Originally Posted by JustSomeName
forgive my ignorance, but what are the benefits of installing spindles? ive seen them on some rigs, but never knew what they were used for...
if you take a look at the picture below, you can see that the coil overs are pretty much cranked all the way, which provided all of the lift for me. (about 3")
With the coil overs maxed out, i would get little to no down travel. but by installing spindles, i am able to adjust the coil over back up (decreasing the ride height) and utilize a lot more down travel while still maintaining the lift that i want. So basically what i did was i adjusted the coil over so i got 0"-1" of lift, then i installed the spindle which brought it back up to 4"-5" in the front. i hope this makes sense haha
