02-16-2015, 06:48 PM
#61
Does anyone think they will make a recall for this? Seems widespread...
03-01-2015, 05:42 PM
#62
March reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
03-01-2015, 09:36 PM
#63
Real Name: Ed
Real Name: Ed
Yes Sir, thank you!
04-01-2015, 06:13 PM
#64
April (bright spring) reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
05-01-2015, 09:52 AM
#65
May reminder.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
05-01-2015, 10:11 AM
#66
Originally Posted by Kmvreter
May reminder.
Thank you!
N0ob question: Is it bad to drive in 4WD 100% of the time??
05-01-2015, 01:09 PM
#67
thanks @kvmreter, got thw wifes and I done yesterday for this.
@ paperchasin
. No.
05-01-2015, 01:13 PM
#68
@ paperchasin
. No.
Thanks!
05-01-2015, 01:28 PM
#69
2007 SR5, V6, Shadow Mica, Toytec Boss, 265/70/17 Terra Grapplers, Rocky Road Super Sliders
05-01-2015, 06:57 PM
#70
Real Name: Jon
Real Name: Jon
im always in 4x4
05-03-2015, 08:27 PM
#71
Real Name: Rob
Real Name: Rob
Here is a friendly Public Service Announcement:
Engage all your 4x4 features once a month and your truck will thank you for it by avoiding a hefty repair bill. A few minutes of free exercise every month will save you big $$$ in actuator repairs.
Great advice, thanks. When I bought my '07 SR5 about six weeks ago, I took it off road right away to put it through it's paces. It went into H4, L4 and CDL with no problems, but I noticed it took a couple of tries to get out of L4. I did exactly what the manual said, and came to a stop and put it into neutral, but when I switched out of L4 it would just beep, with the 4WD lights flashing I think, for about 20 or 30 seconds with no luck. I remember hoping that I had enough gas to get home in 4L, but I tried switching back into 4L and back out again, and the second time it came out after a few seconds. I repeated the process a little while later and the same thing happened, taking two tries to get out of 4L. I checked the manual again later to see if I could find any more information on this, and it does actually tell you to drive forward and backward a short distance if it won't go in or out of L4, so I'm not sure if what I was experiencing was normal, or the result of the 4WD not being used regularly before I bought the truck. Regardless, I will be exercising the 4WD system regularly now after reading your post.
05-03-2015, 08:45 PM
#72
Real Name: Rob
Real Name: Rob
Originally Posted by paperchasin
Thank you!
From what I've been told, it's OK to be in H4 all the time except that your gas milage might suffer a bit, but you don't want to be in Center Diff Lock on dry roads. Anyone else?
05-06-2015, 10:55 AM
#73
tried switching into 4lo yesterday...and the truck made a harsh whirling sound...i was in 4hi and center diff locked then..on rough terrain....i quickly put the car in park and switched back to 4hi, and disengaged center differential......
i then tried again and it switched smoothly to 4lo.........similar thing had happened in the past before...still yet to under why it happens or the causative factor
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
06-01-2015, 08:31 PM
#74
Real Name: Lance
Real Name: Lance
June reminder
2004 Sport Titanium Metallic, Black WeatherTech Mats, J.A.'s Map Light Mod, 2014 Scion Pioneer Bespoke touchscreen w/ Back Up Camera, Arc Audio xdi805 amp, Handsfree phone/bluetooth steering wheel controls, 06-09 OEM LED tail lights, Interior LED Swap, Gentex 177 AutoDimming Mirror w/ Amber Compass, Sunvisor GPS mod, Avitol 4003 Remote Start w/ factory keyfob, J.A.'s DRL Mod, Back Window Up Hack, OEM 115v AC inverter install, Smokers Kit
06-03-2015, 01:26 AM
#75
My thing isn't so much switching between 2/4wd but with the center differential sometimes taking a few tries in and out of drive/neutral
2007 LIMITED 4WD V8
Salsa Red Pearl
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
