight line (important to keep it straight on pavement) at least once a month with the center differential locked to exercise it. While its an oft not used function, there is a mechanical linkage to lock-up the planetary gearset that makes up the central differential.
As for V6 4WD vehicles, it wouldn't hurt to do the same in 4Lo to exercise the ADD and Transfercase. We used to see quite a few 4WDs that were "fixed" by just tapping on the transfer case and then exercising the actuator a few times (easy diagnostic work :) )
Kmvreter 05-01-2014 05:54 PM
Your springy May reminder.
ebg18t 05-01-2014 06:29 PM
Thanks. Used mine yesterday in the Florida Pan handle mud.
CookieRoe 05-11-2014 06:15 PM
Switched over to 4hi yesterday thinking of this thread. She is still in 4Hi today. Haven't switched over to 4lo ever. Kinda scared to. I figure there is a chance I'll run into problems that my wallet can't rescue me from.
Of note: I did notice that before I switch over to 4Hi, while stopped, I'll put the tranny in "N", switch to 4Hi, then put her in "D". I hear the tranny "clang" into drive and hear another "thud". The 4x4 indicator then staying steadily on. BUT, when I switch over to 4Hi while on the drive or not putting it into "N", it takes awhile, as in 30seconds +, all the while the 4x4 indicator flashing. I know flashing means it's still not done fully engaging.
Is it normal for the 4Hi to engage this slow? Is it an indication of trouble?
thanks
scw1991 05-11-2014 09:17 PM
Sometimes it takes a bit longer than a few seconds to engage 4HI on my 4Runner. The ADD incorporates a yoke that slides a splined hub over a mating splined shaft. It can take a while for these splines to sinc properly before the hub slide over.
Kmvreter 05-30-2014 06:12 PM
Your June reminder.
(I'm posting early because I won't be on the site on June 1st.)
JB40 06-01-2014 12:17 PM
Originally Posted by SolRayz (Post 1667384)
I read somewhere on a recent thread that Toyota recommends running in 4Lo once a month for 10 miles or something. 10 miles!!! That unfortionately is not going to happen for some of us city dwellers.
I will usually engage 4Lo and slowly drive in my work parking lot for a minute or so. Is that adequate?
10 miles?!!! Yeaaaaahhhh good luck with that here. You'd have to get recovered 50 times on illegal mudhole trails to put that kind of mileage in around these parts.
MikeyMike 06-17-2014 12:52 AM
Exercised my CDL button today. :rockon:
zeronine 06-17-2014 10:46 AM
I had mine replaced 1 year ago? (both 4hi and low wasn't working, so they said both actuators needed replacement? Dunno much about actuators but thats what I can remember) If I didn't have my extended warranty I think it was about $700-$800 each actuator for parts and labor from dealership.
Just a heads up for anyone needing replacement.
CookieRoe 06-17-2014 11:02 AM
So $1600 for both?? Wow, sounds low. Others were being quoted 2-4K grand. It's a big job.
