Old 04-19-2014, 03:52 AM #1
dgwood12's Avatar
dgwood12 dgwood12 is offline
Real Name: Dustin
dgwood12 is on a distinguished road
dgwood12's Avatar
Real Name: Dustin
Door Lock Actuator
The past two weeks I have had an issue with my driver side door lock. The actuator is not functioning as it should and a lot of the time, does not lock the door when I hit the lock button on the key fob. I have searched for other threads but most of what I have found is people who have the actuator not working at all.
Does anyone know if it is possible to lubricate the actuator without taking the panel off? I can tell the actuator is still good... It just seems that there is something gunking it up and preventing it from locking. The unlock function works fine. If this is not possible, does anyone know of a write up on replacing the actuator so I can figure out how to get to it to lubricate it?
In addition, what is recommended to use as lubricant? I've read that WD40 can lead to rust if use in door locks. I have also read that a silicone lubricant is preferred.
2008 4Runner SR5 4x4 (Galactic Grey Mica)
Got Satoshi? - Compiled: Satoshi Build, Help & Picture Thread
dgwood12 is offline   Reply With QuoteReply With Quote
Old 04-19-2014, 07:39 AM #2
jason56414 jason56414 is offline
jason56414 is on a distinguished road
my passenger side just did the same...would work sometimes..then fail etc..I ended up replacing it with an ebay one that a few guys on here did. Its pretty easy
this is the guy selling them-this is the right for passenger door though
Lexus Toyota Scion Front Right Door Lock Actuator 2002 2010 $30 Refund | eBay
This will get the panel off
https://www.youtube.com/watch?v=SKZw4h1QY2c
then there are 3 torx screws in the jam that hold it in....take those out and peel back the plastic film to reach your hand in to get it out...there is also a 10mm bolt on the door you need to remove to move the internal bar out of the way.....swap the cables...re insert...make sure the rod from the door handle seats....and then just button it up...I had no manual and did it in about 2o minutes yesterday
2006 Sport White-Mine
2013 Limited Charcoal-Boss
2016 Limited Midnight-Boss
2023 ORP-Silver All me
jason56414 is offline   Reply With QuoteReply With Quote
Old 04-19-2014, 04:09 PM #3
dgwood12's Avatar
Real Name: Dustin
dgwood12's Avatar
Real Name: Dustin
Is it possible to lubricate the actuator? I am hoping I dont have to buy a new one since this one still seems to be functioning and is just having trouble with the lock direction.
Old 04-19-2014, 04:37 PM #4
I suppose you could...still need to do the same steps to get to the cables. although I haven't heard of anyone doing that and correcting the problem...
Old 04-20-2014, 01:45 PM #5
dgwood12's Avatar
Real Name: Dustin
dgwood12's Avatar
Real Name: Dustin
Thanks for the info man. If it's easy enough to access, I'll try to lubricate it first and worse case scenario, will have to shell out the $100 for a new one. Thanks again!
FS: Power Door Lock Actuator with Lock Latch - rear passenger side T4RTX For Sale: T4R Items 4 06-26-2014 02:58 PM
Door lock actuator bdstokes1 3rd gen T4Rs 1 01-27-2013 02:17 PM
Door Lock Actuator?? spoiler900 3rd gen T4Rs 2 01-10-2012 05:00 AM
Bad door lock actuator - Need help 97BlackAckCL 4th Gen T4Rs 2 05-10-2011 04:28 PM
