Old 06-14-2014, 08:57 PM #1
pj2006 pj2006 is offline
pj2006 is on a distinguished road
Sway bar bushing is dry/torn boot/link kit
Hi Everyone,
Took my 2006 4Runner in for an oil change today and this was written on the vehicle inspection sheet:
"Sway bar bushing is dry/torn boot/link kit'
I didn't speak to the service advisor so I'm not sure what that means. Can someone explain like I am five?
Thanks!
pj2006 is offline   Reply With QuoteReply With Quote
Old 06-14-2014, 09:15 PM #2
preacher35's Avatar
preacher35 preacher35 is offline
preacher35 is on a distinguished road
preacher35's Avatar
Originally Posted by pj2006 View Post
Hi Everyone,
Thanks!
Your T4R has a front sway bar and a rear sway bar. Both sway bars attach to your vehicle at 4 points. The two inner-points each have a large rubber bushing that the sway bar passes through and pivots up and down in. The two outer-points attach to the frame via "links" which look similar to little tie rods. The front links each have one ball joint and the rears each have two ball joints. Here is a diagram of the rear DRIVER side:
Did the service advisor clarify which sway bar and/or links required replacing?
2005 Sport Edition V6 / Toytec Ultimate 3" lift / Light Racing UCA's / 17x9 KMC Hoss wheels / 285/70 17 Goodyear Duratracs / Gibson cat-back / black headlights / HID's / Shrockworks bumper / Rola Vortex roof basket / LED interior swap / Emelianenkov's gauge cluster LED swap /
preacher35 is offline   Reply With QuoteReply With Quote
Old 06-14-2014, 09:22 PM #3
preacher35's Avatar
preacher35's Avatar
BTW, these are all relatively cheap repairs. The sway bar bushings run about $15.00 per bar, front links are about $18.00 each and rears are about $35.00 each at Autozone. Also, if your T4R has a lot of miles, I would recommend changing ALL of the bushings and links out for new ones as this will improve your T4R's handling, dramatically.
Old 06-14-2014, 10:37 PM #4
RPC's Avatar
RPC RPC is offline
RPC is on a distinguished road
RPC RPC is offline
RPC's Avatar
Check out: Swaybar Bushing Upgrade
Not Stock 2008 V8 4WD SR5
RPC is offline   Reply With QuoteReply With Quote
Old 06-15-2014, 08:48 AM #5
Thanks for the excellent description! Yes the sheet says front passenger side.
Old 06-15-2014, 08:51 AM #6
It has approx 95k miles. Is this a mod that can be done with basic tools on a weekend? Or is this something I might want to take the car to a shop for? I am no pro, but I can turn a wrench.
Old 06-15-2014, 01:33 PM #7
Rocket61's Avatar
Rocket61 Rocket61 is offline
Rocket61 is on a distinguished road
Rocket61's Avatar
Definitely something you can do yourself with basic tools.
White 2017 TRD Pro
Black 2007 Limited V6 4WD - Sold
Rocket61 is offline   Reply With QuoteReply With Quote
Old 06-15-2014, 02:00 PM #8
preacher35's Avatar
preacher35's Avatar
Please make note, the front sway bar diameter is 29mm (which seems to be standard of ALL '03-'09 T4R's), but the rear sway bar diameter varies (which is very important if you are going to change the rear sway bar bushings). Before purchasing your rear bushings (assuming that you are going to change out the rears), you HAVE TO put a micrometer on the rear bar and measure the diameter as it could range anywhere from 17mm up to 21mm, so you need to be sure.
CV boot torn, how bad ? Jester_67 Problems & Warranty Issues 2 07-24-2013 05:09 PM
Tie rod boot torn Matteson General Discussions 0 06-01-2013 11:10 PM
energy suspension sway bar bushing and end link sizes? jblazy18 3rd gen T4Rs 10 08-09-2011 09:04 PM
Need help with end link and sway bar bushing sizes durrell 3rd gen T4Rs 0 09-09-2010 08:58 PM
rack boot torn freshley 3rd gen T4Rs 4 08-16-2010 11:57 PM
