Old 08-26-2014, 09:35 AM #16
superman3043's Avatar
superman3043 superman3043 is offline
Real Name: PD
superman3043 will become famous soon enough superman3043 will become famous soon enough
Real Name: PD
I wanted to update and revisit this issue. I just rebuilt my lower control arms with fresh bushings and ball joints and replaced my outer tie rod ends. After alignment, still no real improvement. Could be because I added some wheel spacers and increased my offset.
I read up on tramlining. Thanks Gecko! Seems like you were spot on with that issue. I've got so many factors that would contribute to tramlining; Soft tread, stiff sidewalls, wide tires, large worn tread blocks, larger wheels and tires with increased offset. I've experienced the issue even on a stock setup, but it's definitely more pronounced with my current set up.
I'm going to play around with tire pressure to see if it helps any because I'm running pretty high pressure. Though, I've experimented with it before. We'll see.
-PD
2005 V8 SR5 4WD Natural White
My Build Thread
My "Rally Rocket" 2017 WRX
superman3043 is offline   Reply With QuoteReply With Quote
alignment , drift , steering
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
ST001R-05 09/08/2005 Steering - Highway Speed Steering 'Flutter' CBR_GUY_IA TSB 2 11-30-2010 05:45 PM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
Toyota Manual Mistakes & Corrections Post <<<< 4th Gen T4Rs 2 04-27-2007 12:19 AM
