09-02-2015, 04:58 PM
#91
Real Name: Larry
Real Name: Larry
Thank god I noticed this thread a couple month ago, bought my 4runner late may... All in all whoever had the vehicle before me never used any of these features and it took forever to engage 4hi & 4lo. Now I try to switch from 2hi to 4hi on occasion while driving a descent speed, while stopped I will go into 4lo and use the diff button... they all work much better now so whoever said it first use it or lose it.
Thanks!!!
Larry
2007 4RUNNER LIMITED 4.0 V6
DRIFTWOOD PEARL
Xenon Depot 4300k Philips HID Kit
Weathertech floor mats
09-17-2015, 01:05 PM
#92
Real Name: Ed
Real Name: Ed
yeeeeeeeeeeeeeeeeeeeeeeeeeeee hawwwwwwwwwwwwww
I recently moved to another complex and it has some dirt/stone road that is under construction. Perfect surface for trying 4Lo. I didn't have access to such a road in the past.
Anyway, after dropping off my daughter in school, I headed to the small stretch to try out 4Lo. Totally anticipating "beeping" and with a mallet in hand, I didn't expect it to engage.
It did. Took about 2 seconds. Didn't hear any beep. I even tried locking the diff. According to the idiot light, it engauged. Turning it off however took about 10 seconds. Very happy to say the least. I'll be doing VERY OFTEN from now on.
When I had my Heap Grand Cherocrap, engaging 4Lo was via a handle and you KNEW it engauged. It would always grind into gear and throttle response was "touchy". Not so with the 4Runner. Smooth operation.
Goddamn I love my truck!
09-17-2015, 04:03 PM
#93
Crap I never switch to 4Lo. I really need to do that. Whats the best way to do this safely? Do I need to find an empty dirt lot somewhere? Also, every month when I switch from H2 to H4, it grinds a little before engaging...is this normal?
07 V6 Limited 4WD; FJ Springs + Bilstein 5100's
16 Lexus GX460
09-17-2015, 04:30 PM
#94
Real Name: Greg
Real Name: Greg
You can switch to 4Lo anywhere. Must be in neutral though.
09-17-2015, 05:44 PM
#95
Real Name: Matt
Real Name: Matt
To switch to 4Lo, you have to stop, put the transmission in neutral, then switch. You can try the same for going from 2Hi to 4Hi if it won't shift on the fly.
You can drive in 4Lo on pavement. The center differential is still unlocked, so you can turn normally, but the engine will rev higher because of lower gearing, and there will be more engine braking. You can actually get up to about 50-60mph if you want, but you probably won't want to.
You can also lock the center differential on pavement, but I strongly prefer to only do that if I'm going in a straight line. I don't like the drivetrain binding up. People with less sophisticated transfer cases (most 5th gens, for example) will tell you it's not a problem, but I don't like it.
2007 V8 Limited 4WD
09-17-2015, 05:47 PM
#96
Real Name: Matt
Real Name: Matt
Do you shift while moving? I don't think I've noticed grinding going from 2WD to 4WD, just a clunk sometimes, the times I've driven a V6 model. I almost always do that shift while moving. I have had grinding going from 4Hi to 4Lo once, and apparently that is somewhat normal.
2007 V8 Limited 4WD
09-17-2015, 06:23 PM
#97
I shift it into 4Hi while sitting stopped at a light, and slowly accelerate as I wait for it engage. After about 5 seconds or so of moving, I hear a grinding noise and then the light stops blinking, confirming that it has successfully engaged into 4Hi. My understanding is that this is normal, except I have heard every time I've done it, which is monthly.
16 Lexus GX460
09-30-2015, 08:14 PM
#98
Here's the October reminder.
10-01-2015, 03:25 PM
#99
Thanks for handling that, early.
I still try to add reminders in order to increase my post whore count (like I just did.)
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
10-02-2015, 04:33 PM
#100
Back at ya man.
10-02-2015, 05:35 PM
#101
Just did this again myself. Good reminder. No beeps -- 4lo & 4hi like a viking.
Current: 05 GX470
Past: 2002 SR5 Sport, 2007 SE V6, 2015 TEP, 2008 SR5
10-02-2015, 05:55 PM
#102
Originally Posted by CookieRoe
Holy crap that thing is spotless!
2005 4Runner V6 Limited 4WD Pacific Blue Metallic: Bilstein 5100 + Moog FJ Springs front, Superflex rear, OEM LED tails, Dinoc woodgrain conversion, Kenwood DDX371
10-03-2015, 12:13 AM
#103
Works in neutral, not park, correct?
10-03-2015, 12:41 AM
#104
Real Name: David
Real Name: David
4x4 PSA: Use it or lose it monthly reminder
Used 4LO today to move this Pig of a trailer, barely needed to give it gas.
2006 T4R Sport 4WD V6 - Bilsein 5100 Shocks, Toytec 2.5" lift front coils, SuperFlex rear coils, Toytec front diff drop, Icon sway bar relocation block - BFGoodrich AT KO2 275/70/17 - Spidertrax 1.5in wheel spacers - DDM 6k low beam headlights & 6K dually ditch lights - Scion FRS radio - Custom rear sway bar end links
Build Thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
IG: Davy180
10-03-2015, 11:44 AM
#105
The rear is sagging. Did you use a WDH or something to level the back? Hope the tow was a short distance.
2005 4Runner 4x4 Sports Edition
Bilstein 5100 + FJ Coils front and rear | 1.5" Daystar Spacer Rear | Airlift 1000 Airbags | Hayden 678 Tranny Cooler | Cheap LED Interior Lights | BudBuilt Front Winch Plate | Engo 10K Winch
