Old 06-09-2018, 02:39 PM #1
Toyota Jim's Avatar
Toyota Jim Toyota Jim is offline
Toyota Jim is on a distinguished road
Toyota Jim's Avatar
2008 TPMS bypass
Since my google searches didn't come up with anything for 07 and up, and I was tired of my TPMS light being on, I got to work. I figured I'd share what I did on my 4Runner to see if it helps anyone else. Obviously try at your own risk, I accept no responsibility... blah, blah, blah.
Here's the wiring diagram. The pink/black is still the TPMS light wire (pin 5). The black/red is the 12v IGN source into the TPMS module (pin 7).
I cut the pink/black wire and connected the harness end to the black/red wire. Basically, I'm putting 12v on either side of the dash light, so it can't complete the circuit and light up.
This instantly turned off the flashing light on the dash for me. I haven't noticed any negative effects from doing this, nor should it drain the battery, because it's an IGN hot.
I hope this helps!
-08 Urban Runner
Toyota Jim is offline   Reply With QuoteReply With Quote
Old 06-09-2018, 03:13 PM #2
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Wouldn't it have been easier to just pull the bulb out of the dash? Or cut the power wire going to the bulb so it doesn't see power at all?
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 06-09-2018, 03:31 PM #3
Toyota Jim's Avatar
Toyota Jim's Avatar
One screw compared to pulling the instrument cluster out? I think this was easier.
-08 Urban Runner
Old 06-09-2018, 06:28 PM #4
Real Name: Chris
Real Name: Chris
Just not a fan if twisting wires together like that. You would likely have had the same result by just cutting the feed wire to the bulb, no? That or buying new TPMS sensors of course.
Old 06-09-2018, 06:30 PM #5
Toyota Jim's Avatar
Toyota Jim's Avatar
New TPMS wasn't in the cards. I also soldered this before I taped it up. Sorry I didn't explain that.
-08 Urban Runner
Old 06-09-2018, 06:35 PM #6
Real Name: Chris
Real Name: Chris
There's nothing wrong with the connection and I get the cost of TPMS sensors can be insane unless you find a deal on ebay or something. You said you're sending power to both legs of the bulb. If you were to just cut the one wire that powers the bulb and not splice into anything else, wouldn't that shut the light off also?
Old 06-09-2018, 06:38 PM #7
Toyota Jim's Avatar
Toyota Jim's Avatar
Yes it would. However, one screw under the glove box was an easier option than chasing a harness behind the instrument cluster.
-08 Urban Runner
Old 06-10-2018, 08:04 AM #8
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
Write-up: How to Disable (Bypass) the TPMS
(The search tool on this site is not the best.)
The TPMS sensors I have had last over 10 years.
I chose to keep my TPMS systems functioning properly on each of the vehicles with the help of an Autel TPMS tool.
PSI/temp data is available off the sensors. Data can be viewed from an ....(eg. Pioneer NEX with idatalink Maestro)
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
Old 06-10-2018, 03:02 PM #9
Toyota Jim's Avatar
Toyota Jim's Avatar
That write up I found, but it doesn't work on my truck.
-08 Urban Runner
Old 11-23-2018, 01:54 PM #10
StaticKlingon's Avatar
StaticKlingon StaticKlingon is offline
StaticKlingon is on a distinguished road
Followed Toyota Jim's directions above on an '08 Sport and so far it's worked like a charm. New SCS Ray 10's on the UPS truck for delivery today. No need for TPMS sensors when I have them mounted.
StaticKlingon is offline   Reply With QuoteReply With Quote
Old 11-23-2018, 03:53 PM #11
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
Nice, thanks for sharing!
CookieRoe is offline   Reply With QuoteReply With Quote
Old 11-24-2018, 11:54 AM #12
Toyota Jim's Avatar
Toyota Jim's Avatar
Glad it works for you guys!
-08 Urban Runner
Old 11-24-2018, 07:07 PM #13
SummitRunner SummitRunner is offline
SummitRunner is on a distinguished road
Thanks, I'll have to try this soon
SummitRunner is offline   Reply With QuoteReply With Quote
Old 11-25-2018, 08:41 AM #14
LoneDeRanger's Avatar
LoneDeRanger LoneDeRanger is offline
LoneDeRanger is on a distinguished road
So.... You just took ground away from the bulb?
And the computer does not care about the tpms?
It only activates the dash bulb? Not a check engine light or anything?
2008 4Runner Limited 4WD Nav/cam/Jbl/V8 4.7L
LoneDeRanger is offline   Reply With QuoteReply With Quote
Old 11-25-2018, 09:51 AM #15
Toyota Jim's Avatar
Toyota Jim's Avatar
Correct.
-08 Urban Runner
TPMS light bypass switch Kmvreter 4th Gen T4Rs 84 07-28-2023 07:31 PM
Write-up: How to Disable (Bypass) the TPMS txt4r 4th Gen T4Rs 343 10-29-2022 11:00 PM
5th gen TPMS Bypass help ABDave 5th gen T4Rs 19 12-28-2020 02:34 AM
TPMS Bypass for 5th gens. hearno 5th gen T4Rs 45 08-02-2018 08:40 PM
TPMS Push Button Bypass Switch slimjj 4th Gen T4Rs 9 11-04-2016 03:56 PM
