Old 07-04-2020, 01:05 PM #496
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Well, 4Lo is flashing at me today. Went for an overnight camping trip yesterday and 4Lo and center diff lock were working yesterday. This morning, they worked for a little bit and started having issues. So I put it back into 4Hi (V8 AWD) and about 30 minutes later, 4Lo started flashing at me and now won't turn off. Just got home and tried tapping the servo housing with a hammer but still no go. So now I get to trouble shoot and hope I can get the stupid thing working again. This has me ready to sell the 4runner. The tcase shifting is far too unreliable and an FJ case swap (manual shifting) runs about $2500 for parts alone. My 1999 Tacoma is far more reliable and capable off-road.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 01:18 PM #497
4Reak Show's Avatar
4Reak Show's Avatar
That sucks. Makes me glad my 2nd and 5th gen both have a manual lever. I'm wondering if there's some trick like doing slow wide figure 8's to help shafts line up while attempting engagement. I don't own one to test that theory but it's free and easy
Old 07-05-2020, 07:51 AM #498
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
Have you checked your tire pressures? A low tire will cause issues. Simple stuff first.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 10:15 AM #499
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
No, it wouldn't.
Old 07-05-2020, 10:24 AM #500
Bigcanoe's Avatar
Bigcanoe Bigcanoe is offline
Real Name: Arn
Bigcanoe is on a distinguished road
Bigcanoe's Avatar
Real Name: Arn
Thanks for the reminder! I ran mine through the combinations on my gravel street and all seemed to work ok!
2008 4Runner Sport V8
Bigcanoe is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 12:27 AM #501
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Not sure why so many are having issues with the 4th gen 4 wd system. We might engaged our 4 hi 2 may be 3 times a year. I change the transfer case fluid once a year before snowboarding season and after 13 years and 275 k miles the 4wd has been rock solid.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 12:24 PM #502
egr13 egr13 is offline
egr13 is on a distinguished road
Originally Posted by 4Reak Show View Post
Alright so my 2016 4Runner rear diff lock does this to me too. And it's been mine since brand new, only 27K odometer. What helps me a LOT with rear diff lock engagement is slightly turning the steering wheel while driving slowly in sort of a slalom maneuver back and forth about a 10 degree turning angle. So very little. And I can hear it click right into place by the second slalom every time.
What I accredit it to is that the rear axle shafts are not aligned TOGETHER for the locking sleeve to engage. So driving forward or backward perfectly straight does nothing since that keeps axles in the same position relative to each other. The slow slalom forces the axles to spin at slightly different speeds to each other allowing the splines of whatever sleeve needs to engage to line up correctly.
I would bet a center diff lock issue could be tested the same way but probably would need a more severe turning radius since those alignment shafts are for front and rear tire speeds, not side to side tire speeds.
4Reak Show-Worked like a charm!
Muuuuuuch appreciated!!! I tried the slight turning approach and it works every time, within maybe 5 to 10 feet. Friggin brilliant.
I know differentials as a general concept on paper but I've never pulled one apart (at least not a vehicle differential). I'm not familiar with the innards of the one on our 4Runners, but I think you are dead on about why this works; just need to get the two sides rotating at different speeds so the locking coupling/sleeve/spline/whatever has a chance to align.
Everything working pretty much like clockwork now in my 4WD system.
Cheers everyone....thread bump....Use Or Lose reminder.....
egr13 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 08:58 AM #503
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
August reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:01 AM #504
Bigcanoe's Avatar
Real Name: Arn
Bigcanoe's Avatar
Real Name: Arn
Do you guys exercise "all the buttons" or only the 4LO on the 4th Gen? DAC, Center diff lock, Traction control, RSCA off are the ones I have in mind.
Old 08-04-2020, 10:05 AM #505
KLH4R3 KLH4R3 is offline
KLH4R3 is on a distinguished road
Great reminder, thank you -
KLH4R3 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:52 AM #506
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
I just do center diff lock and 4LO, but I think the biggest concern is 4LO since the 4wd actuator is what is prone to failure if you don't exercise it regularly.
I also don't have a traction control button - I think that was added in 2008.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 11:46 AM #507
xfitr911 xfitr911 is offline
xfitr911 is on a distinguished road
Good to know! When I get my ‘03 this week I’ll set a reminder for myself on my phone, especially since I can’t remember shit like this 😂🤣
xfitr911 is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 10:45 PM #508
ieatfish's Avatar
ieatfish ieatfish is offline
ieatfish will become famous soon enough
ieatfish's Avatar
I thought mine worked when I purchased the vehicle a month ago but when I tried afterward, it would just blink. I could hear the actuator whine so I knew it was functional. I spent a little while tapping the actuator and transfer case while engaging 4Lo and it didn't seem to make much difference.
However, just drove down from Portland to Phoenix this last weekend and tried the 4Lo when I reached southern CA after 8 hours of driving and with 105 degree heat. It engaged almost immediately. Tested a couple more times just to be sure and now it seems to be working great. I'll be sure to exercise it monthly to keep it working!
2006 4Runner Sport Edition 4WD V6
Dobinsons 2.5"/1.5" - C59-302, GS59-221, C59-505, GS59-705 | General Grabber ATX 265/70R17 | TPMS Bypass Mod
Custom Storage Box/Sleeping Platform Build | Dedicated Transmission Cooler (Derale D13503) | Demello Offroad Sliders
ieatfish is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 09:33 PM #509
Kmvreter's Avatar
Kmvreter's Avatar
September reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 10-03-2020, 02:49 PM #510
Kmvreter's Avatar
Kmvreter's Avatar
October reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
no monthly GPS vehicle tracker pacho General Discussions 24 09-17-2023 03:07 AM
Entune Monthly Charges DannyLlama 5th gen T4Rs 40 09-13-2013 07:32 PM
Monthly Meets in Central AR ARK_SWAMP_RIDER Ozarks 57 07-10-2013 09:49 AM
Monthly payments Sprocket 5th gen T4Rs 12 12-13-2010 04:35 AM
Comcast To Restrict Monthly Broadband Use icantsee Off Topic 4 09-05-2008 01:13 PM
