Old 04-02-2014, 09:02 AM #16
Greydog's Avatar
Greydog Greydog is offline
Greydog is an unknown quantity at this point
Greydog's Avatar
Done, good thing too, first time 4 Lo beeped at me...
'07 SR5 V6, 245k miles, Shadow Mica, Fox 2.5 DSC front/Icon 2" w5100 rears, Addco sways, Method Roosts, 4Plus/RCI Skids, BudBuilt Sliders, LR UCAs, TPMS Kill, Inverter, Elite Rear Spoiler, LED reverse Fog Mod in bumper, 5K HID Lows, 3k HID front fogs, Dirty parts dual battery, UCHWM plate w/Engo 12k-S, All maintenance at GreyDog Garage.
Greydog is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 12:50 PM #17
earthrealm earthrealm is offline
earthrealm is on a distinguished road
yeah 10miles is tough for me..as the only unpaved patch near me is about 1/4 mile!!!.....what i do is engage it daily for about a week...i know its really not enough but what can i do...had the truck for 1.6yrs now...it shifts easily
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 12:57 PM #18
coconutpete's Avatar
coconutpete coconutpete is offline
coconutpete is on a distinguished road
Thanks for the reminder. My actuator is less than a year old and It has been a few months since I've "exercised" it.
Jeez Brian, where do you think you are, Caldor?
coconutpete is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 01:01 PM #19
nevada's Avatar
nevada nevada is offline
nevada will become famous soon enough
nevada's Avatar
Originally Posted by BlackWorksInc View Post
*snip
* Thus no matter what you do, you still need to foot the bill to have the transfercase removed, torn-down, and then rebuilt (in the case of adding this manual linkage system, you'll need to find a shop that is willing to do the work; some may not due to liability reasons) so you're looking at an expensive modification/repair either way. You might just be better off getting an aftermarket transfercase or even trying to adapt an FJ cruiser manual transfercase (which may be easier to be honest.)
I would have to have a tcase in front of me, but just off the pics ive seen, I think an external shift linkage could be setup using the existing shift rails.
altho, a set of dedicated rails would likely work better.
luckily, my actuator was replaced when I bought it. I think it if ever fails, i'll attempt to fabricate some sort of mechanical linkage system.
I would still exercise it in both 4Lo and CDL ON once a month, the idea is to get the actuator to move so it doesn't seize up which is what typically happens.
im pretty that before me, mine had never been shifted into low range. due to this, it was stuck. I wasn't surprised really. im just glad that because of this site I knew to check it on the test drive.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 01:43 PM #20
JB.'s Avatar
JB. JB. is offline
JB. is on a distinguished road
JB. JB. is offline
JB.'s Avatar
No significant driving in low range is necessary or advised by the owners manual.
The 10 miles per month advised in the manual is for lubricating the front drive components. It only applies to the V6 multi-mode.
This thread is about the transfer case low range and diff lock actuators which the owners manual doesn't address, but history has shown to be important.
For V6 4wd owners, the act of going into and out of 4wd, all by itself, exercises the diff lock actuator (it finishes unlocked). All that is needed is to stop at some point and put the truck into low range.
Whether there is any possible benefit to doing a little driving while in low range or also engaging the V6 diff lock via button (instead of just using 4wd), I can't say, other than the fact that more is better (with quickly diminishing returns). Perhaps @BlackWorksInc has some input on that.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 04-02-2014, 08:08 PM #21
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a jewel in the rough BlackWorksInc is a jewel in the rough BlackWorksInc is a jewel in the rough
Honestly I just drive my V8 4WD a hundred to a few hundred feet or so in a straight line (important to keep it straight on pavement) at least once a month with the center differential locked to exercise it. While its an oft not used function, there is a mechanical linkage to lock-up the planetary gearset that makes up the central differential.
As for V6 4WD vehicles, it wouldn't hurt to do the same in 4Lo to exercise the ADD and Transfercase. We used to see quite a few 4WDs that were "fixed" by just tapping on the transfer case and then exercising the actuator a few times (easy diagnostic work )
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-01-2014, 05:54 PM #22
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough
Kmvreter's Avatar
Your springy May reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 05-01-2014, 06:29 PM #23
ebg18t ebg18t is offline
ebg18t is on a distinguished road
Thanks. Used mine yesterday in the Florida Pan handle mud.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 05-11-2014, 06:15 PM #24
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe will become famous soon enough CookieRoe will become famous soon enough
MY GARAGE
CookieRoe's Avatar
Real Name: Ed
MY GARAGE
Switched over to 4hi yesterday thinking of this thread. She is still in 4Hi today. Haven't switched over to 4lo ever. Kinda scared to. I figure there is a chance I'll run into problems that my wallet can't rescue me from.
Of note: I did notice that before I switch over to 4Hi, while stopped, I'll put the tranny in "N", switch to 4Hi, then put her in "D". I hear the tranny "clang" into drive and hear another "thud". The 4x4 indicator then staying steadily on. BUT, when I switch over to 4Hi while on the drive or not putting it into "N", it takes awhile, as in 30seconds +, all the while the 4x4 indicator flashing. I know flashing means it's still not done fully engaging.
Is it normal for the 4Hi to engage this slow? Is it an indication of trouble?
thanks
CookieRoe is offline   Reply With QuoteReply With Quote
Old 05-11-2014, 09:17 PM #25
scw1991 scw1991 is offline
scw1991 is on a distinguished road
Sometimes it takes a bit longer than a few seconds to engage 4HI on my 4Runner. The ADD incorporates a yoke that slides a splined hub over a mating splined shaft. It can take a while for these splines to sinc properly before the hub slide over.
scw1991 is offline   Reply With QuoteReply With Quote
Old 05-30-2014, 06:12 PM #26
Kmvreter's Avatar
Kmvreter's Avatar
Your June reminder.
(I'm posting early because I won't be on the site on June 1st.)
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 06-01-2014, 12:17 PM #27
JB40's Avatar
JB40 JB40 is offline
JB40 is on a distinguished road
JB40's Avatar
Originally Posted by SolRayz View Post
I read somewhere on a recent thread that Toyota recommends running in 4Lo once a month for 10 miles or something. 10 miles!!! That unfortionately is not going to happen for some of us city dwellers.
I will usually engage 4Lo and slowly drive in my work parking lot for a minute or so. Is that adequate?
10 miles?!!! Yeaaaaahhhh good luck with that here. You'd have to get recovered 50 times on illegal mudhole trails to put that kind of mileage in around these parts.
2005 SR5 V8 06-09 OEM tail swap | HCF Delete | Camry Homelink Console | Ashtray door degunk | 5100s F/R (.85) | 2010 FJ coils F/R | Spraybomb Black FJ Wheels | 265/70-17 Duratrac
Planned: Upgrade JBL with BT | Aux lighting | 5k Heads | 3k Fogs
JB40 is offline   Reply With QuoteReply With Quote
Old 06-17-2014, 12:52 AM #28
MikeyMike MikeyMike is offline
MikeyMike is an unknown quantity at this point
Exercised my CDL button today.
2008 4Runner Urban Runner 4WD Titanium
Morimoto Elite 3Five 4500K | 20% tinted front windows | V-LEDS LEDs | Goodyear Wrangler A/T Adventure
2002 BMW M5 Chiaretto Red
MikeyMike is offline   Reply With QuoteReply With Quote
Old 06-17-2014, 10:46 AM #29
zeronine zeronine is offline
zeronine is on a distinguished road
I had mine replaced 1 year ago? (both 4hi and low wasn't working, so they said both actuators needed replacement? Dunno much about actuators but thats what I can remember) If I didn't have my extended warranty I think it was about $700-$800 each actuator for parts and labor from dealership.
Just a heads up for anyone needing replacement.
zeronine is offline   Reply With QuoteReply With Quote
Old 06-17-2014, 11:02 AM #30
CookieRoe's Avatar
Real Name: Ed
MY GARAGE
CookieRoe's Avatar
Real Name: Ed
MY GARAGE
So $1600 for both?? Wow, sounds low. Others were being quoted 2-4K grand. It's a big job.
no monthly GPS vehicle tracker pacho General Discussions 20 09-19-2016 07:49 PM
Entune Monthly Charges DannyLlama 5th gen T4Rs 40 09-13-2013 07:32 PM
Monthly Meets in Central AR ARK_SWAMP_RIDER Ozarks 57 07-10-2013 09:49 AM
Monthly payments Sprocket 5th gen T4Rs 12 12-13-2010 04:35 AM
Comcast To Restrict Monthly Broadband Use icantsee Off Topic 4 09-05-2008 01:13 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
