05-30-2014, 11:13 AM
AC compressor kicks on and off
After buying my 2006 4Runner this winter, I tried the AC for the first time about a month ago and I realized it was blowing cold on the passenger side and warm on the driver's side. I recharged it with a bottle of R134a and it blew cold on both sides.
Recently, I realized that the AC compressor keeps kicking on/off so the vents will alternate blowing cold/warm air. After researching it a little, I found that this is a fairly common problem with the magnetic clutch relay, (same part number used for fog light relay) Here is a thread from another forum that addresses it 2003 4Runner Air Conditioning issues... - Toyota 120 Platforms Forum
So I started looking around for relays and some guys are saying that the EVERCO 35874 from Autozone works, but it doesn't match up on the Autozone website. Autozone says this is the fog light relay Relay - Fog Lamp | 2006 Toyota 4 Runner 4WD 8 Cylinders T 4.7L EFI DOHC | AutoZone.com but they don't list an AC compressor relay.
Amazon says this Four Seasons 35874 Standard Relay Amazon.com: Four Seasons 35874 Standard Relay: Automotive works for slightly older 4Runners, but not for 2006s.
Amazon says this Standard Products ry345 fits my 4Runner, it appears to have an additional prong unlike the above relays. http://www.amazon.com/Standard-Motor...ds=ry345+relay
If I can, I'd like to avoid dropping $70+ to get the part from a dealer, can anyone clear up if any of the above relays would work for my 4Runner? Thanks
2006 Toyota 4Runner, SR5 Sport package, 4.7L V8, 4WD
Mods - HCF delete, fog light mod, Gibson stainless catback, K&N air filter
05-30-2014, 01:50 PM
I sourced my replacement magnetic clutch relay on eBay.
Just type in the part number (90987-02028) in the eBay search and you'll find some.
My Canadian Toyota dealership wanted way too much money for it up here, so I bought a brand new Toyota oem sealed in original packaging relay from a U.S. eBay seller for much less (even with cross-border shipping).
The relay has worked great ever since.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
05-30-2014, 06:33 PM
Real Name: John
Real Name: John
I bought 3 of these and they work for all, fog lights, AC, dome lights, etc.
AIRTEX / WELLS Part # 1R1696
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
05-30-2014, 08:21 PM
Have you pulled the relay and swapped it with the fog lights to verify that will fix the issue?
05-31-2014, 10:58 AM
I was at work yesterday with my Mustang when I started the thread but I got home and verified that the relay in the 4Runner was the part number you referenced above. It is a 4 prong relay.
Originally Posted by morphious
Thanks, I will probably buy a couple as spares at that price. The picture shows similar prongs as what is installed.
Didn't swap but I did lightly tap the relay on the garage floor and when I reinstalled, the AC compressor stayed on like it's supposed to. From my research, the relay in my 4Runner was the "improved" relay that was called for in the earlier TSB but it still seems to be on it's way out.
Thanks for the help guys.
