01-14-2016, 05:42 PM
#46
Real Name: Jake
Real Name: Jake
Originally Posted by EdmundGTP
Same in every single way except the colors of the casing, and of course the Odyssey name brand mark-up. A couple years back, identical DH Platinum AGM's could be had for about 2/3's the retail of the same battery branded as Odyssey. Seems to be not so much the case anymore?
Good to know. I really wanted one of those 31M Diehards, but now I guess I'll go with the Odyssey. Really like the idea of having the dedicated posts and the two accessory posts. Might stop by my local sears to see if they have any left in stock though.
"Po" - '18 Super White TRDORP - Build Thread Here
"Sirius Black" - '03 Limited V8 Build (Sold) - Build Thread Here l 03->06 Headlight Swap Guide
My Photography // My Videography
01-14-2016, 06:58 PM
#47
Good luck. Be aware its an extremely heavy battery and it is a tight fit, if you find one. I had to readjust my front coilvers a bit after putting in this battery and a winch.
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
01-14-2016, 07:03 PM
#48
Real Name: Blake Salce
Duralast gold with 710 CCA I believe. Built to last.. Duralast :-)
01-14-2016, 09:35 PM
#49
If you have a Batteries Plus by you, they sell the X2Power batteries. Northstar (the split from Odyssey) makes them. Look exactly the same. 10% off coupon if you order online for in-store pickup, and there is a $30 rebate right now.
01-15-2016, 12:01 AM
#50
Real Name: Jake
Real Name: Jake
Damn, my fronts aren't adjustable. Guess I might just go with a slightly smaller battery as opposed to the 31M. Maybe the 34R then.
01-15-2016, 07:35 AM
#51
I believe I saw in another thread that the stock battery is 60, and the 31m is 75. so we're talking 15 pounds.
01-16-2016, 11:58 AM
#52
Real Name: Jake
Real Name: Jake
Hmmm interesting. So after doing more research it seems the 31M would probably be overkill for me, both size and weight wise, but I really like the thought of having a bigger battery in general, especially one with additional posts for accessories. The Odyssey 34M AGM l found looks to be a winner. I don't know much about batteries, so what do you think?
Edit: Crap nevermind. I realized the posts are backwards for us and I would have to redo the wires...Damn
07-10-2016, 09:37 PM
#53
I was looking at Optima Blue Top. Spec sheet from Optima for the Blue Top - http://d26maze4pb6to3.cloudfront.net...pecs_Sheet.pdf
Blue Top is the marine AGM battery, has the dual posts. D34M or D27M are dual purpose, starting and deep cycle. Both fit in the OEM plastic battery tray. I like the marine screwdown connections.
Donated to SoulDog Rescue - '07 Limited 4.7 4WD | Toytec Boss kit front and rear set to 2.0" in front with standard Superflex 2" lift rear coils | Firestone 9" airbags | 600W Samlex PSW inverter | Slyfox SAIP bypass | Toytec 14" rear brakelines
'08 Limited 4.7 4WD | Toytec BOSS kit front and rear set to 2.75" front standard Superflex 2" lift rear coils | SPC balljoint UCA's | Firestone 9" airbags | Slyfox SAIP bypass | Toytec 14" rear brakelines
07-10-2016, 10:01 PM
#54
The optima blue tops are identical to the yellows but a marine style. Tough son of a guns.....
1997 T4R SR5 3.4L 5 speed with factory e-locker bought new with almost 1km on it
11-11-2016, 04:34 PM
#55
Originally Posted by noshortcuts
I went with Toyota Truestart 00544-27F60-710
710 CCA / 165 RC
84 month warranty
Same specs as Interstate MTP-27F, I believe.
Cheaper than Optima from the Dealer. It was about $110 w/coupon.
But will I get 8 years out of it?
Update: Lasted exactly 3 years and they won't replace under warranty because it says "need charge" and not "defective" when they test it.
2006 Limited V6 4x4 // EXTERIOR: White Knuckle sliders; Ricochet Aluminum Armor; RCI LCA and Gas Tank Skids; yellow fogs; two 6" LED work lights; two 6" LED reverse light // STEREO: Pioneer deh-80prs head unit; Alpine MRV-M500 Mono Amp; JL Audio 8" Subwoofer // UNDER HOOD: aFe CAI Stage 2 and aFe throttle spacer; Budbuilt Hidden Winch Holder; Engo EPF 10,000S winch // LIFT: Toytec Ultimate 3"; Extended Rear Sway Bar Links; front sway bar delete; 32.1" Toyo ATII TWEAKS: VSC Off Mod ; Speedohealer; LED's
11-11-2016, 09:31 PM
#56
Registered User
Registered User
EXIDE AGM IS good.
11-12-2016, 09:52 AM
#57
11-12-2016, 10:06 PM
#58
I still have the original Panasonic battery in the 2008 at 133,000 miles!
I had a yellow top Duralast in my 2000 last winter. I think it was just under two years old. One snow day when it was about 10 degrees I did donuts off road and the battery split and spilled all its contents. Autozone replaced it for free. They are not yellow on top anymore which messes up my Fisher Price theme under the hood.
I had an Optima red battery in my '89 for two years. Hint: Tacoma World has a great on line coupon for Advance Auto. I got it for 40% off ordering it on line and picking it up in the store. It went bad this summer but they have a three year warranty. It was replaced for free.
I do really like buying batteries from Autozone or Advance because they are everywhere and open more hours than Costco. Their computers remember the warranty.
1989 4Runner Build thread: http://www.yotatech.com/f199/nervo19.../#post52231244
2000 4Runner & 2000 Tacoma TRD Off Road
2008 4Runner & 2016 Tacoma 4x4 Dbl Cab TRD Sport
11-13-2016, 06:52 PM
#59
Real Name: Chris
Real Name: Chris
I went with this, its the same as the Deka Intimidator for a lot less.
AGM type
Super Start Platinum 34RPLT - Battery | O'Reilly Auto Parts
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
09-01-2017, 09:17 PM
#60
Any new additions to be looking at? I'm thinking I need a battery soon
