Old 06-14-2014, 06:05 AM #1
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
zero point calibration
is this the same way instead of using the jumper wires?
reason is that my fuel gauge was being funky, so once the needle droped to 1/4, i filled it up, it went to half way mark, but i know my tank is full. then i get home and parked my truck, needle back to full mark now.
INCLINATION SENSOR ZERO DEGREE
CORRECTION
NOTICE:
• When replacing or removing/installing the
combination meter assembly and inclination
sensor assembly, be sure to perform zero degree
correction of the inclination sensor.
• When performing zero degree correction, install
the combination meter assembly and perform it in
level surface.
• Also perform zero degree correction when the
body level setting is inclined because of vehicle
height adjustment.
(a) Turn the ignition switch off.
(b) While pressing the RESET switch, turn the ignition
switch on.
(c) Within 5 seconds after the ignition switch is turned
on, repeat pressing and releasing the RESET
switch 3 times and keep holding the last press for
more than 5 seconds. (Buzzer sounds for a second)
NOTICE:
If the buzzer does not sound, perform this
procedure from the beginning.
(d) Release the RESET switch when buzzer sounds.
(e) Press the RESET switch again and keep pressing
for more than 5 seconds. (Buzzer sounds for a
second again)
HINT:
• When the buzzer sounds twice, reset operation is
completed.
• The buzzer sound of the first and second time is
the same.
NOTICE:
If the buzzer does not sound or keep sounding
for more than 1 second, perform the procedure
from the beginning.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 06-14-2014, 06:16 AM #2
riceandpho's Avatar
riceandpho's Avatar
got it from here in the service manual, meter section.
0520012.pdf
Old 06-14-2014, 06:45 AM #3
ebg18t ebg18t is offline
ebg18t is on a distinguished road
It is worth a try. I just use the TIS Techstream.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
zero point calibration needed? rutledj 3rd gen T4Rs 10 07-08-2015 01:39 PM
Zero Point Calibration on 04 V8 dave4242 4th Gen T4Rs 3 04-20-2013 07:29 PM
Zero Point Calibration RiDE 5th gen T4Rs 3 12-28-2012 05:28 PM
Zero point calibration question run4estrunner 4th Gen T4Rs 1 09-19-2012 12:23 PM
Zero point calibration Help? 4runner_03V8SPT 4th Gen T4Rs 0 10-17-2010 05:50 PM
