Old 03-07-2014, 01:13 PM #1
Ginneta's Avatar
Ginneta Ginneta is offline
Ginneta is on a distinguished road
Ginneta's Avatar
05 Traction lights & check engine lights on
Ok, I've read several threads about misc lights but I'm looking for some advice specific to my issue. Monday morning I filled up the gas tank and drove to work, stopped at the gym and then home. So my truck was turned on and off several times after the fill up. Tuesday morning I get in my truck and all of the traction lights are on and the check engine light. I jumped on here and read a thread that said I should tighten my gas cap and disconnect the negative battery terminal to reset the lights. Done all that on Tuesday afternoon. The lights went away and now Friday morning THE LIGHTS ARE BACK. I have noticed my MPG from 18.5 to 16.5, but was thinking maybe since the battery was disconnected the MPG's were reset and the reading isn't so accurate. There is no stalling or idle issues. The gas cap does come loose by just barely turning it. Change the gas cap? Get the codes read? I'm learning as I go when it comes to maintaining and minor repairs so any advice is appreciated. BTW if it matters my 4Runner is an 05 4X4 SR5 with 190k miles.
-- Ginneta
2005 Toyota 4Runner SR5 V6 4X4 // Aftermarket Factory Sport Hood // Pionneer AppRadio 2 with JBL Amp & Speakers
Ginneta is offline   Reply With QuoteReply With Quote
Old 03-07-2014, 01:39 PM #2
HokieRunner's Avatar
HokieRunner HokieRunner is offline
Real Name: Matt
HokieRunner will become famous soon enough
Real Name: Matt
I know it's the trendy thing to replace or tighten a gas cap when CEL and TRAC lights come on. But in reality, the first thing you should do is get the code(s) read. Most auto parts places will do it for free. Or buy a $20 one and keep it in the glove box.
There are many issues that can trigger the CEL/trac light so get the code read. It usually is cheaper and less time consuming than guessing what the issue is
Post up the codes once you know them and I'm sure the forum can point you in the right direction!
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
HokieRunner is offline   Reply With QuoteReply With Quote
Old 03-07-2014, 02:15 PM #3
Ginneta's Avatar
Ginneta's Avatar
thanks Hokie!! as soon as i read your message i left work and headed to Auto Zone. Here is the read results. Hoping it is the gas cap and not one of the other issues listed!!!
05 Traction lights & check engine lights on-code-results-jpg
-- Ginneta
Old 03-07-2014, 02:56 PM #4
Real Name: Matt
Real Name: Matt
Nice! Gas cap seems to be the common fix for that code. Glad it wasn't something expensive! Let us know if the gas cap def. fixes it.
Old 03-07-2014, 08:11 PM #5
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Good to Read Up On:
Check Engine, TRAC, AND/OR VSC On? Read Me!
Its always a good idea to pull the codes from the vehicle, typically this can be done for free and should always be your first step in diagnosing any MIL related issue, otherwise you're just flying blind and throwing shit at a wall and hoping something sticks.
As for the P0456, its not typically the DTC you'd see for the gas cap, usually that is a P0455. But at this point I'd feel okay with either tightening the gas cap and/or replacing it and checking again.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-07-2014, 09:58 PM #6
CXS CXS is offline
Real Name: Chris
CXS will become famous soon enough
CXS CXS is offline
Real Name: Chris
I remember it as a P0441 error that I get about once a year and replacing the cap takes care of it. Just replaced another one two weeks ago and it's eliminated the error again.
Chris - '07 SR5
‘05 Limited - sold
CXS is offline   Reply With QuoteReply With Quote
Old 03-07-2014, 10:08 PM #7
Holy crap, that's a pretty regular failure rate for gas caps.
Old 03-08-2014, 12:17 AM #8
CXS CXS is offline
Real Name: Chris
CXS CXS is offline
Real Name: Chris
My thought exactly, I guess I'm resigned to Toyota caps failing regularly (engineered obsolescence?). Maybe I should try a generic one instead.
Chris - '07 SR5
‘05 Limited - sold
Old 03-11-2014, 04:44 PM #9
asimdada asimdada is offline
asimdada is on a distinguished road
I had the same P0456 (VCS lights, VSC TRAC and CEL ON). I didn't need to change the gas cap though. Just tightened it and reset the CEL with a scan meter and its been all good. Guess I didn't tighten it enough after my last fill.
2006 Toyota 4Runner SR5 "STOCK" 4.7L V8, leather, 3rd row seat, DDMTuning HID's, Interior LED's
asimdada is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 04:10 PM #10
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Haha it seems like that's all I read about is gas caps on any abs related problems. I can't get my issues solved because that's all anyone seems to know.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 02-26-2022, 03:49 PM #11
I mean the gas caps do seem like you might as well replace them every oil change... So I don't entirely blame people for defaulting to that, but getting in that habit of just knee-jerk going after a cap before you even know why the MIL was set is a bit silly IMHO.
Old 02-27-2022, 09:47 AM #12
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
I bought a $20 Hyper tough code reader at Walmart tightened gas cap then using the code reader reset the check engine codes.
Why I get the skid control flashing I feel is Toyota trying to get one to their service departments.
Auto Zone reading peoples check engine codes is how they sell lots of parts some needed but many they don’t.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 02-27-2022, 12:17 PM #13
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
maybe changing my fuel cap will turn off my brake lights!
rwh963 is offline   Reply With QuoteReply With Quote
Old 02-27-2022, 12:18 PM #14
also, i have read that you should not "top off" the tank. i think it messes with the emissions components in the tank area.
Old 02-27-2022, 07:32 PM #15
Jakeepoo3's Avatar
Jakeepoo3's Avatar
😆 Hey buddy did you get it sorted out yet!
Check Engine + VSC OFF + VSC Traction lights all came on?! Bamboozler 3rd gen T4Rs 6 01-24-2017 04:40 PM
New tires: Check engine/traction control lights on BPo001 4th Gen T4Rs 12 04-18-2013 11:06 AM
vsc, vsc off, traction control light, check engine lights Dunk50 General Discussions 1 10-26-2011 06:22 PM
'check engine', 'trac off', and 'vsc' lights came on. Plus 'abs' and 'brake' lights thehadley4 3rd gen T4Rs 0 10-23-2011 01:51 PM
'08 4Runner check engine/vsc/traction control lights Ant3_16 4th Gen T4Rs 2 03-11-2009 12:32 AM
