05-04-2019, 11:23 PM
#406
I do 4hi all the time but forget about 4lo. I need to that on both. The first time I did it on the 2015 Limited, which was its first time in 22k miles, it took a while and a few cycles.
This forum is a life saver.
05-05-2019, 01:32 PM
#407
Real Name: James
Real Name: James
Originally Posted by Trumpet
Warmed up the thickened grease, and the electric motors over came the mechanical resistance and poof 4lo.
Both my 4runners were bought with non functioning 4lo, and both started working over the course of the summer with persistent working of the dash switch. Took a few months of messing around, but much less expensive than paying for a unneeded repair.
Only costs time..... and if gets fubar from trying, well you were spending the money anyhow.
I have tried switching during periods of hot weather, never made a difference. However, have not tried running 4Hi over a distance, in hot weather, or for that matter repeatedly switching the CDL on/off. Correct me if wrong, but doesn't the truck need to be stopped to switch the CDL? If possible on the fly, would be risky to do at higher speeds.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
05-05-2019, 01:34 PM
#408
Activating CDL on the fly is fine, as long as you're tracking straight or on a surface loose enough to avoid binding the driveline (mud/ice/gravel/sand/etc).
05-05-2019, 08:08 PM
#409
2hi to 4hi on the fly under 62 mph
4hi to 4lo stopped in neutral
CDL on/off anytime, though best used on the lawn, snow, sand or other surface that allows slippage.
To quote that cartoon, ya got ta work it, work it.....
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
05-05-2019, 09:13 PM
#410
Real Name: James
Real Name: James
thank you, over the last few years sure i have read and forgotten that more than once...
Regards, sport2004
06-02-2019, 08:48 PM
#411
June reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
06-02-2019, 09:02 PM
#412
Thanks for the reminder. I cycled the 4WD system twice from 2WD through 4HI then to 4LO and back. Everything functioned normally including diff lock and running through all transmission gears while in 4LO.
I think this vehicle has never been shifted into 4LO before, and it has 206,000 miles. Good to know it still works.
2005 4Runner SR5 V6 4WD
06-02-2019, 09:30 PM
#413
Mine had been stuck but freed up with perseverance.
It goes easily now, but 4Lo makes a bit of a crunchy noise when it engages.
That Ok?
2008 4wd V6 Limited Xreas - 2.5/1.5 Daystar - 17" TRD Wheels w/ 255/75-17 BFG KO2's - NFAB Steps - Debadged and 5th Gen REbadged - Maplight Mod - Interior LED Swap - LaminX Yellow Fogs - Gobi Stealth - Powerstop Z36 Brakes - Husky Liners - DeWalt Bluetooth Dongle - Blackedout Headlights with LED's
06-03-2019, 05:59 PM
#414
That Ok?
The Toyota ADD 4WD's I've owned crunched going into 4LO 99% of the time, and that's with fresh gear lube. Makes you cringe when you hear it, yeah? The manual transfer case, manual front hubs were better.
Well thanks for the reminder, did the CDL, 4LO.
Donated to SoulDog Rescue - '07 Limited 4.7 4WD | Toytec Boss kit front and rear set to 2.0" in front with standard Superflex 2" lift rear coils | Firestone 9" airbags | 600W Samlex PSW inverter | Slyfox SAIP bypass | Toytec 14" rear brakelines
'08 Limited 4.7 4WD | Toytec BOSS kit front and rear set to 2.75" front standard Superflex 2" lift rear coils | SPC balljoint UCA's | Firestone 9" airbags | Slyfox SAIP bypass | Toytec 14" rear brakelines
06-04-2019, 09:52 AM
#415
Real Name: Todi
Real Name: Todi
Has anyone seen an improved mpg-s while in 4Hi on 5th gen?
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
06-04-2019, 10:25 AM
#416
You might get better responses in the 5th gen forum.
Originally Posted by Kmvreter
June reminder.
Thanks for the monthly reminder on this - I just found this thread and realized it's been years and I live in the NE where salted roads are the norm. Was thankful to hear that satisfying shift on mine.
06-10-2019, 05:27 PM
#417
Real Name: James
Real Name: James
Any tips on what finally worked?
Regards, sport2004
06-10-2019, 09:03 PM
#418
I cycled from 2WD to 4LO twice, and rode the gears up. The transmission seemed to only shift three times, or to have used 4 gears. I have a 5 speed automatic transmission.
When in 4LO, is first gear locked out, or did I not drive fast enough to achieve fifth gear? Or is fifth gear locked out? I was driving approximately 30mph around 2500rpm in 4LO.
06-10-2019, 09:16 PM
#419
Scroll back a bit.
I picked a warm day and a long freeway run to cycle though 2hi, 4hi and center diff lock on and off a bunch for about 90 minutes.
When I got off the highway, 4Lo engaged on the first try.
06-10-2019, 09:20 PM
#420
Real Name: James
Real Name: James
Scroll back a bit.
Thanks, I do remember seeing that.
Regards, sport2004
