03-08-2014, 06:06 PM
Again with the Leaks!
I was looking around the underside of our 4runner today when I discovered treachery.
I have no time in the next 10 days. Is this leak so bad that it needs to be corrected immediately or do you think I can wait til late next week? Thanks for the opinions!
1999 4runner highlander model, 5-speed
03-08-2014, 06:29 PM
If that was my vehicle I'd crawl under there and figure out the source and then fix it asap without driving it (much). It may be a band, it may be a tear (can't tell from the pictures... )... good luck. If it continues to leak like that (regardless of the source) you may end up buying a cv axle instead of a boot band.
in case you need it after the milkshake gets cleaned up.
best case: Replacing CV bands - Toyota 120 Platforms Forum
intermediate stop gap/ tear containment: RESCUE TAPE Self-Fusing Silicone Tape: Amazon.com: Industrial & Scientific (if it turns out you have a tear this stuff ma get you by until you can get it replaced....)
worse case: http://lotusdevelopmentllc.mybigcomm...nd-gen-tacoma/
Current: 17' GX460 Luxury with DSP, Nightfall Mica / Black
Sold: 05' 4R Sport v6, 07 4R Limited v6
03-08-2014, 08:07 PM
Real Name: Leonard
Real Name: Leonard
Looks like a loose band and the boot is pulling back.
Clean up will definitely tell.
Having fun's build
03-08-2014, 09:30 PM
Looks like the band is loose and cocked to one side a bit. Clean it up, install a new band if it looks good and see how it goes.
03-08-2014, 10:07 PM
Real Name: Leonard
Real Name: Leonard
And re grease.
Having fun's build
03-08-2014, 10:43 PM
And re grease.
Yes that too... lol Having Fun making me look bad!
03-09-2014, 12:26 AM
Real Name: Alex
Real Name: Alex
And re grease.
2 things:
1. Do this, but I'd suggest re-booting at the same time, as it's not that expensive to do, and re-banding/re-positioning the band may not solve it, because the band may have gotten moved by slipping due to a (not obvious) tear.
2. Everyone remember this day.
@ BlackWorksInc
, our go-to for servicing advice, has been shown up. PSA: Our new official go-to is
@ having fun
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
- Helpful DIY Videos
03-09-2014, 01:00 AM
Real Name: Leonard
Real Name: Leonard
And since where being CERTIFIED now. I would personally get some marine stainless steel hose clamps to re clamp with.
There's a thread in here somewhere about them. Napa sells the grease packs with the right amount of grease (4oz.) for each side also. How do I know, been there done that.
@ Stuck CAPS
- I'll let you have the credit on the research on the bands when you find the thread.
Having fun's build
03-09-2014, 02:18 AM
@ Stuck CAPS
^^^This. I did exactly this probably 1.5 yrs ago and its holding up perfectly.
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
03-09-2014, 12:18 PM
Real Name: Alex
Real Name: Alex
@ Stuck CAPS
Here.
@ having fun
Pay up.
03-09-2014, 01:15 PM
Real Name: Alex
Real Name: Alex
I may get some long red boots for my 4wd conversion. they do look quite nice :P And longer seems helpful.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Leaks
ASUMTNEER |
4th Gen T4Rs |
3 |
06-13-2013 08:01 PM |
Oil Leaks
jaybirdy2k |
Classic T4Rs |
14 |
04-27-2012 03:28 AM |
Leaks all over
rbdhd |
3rd gen T4Rs |
7 |
04-02-2012 10:14 PM |
93 leaks
kroo88 |
Classic T4Rs |
4 |
04-21-2011 11:58 AM |
oil leaks
4ballin |
3rd gen T4Rs |
1 |
02-02-2010 11:22 PM |
