Old 01-07-2017, 10:03 PM #31
mgson's Avatar
mgson mgson is offline
mgson is on a distinguished road
mgson's Avatar
Originally Posted by Kmvreter View Post
@mgson What product did you use and is it compatible with the Super Long Life Coolant? Keep us posted if things change.
I used the bars leaks head gasket sealer, and I'm issuing the long lasting Toyota coolant. So far it's holding up awesome! Took a few longs trips, drive it to work every day and went off-roading.
mgson is offline   Reply With QuoteReply With Quote
Old 01-10-2017, 07:38 PM #32
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
@mgson
Bar's Leaks has several products. Can you be more specific on which product?
Thanks.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 01-10-2017, 08:30 PM #33
mgson's Avatar
mgson's Avatar
@mgson
Thanks.
Yea sure it was this one
https://www.amazon.com/Bars-Leaks-11.../dp/B0036VRQ70
Old 01-18-2017, 05:39 PM #34
mgson's Avatar
mgson's Avatar
Originally Posted by happy camper View Post
Great to hear this worked. Still no negative results? I'm about to give this a try.
275,000 miles on this otherwise bulletproof 4R. Love this truck, but I'm getting the classic symptoms and lights. I did replace radiator 3 months ago as I was really consuming coolant. After that no discernible coolant loss.
Nope no negative results to report. I've been off-roading in the snow lately and have really put my truck to the test. I can't say it'll work in every scenario but it won't hurt to try. I plan on an engine rebuild but more towards the end of the year.
Old 02-17-2017, 07:26 PM #35
Kmvreter's Avatar
Kmvreter's Avatar
FYI That product is branded as Rislone Gasket Fix up north here.
Previously I had slow coolant use (~250ml or 1 cup per month), the odd stumble on cold starts and a wet #6 spark plug (although no codes were thrown.) It's been over a month since I used this Fix and have had zero coolant use. No intermittent stumbles. I will report back after I do the next plug change or if things change.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 03-17-2017, 05:25 PM #36
_Zort_ _Zort_ is offline
_Zort_ is on a distinguished road
'05 4.0 at 170k - too old to replace HG?
This particular thread has proved to be the most current and on-point for my situation. Thanks to you guys for sharing your knowledge and experiences!
My 4.0 V6 is in an '05 Taco, and it has the classic symptoms of the head gasket issue, including coolant in cylinder 4. Local shop (Kelly Clark) says at 170K it's asking for trouble to replace the HG. The bottom end would likely develop problems soon after, they say. Thoughts on this?
My girlfriend has an '08 4Runner, so I'm wondering if we'll end up in this situation again with her truck.
I am original owner of the Taco, have all the regular maintenance done, don't abuse it, and I was really hoping to get 250k out of this Toyota. Is it really a bad decision to replace the HG now at 170k? I won't be doing the work myself, so it wouldn't be cheap. Other options would be to buy a used low-mileage motor from a yard and have someone install it. Also not cheap Looks like a used motor is about $2500 or so), but this might be a better long-term solution? Finally, I suppose there's always the cheap HG Fix attempt.
Again many thanks for your previous posts and any additional thoughts or knowledge you might share.
Zort
_Zort_ is offline   Reply With QuoteReply With Quote
Old 04-23-2017, 04:53 AM #37
markeike's Avatar
markeike markeike is offline
markeike is on a distinguished road
markeike's Avatar
Wondering about 4.0 V6 and Head Gasket @#6 "issue"
Has anyone here had the head gasket/cylinder #6 issue with an '06 or later? It sounds like this was an issue with earlier models and may have been fixed sometime in '05?
Mark
1998 4Runner SR5, Desert Dune, No Major Mods.
markeike is offline   Reply With QuoteReply With Quote
Old 04-25-2017, 08:30 PM #38
05toyrun's Avatar
05toyrun 05toyrun is offline
Real Name: John
05toyrun is on a distinguished road
05toyrun's Avatar
Real Name: John
The plugs need to be changed that frequent?? My manual says 160k or something close to that number.
2005 TOYOTA 4RUNNER V6 LIMITED.
05toyrun is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 08:12 AM #39
kcdehart's Avatar
kcdehart kcdehart is offline
Real Name: Kevin
kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough
kcdehart's Avatar
Real Name: Kevin
Zort
I'm not sure about the age issue, but your girlfriend's 4 Runner should be fine. They updated the headgasket design somewhere in the '05-'06 years, and those supposedly no longer have the tendency to leak
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
kcdehart is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 12:27 PM #40
4unnerftw's Avatar
4unnerftw 4unnerftw is offline
Real Name: Carl
4unnerftw is on a distinguished road
4unnerftw's Avatar
Real Name: Carl
My 2006 had the head gasket replaced by previous owner, but it was actually built in 05 (maybe before they changed the design).
When I start it, it does have a few very quick small vibrations here and there which now have me worried. I'll take a look at the coolant and make sure it isn't losing coolant. This is really freaking me out now.
Maybe i should try that sealer.
4unnerftw is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 12:58 PM #41
kcdehart's Avatar
Real Name: Kevin
kcdehart's Avatar
Real Name: Kevin
Don't use the sealer unless you're sure the HG is bad and you don't have the money to properly fix it. I was talking to a mechanic friend when I thought mine was bad and asked about the sealer. He said to absolutely not do it, as it will clog other parts of the cooling system and can seep into the head and cause issues, apparently. It's the last resort when you know your engine will be toast otherwise
Old 04-26-2017, 01:14 PM #42
4unnerftw's Avatar
Real Name: Carl
4unnerftw's Avatar
Real Name: Carl
ok, thanks for the advice. Sounds like monitoring coolant and then a compression test would be the way to go.
Old 04-26-2017, 01:16 PM #43
kcdehart's Avatar
Real Name: Kevin
kcdehart's Avatar
Real Name: Kevin
Yeah, also test for exhaust in the coolant. I did that test 3 times when I thought mine was bad and it came back negative each time. It turned out to be a clogged radiator that was making it overheat and spew coolant out of the overflow
Old 08-18-2017, 11:41 AM #44
Spy017 Spy017 is offline
Spy017 is on a distinguished road
Replacement of 05 4Runner HG
Hi Everyone.
I just had my HG replaced (05, 2WD 4Runner). It all started from a P0300, P0302, P0304 and P0306 codes, with rough idling for some seconds at every start up. Also, I was beginning to loose an appreciable quantity of coolant.
However, in the process of coupling the top cylinders back, one of these sensors got broken.
Can anyone please tell me what these are called, and their function?
Thank you. (I am new to this thread).
https://photos.google.com/photo/AF1QipOEVo523d3u6zSVcGmExdKQIc7YvlROSFIbKmN8
Spy017 is offline   Reply With QuoteReply With Quote
Old 09-14-2017, 09:17 AM #45
mcfly0913's Avatar
mcfly0913 mcfly0913 is offline
mcfly0913 is on a distinguished road
mcfly0913's Avatar
Originally Posted by blackmax View Post
sorry for kinda long.....
So, P0306.....it seems to be something of a "known issue" for the 4.0 liter engine. with higher miles. However, it's also true that reading a forum can make things look more prevalent than they really are. If 8 people all come on and say "Yea, me too"...it sounds epidemic. But maybe it's just 8 out of 300,000. Or maybe it really is a problem and needs to be considered.
Anyway,it seems that quite a few people have complained that they got the dreaded P0306 code (misfire in #6). Many then took it to the dealership who promptly nailed them for a "tune up" including plugs and a coil....only to eventually get to the real problem- "your head gasket failed at #6; and it's leaking coolant into the cylinder. You're F'd." It seems as if ALL of these people were at 120,000 - 160,000, with the majority seeming to be right at 150,000 miles.
Symptoms beside the code would be rough (as if missing a cylinder) at startup, especially after sitting for while.
I'm wondering if most or perhaps ALL V6s over 100k miles have this leak, but it's so small that it simply isn't noticed (yet); plus, it seals back up very quickly after startup, due to the intense combustion temps? After reading all the post on this subject, I'm convinced that mine has had this small leak for 100k miles now. It must just be soooooo small, that it hasn't become (and perhaps never will) a major issue. Why do I think I have a small leak, and have for long time? Here's what I've experienced-
1- maybe 10 times since I bought my truck (10 years ago) it shuddered for 5 seconds after startup....but later smooth out.
2- a couple times in summer, while climbing a hill, I could see white smoke in my rear-view mirror. Why it's only happened 3 times (that I know of)....I can't say. But I know it did happen.
3- And this is the big one for me: I pulled all the plugs. They ALL look exactly the same......except #6! It had significantly more deposits on it (not black).
Now, like I said, I'm wondering if perhaps most 4.0 engines have some leakage at #6 (seems it's an admitted design flaw, and Toyota has changed the HG design, as I understand it), but since the leak is so small, the owner is just unaware. So the real question is- how many drivers have over 175,000 miles on their 4.0 and have not seen the CEL come on, and find out it's P0306?
Sorry for the length....but this could be a serious issue for people wanting to get high-miles out of their 4Runner, like me. I wonder if:
1- everyone with over 100k miles on their truck pulled the #6 plug plus any other plug....if they'd see an obvious difference with lots more deposits on #6? or,
2- not that many would, and the real truth is that though HGs will fail on our engine, just like any engine, it's just that when it does n ours, it happens at #6.
Again, sorry for the length.
I just bought my '06 V6 Sport with 149,000 miles on it. No problems as of yet.
mcfly0913 is offline   Reply With QuoteReply With Quote
Mechanic to fix head gasket issue Smkg 4th Gen T4Rs 9 12-24-2013 06:03 PM
2004 V6 head gasket issue? woff32 4th Gen T4Rs 3 05-14-2013 03:50 PM
Is the head gasket an issue in the 2007 v6? jnat306bg 4th Gen T4Rs 0 03-27-2013 10:13 PM
Just joined the "Head Gasket Club" Coctailer Classic T4Rs 19 05-25-2012 05:10 PM
"sniffer" says bad head gasket - believe it? iamburanto Classic T4Rs 4 09-15-2006 03:02 PM
