Originally Posted by BlackWorksInc
I had a similar issue recently on a 1st Gen Tacoma, we ended up recommending a replacement caliper. The outer pistons were going far slower than the inner ones, in fact the front outer one was even slower to act than the rear outer piston (was a 4 piston fixed caliper like the 3rd gens.)
I would assume that a rebuild would have fixed the issue, but we don't do that at the dealership anymore; so it was a new caliper to correct the issue.
Is there any way to tell that one may be moving slower than the other? Did you guys just pop the brake shoes out(or pull the caliper off) and have somebody press the brake?
I think I will try the rebuild kit since they are so cheap, thanks for the reply!
Originally Posted by LargeOrangeFont
FWIW I only got about 20K miles out of my EBC Green 6000 pads before they were either worn out completely (rears) or the brakes started pulsing (fronts).
This was with 2 sets of pads.. I just switched to Centric Posi Quiet all around yesterday.
Well that makes me feel better, I drive a little aggresive, but not bad enough to only get 20,000 miles out of the brakes, I am not too impressed with EBC. I am getting pulsing right now and that front right is squealing. I also think when I do my next break job I will be using a different type. Thanks!
Originally Posted by blackfc3s
Honestly if you can't get them (the brake pistons) to move by slight force such as by hand or by plastic board clamps, its on its way to being fully seized.
I can't honestly remember if I had to torque on them or not, I dont think I did but I will keep this in mind on the next brake change.
