Old 05-27-2014, 10:06 PM #1
golfinw71's Avatar
golfinw71 golfinw71 is offline
golfinw71 is an unknown quantity at this point
golfinw71's Avatar
Post Trailer Running Lights
I have a problem that has me stumped. Here is the quick and short of what happened. I hooked up boat trailer and lights and everything was working as it should. Then, somehow the tunning light wire and the ground wire on the Trailer crossed ultimately melting a lot of the trailer wiring and ruining my trailer light adapter (7 to 4 plug). I bought a new adapter, rewired the boat trailer wiring but cannot, for the life of me, get the trailer tail/running lights to work at the truck's towing adapter. Here is what I've tried thus far:
Checked all fuses both in the cabin and under the hood.
Checked the Towing relay, it's good.
Using a test light I have confirmed that all the other terminals at the truck adpater are working, the running light connection is not getting power. I even unhooked the factory adapter and tested the terminals that connect to the adapter.
I bought another relay towing adapter thinking mine somehow took a crap. Put the new one in and same issue.
I checked the terminals and connection at the adapter itself, nothing melted or abnormal looking. I unhooked the adapter and tested the "ground" to "running light" connection - no power (using test light)
From the wires I can see doing all this none look melted or abnormal.
The tail lights on the truck are fine.
Please help, is there a mysterious fuse I am not seeing, relay or some other way I can find the problem??
Never realized how much I towed at night until this has happened! Thanks for the help folks!!
2006 Toyota 4Runner Sport 4X4
1978 Toyota Land Cruiser BJ40
golfinw71 is offline   Reply With QuoteReply With Quote
Old 05-30-2014, 05:44 PM #2
golfinw71's Avatar
golfinw71's Avatar
Bueller??
Old 05-30-2014, 06:24 PM #3
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
Sounds like a ground issue, here is the Toyota wiring schematic. Hope it helps and good luck.
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 06-01-2014, 08:04 AM #4
golfinw71's Avatar
golfinw71's Avatar
thanks Morphious, I'll give it a shot. Where did you get this diagram? I have the Toyota repair manual but haven't seen a wiring diagram like this in it
Old 06-03-2014, 07:07 AM #5
golfinw71's Avatar
golfinw71's Avatar
Well, long story short, double, triple, and quadruple check ALL fuses. After using the wiring diagram morphious provided I was able to conclude there weren't any additional converters, relays between the connector in the back and the engine compartment. I even bought a new "relay towing converter" thinking my problem was there. Not only did that not work, but the trailer/running lights don't even go through relay. I used my voltmeter to see if I was getting power to the towing relay by engine, no-power. Only place left was the main fuse panel. Low and behold, I found a 40 AMP square fuse that was blown. Two months of pain and agony were caused by a lowly fuse. Thanks again for the help Morph
Old 06-03-2014, 08:39 AM #6
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
I am glad you were able to figure it out, here is a link to the diagrams that are stickied to the top of this forum. Very useful information.
Service Manual Download Links.
running , tail lights , towing , towing tail lights , trailer lights
No Trailer Running Lights (have brakes and flashers) MtAiryEd General Discussions 13 04-29-2018 07:25 AM
'97 trailer lights Stickit1997 Maintenance/Detailing 2 07-28-2011 09:52 AM
Trailer lights slowhand197 4th Gen T4Rs 2 05-30-2010 08:13 AM
Connection for trailer lights BretSuAz 4th Gen T4Rs 8 03-17-2009 12:38 AM
Trailer Lights Question Dirt4dinner 3rd gen T4Rs 2 05-09-2008 01:35 PM
